Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 22, 2016 08:10PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 02:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 07:41AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 01:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 02:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 03:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 23, 2016 04:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2016 12:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2016 06:46AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2016 08:44AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2016 03:25PM |
Yes thanks, the host height map. Tried a clean attempt with reset as you suggested but it was a no go. I suspect I have a firmware setting that is glitching the height mapping up.Quote
docpayce
@Gingerbreadman: I dont understand what you mean by importing corrections? Do you refer to a G30 command running slow? Or do you refer to Repetier host height map? If the latter - its kinda jerky. You will want to go sure that Repetier host software finished every command (none in the buffer) and knows the actual position (i.e. dont open the height map window until everything has stopped moving and is at its place).
Other than that... have you tried to switch it off an on again? ... jk, sorry.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 25, 2016 05:29PM |
Zoolander06
I just have one question about the build volume of this printer. The FT site says 210mm diameter and 310mm height, but after reading all 104 pages of this topic, it seems like the reality is more about 170mm diameter and 240mm height, which is a lot smaller !
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 26, 2016 06:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 26, 2016 11:02AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 26, 2016 12:57PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2016 02:42PM |
But I have to say the smartrapcore seems nice, and it's a local product, that's a +1, thank you spiffcow ! I will check to the T3P3 site too !
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2016 03:38PM |
Zoolander06
A lot of people told me about the Prusa I3, but I have to say that I kind of dislike this design. I know it's efficient, and easy for the newbies, but I don't like moving Y axis... And maybe I'm an outsider, I don't like the easy way
So my choice is not definitive, but for now, I prefer deltas... I think I'm capable of setting it up, even after reading a lot of testimonies about how it can be a PITABut I have to say the smartrapcore seems nice, and it's a local product, that's a +1, thank you spiffcow ! I will check to the T3P3 site too !
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 27, 2016 06:53PM |
Zoolander06
Hello,
Thank you all for your advices !
And if my first try is a success, I already have a big size corexy design in my bookmarks (the 3C-bot, based on openbuild extrusions)
Thank you all again !
PS : excuse me if my english is not always good, I try to be comprehensible, but sometimes, I fail ^^
Joris
C-Bot is actually an active project now with various configurations, including the 3 lead screw option. I would encourage you to look into the main project as the community is pretty active. D-Bot is a more popular derivative and has better instructions, though most D-Bot builds tend not to deviate from instructions. It'll be interesting to see where the community goes from here.|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2016 06:19AM |
spiffcow
Nice! I hope it works out whatever you decide. You just missed a big sale they had where you could have gotten the larger SmartRapCore for roughly the same price, but honestly I wouldn't trust 2020 to be rigid enough for a 300mm cube build volume.
spiffcow
The CoreXY I'm building is a C-Bot Rework, so your target and mine are close relativesC-Bot is actually an active project now with various configurations, including the 3 lead screw option. I would encourage you to look into the main project as the community is pretty active. D-Bot is a more popular derivative and has better instructions, though most D-Bot builds tend not to deviate from instructions. It'll be interesting to see where the community goes from here.
spiffcow
Also another option -- source the Kossel parts yourself. The parts are being mass produced at this point, and you can probably get high quality metal parts off ebay or aliexpress pretty cheap.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2016 06:29AM |
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 28, 2016 09:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 01:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 01:44PM |
stephenrc
Red is +
Black is -
Yellow is tachometer (not used if just powering the fan)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 07:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 07:32PM |
Captain_Tim
Should the cooling fan for the prints be connected to the RAMPS board, or should it just be always on and connected to the PSU. If it should be connected to the RAMPS board, anyone know which pinit gets connected to for Paul's Repetier FW?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 07:35PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level March 29, 2016 07:36PM |
paul_delta
In my 0.92.6configuration only hotend fan connected to RAMPS pin 9 (ORIG_FAN_PIN). This way firmware turns the fan only if hotend temperature greater than EXTRUDER_FAN_COOL_TEMP. You can re-configure your setup and run hotend fan directly from PSU (always On) and use 9 pin for filament fan. In this case you can use slicer commands to turn fan on/off when needed (depending on layer height for example) and change fan speed.
Update: you will need to change Configuration.h and pins.h to let firmware know how to operate the cooler.
Captain_Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2016 02:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2016 02:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 01, 2016 04:24PM |
paul_delta
Did you try >90mm/s printing? I think the whole assembly will have too much inertia to get adequate quality for high sped.
