Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 03, 2016 01:51AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 05, 2016 05:19PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 07, 2016 07:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2016 06:01AM |
fredw
Any suggestions about the best way to terminate the thermocouple wires to the pin strips on the controller board would be greatly appreciated. Thanks in advance.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 08, 2016 07:33PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2016 11:02AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 09, 2016 01:07PM |
fredw
I found the second pigtail.I had attached it to the fan for later. Now, I see the fan connects to the terminal block.All is well. Connecting the display board is way too easy. I found a three wire cable and I do not know what it is for. I attached a picture.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 15, 2016 03:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 23, 2016 09:58AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 23, 2016 12:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 28, 2016 10:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2016 08:11AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 29, 2016 11:13AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 30, 2016 06:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 01, 2016 04:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 02, 2016 09:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 03, 2016 06:51AM |
sharkicicles
Hi all,
My kit should be in in a few days and I've been spending the waiting time reading through this thread. Apologies if any of these are re-asks, but I have a few questions:
1. For safety reasons I've been thinking of replacing the standard power supply with one that gets AC through an IEC plug and has a built in fuse. Anyone else do this?
2. I had a couple of jig mounts (http://www.thingiverse.com/thing:37306) made which I plan to screw to some wood to make the rods. Any pointers on how to make sure the jig is true?
3. Is any lube recommended for the rev B printed sliders, like maybe a silicone spray on the rails?
Thanks all. This thread has already been invaluable.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 03, 2016 11:30AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 05:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 06:05PM |
docpayce
Hey!
In addition to Legrand:
- ATX PSUs are pretty good bets when it comes to exchanging the power supply. They come with all bells and whistles (short protection, built-in fan, power switch, overload protection etc.) and are rather cheap when bought used. I got one for 30 bucks.
- Jig: If you take your time and use the jig to glue *one rod after the other* and not all at once, your results are not so dependant on the screws sticking out of the wood dead-on perpendicular. I still wish I had done so. But in the meantime, this doesn't matter anymore (see below ).
- No lube necessary. Delrin is really slippy on its own.
I finished magnet-rodding my Kossel: [www.thingiverse.com]
Results are, to say the least, GREAT. Print quality went up quite a bit (mainly due to zero backlash). And the best part: Whereas I could only use a radius of 60 mm ... 70 mm before, I can now easily use the full radius of 100 mm without any issues. Bed correction is still necessary, but has to do way less work than before (~ +/- 120 µm). I can fully recommend doing this mod. Costs are reasonable (~ 35 bucks) and results are reeeally nice.
My rod length is ~ 280 mm, which results in my printing height to be reduced to usable 195 mm ("usable": I can still print the full 200 mm diameter at 195 mm height). Maybe I will get a second set of rods (~ 250 mm) for smaller footprint but higher prints. Changing the rods is eeeeasy.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 06:22PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 06:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 07:24PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 04, 2016 07:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2016 07:16AM |
sharkicicles
One more question for you folks- for the standard rods, I noticed the Folger traxxas ends already have the grommet installed, whereas my jig ends are designed for bare ends. Would it create too much play to try to pop the metal parts out and back in, or should I just get some new ends that haven't had them installed yet?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2016 11:24AM |
Legrand
Personally I wouldn't recommend it. You're going to open one side of that plastic joint up and I don't know how you can achieve a "factory" seal again with all the proper clearances. I'd try to modify the jig before I'd modify the rod ends.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 05, 2016 08:29PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2016 06:03AM |
Captain_Tim
Is the 2004 LCD only supposed to work when the printer is plugged in via a USB? I can't get my LCD to turn on when it's just the 12V, but it'll turn on if the USB is connected, whether or not the PSU is on or not.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2016 07:36AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 06, 2016 10:49AM |
