Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 31, 2016 06:09AM |
matthew900
matthew900
Hi, I've haven't used my printer in about 6 months and tried to get it working again this week. I had upgraded to windows 10 since I last used it so I updated the Arduino softare and printrun. Now I can not get the printer to work. When I try to load the firmware with Arduino I'm getting the following error message:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
I thought maybe it was an issue with the updated Arduino software but I also can not get printrun to connect to the board either. Anyone encountered this error or have any ideas? Thanks!
I got the new Arduino and I uploaded the firmware the first time with no issues. Then after that then when I made some changes to my firmware and tried to upload it again I started getting the same errors. Anyone have any idea what can be causing this? I've tried multiple computers with different operating systems. I can get printrun to connect to the printer, I just can't get the firmware to update.
I'm so frustrated that I'm ready to just throw this thing in the trash
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 03, 2016 08:36AM |
matthew900
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 06, 2016 10:52AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 06, 2016 02:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 08, 2016 07:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 09, 2016 12:07PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 09, 2016 07:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 10, 2016 12:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 12, 2016 03:52PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 12, 2016 06:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 12, 2016 09:25PM |
UncleSas
After a few (OK 15-20) rounds of tuning the prints, I started getting prints that I thought were up to snuff...
So, naturally, I started printing minor upgrades; including these legs with adjustable feet: [www.thingiverse.com]
It looks like the center hole on the base lines up with the center hole of the 2020 extrusion. Has anyone here tapped the center hole of the ones that Folger ships? If so, are they M5 or M6?
Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 13, 2016 03:32AM |
Sintensity
Another question related to the hot end....
I've got my Folger Tech Kossel up and running, and I've made a few fairly decent prints in PLA and ABS. That said, I got my hands on some Taulman 645 filament, and I'd like to see what I can make with it. My problem is that the Folger Tech build guide, user manual, or online documentation do not state any upper limit or maximum recommended temperature for the stock hot end. The only note on temperature is on the Folger Tech Kossel 2020 product description on the website, which says the hot end runs at 230 degrees. Taulman 645 needs to be extruded between 242-248 degrees Celsius. Is 230 degrees the maximum for our Kossel? Can I run it 12-18 degrees more? Or is that not recommended? I thought I'd ask first before simply bumping up the temperature (and maybe seeing fan & induction sensor bracket melt away).
Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 13, 2016 06:07AM |
Sintensity
Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 14, 2016 01:48AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 14, 2016 06:06AM |
sharkicicles
Re: my earlier post about the hot end not heating- apparently I did too good of a job covering up the fan as the hot end decided to eat the effector. Serendipitously enough though, I was ordering some small parts from Folger and decided to get the aluminum effector to change on out at some time. Well... that time is now.
Before the new one goes on I'm going to do some more airflow tests to make sure the hotend is getting enough cool air, then put the new effector in and print out that darn fan shroud.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 14, 2016 03:11PM |
Legrand
Make sure there is a air gap between the hot end and the cylindrical, finned "cooler". I made the mistake of butting the two pieces together and the hot end couldn't push enough heat into the tip with the cooler sucking it all away.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 14, 2016 10:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 15, 2016 07:24AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 15, 2016 12:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 15, 2016 08:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 16, 2016 06:05AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 17, 2016 02:03AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 18, 2016 11:52PM |
paul_delta
Here is another tool to auto-calibrate Delta with Repetier firmware:
[forum.seemecnc.com]
Please share your experience.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 20, 2016 12:47AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 21, 2016 07:42AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 22, 2016 03:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 22, 2016 10:10PM |
docpayce
@paul:
I tried to get the software running, but got no luck: I can install and start the software and connect to my printer. But I cannot do anything else without the software crashing (no G-Code sending, no calibration, no EEPROM, no nothing). I am on a Win10 machine with german localisation - but I also tried to switch to US localisation without any luck. Did you have any luck?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 24, 2016 04:57AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 24, 2016 11:27AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level June 24, 2016 06:42PM |
