Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 11, 2016 06:48PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 11, 2016 06:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 11, 2016 06:55PM |
spiffcow
Has anyone here upgraded their electronics? If so, did it make a difference in print quality?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 11, 2016 07:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 11, 2016 08:08PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level November 22, 2016 11:06PM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 04, 2017 11:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 07, 2017 07:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 12, 2017 04:23PM |
thosmos
Careless
So what is the general consensus on this Folger Tech 2020 Kit in its newest iteration with all the cool ALU parts?
Does it remain as one of the better Kossel un-assembled pre-packaged kits that comes with (almost) everything required?
I am thinking of purchasing. Definitely want a Kossel, and this one looks reasonably priced considering shipping and base price.
Lets remove past printing and tool-handling experience from the equation- is it a good buy, or good bye?
It's my first printer and I think it's generally a good kit. It's worth a lot to have everything provided for a first-timer like I am. Now that I've built it and learned more, I would instead build one from scratch if I were to do it again.
I think its biggest downsides are:
1. incorrect default configuration settings in their firmware - especially INVERT_X_DIR, INVERT_Y_DIR, INVERT_Z_DIR set to true which caused my printhead to slam and scrape across the printbed on first powerup as it tried to home for the first time.
2. incorrect details in the assembly manual - thermistors needed to plug into different spots on RAMPS board than specified in manual; told to cut bowden tube in half, but then it would have been too short
3. insufficient screws of specific sizes - I needed to make a few parts runs to the hardware store to get specific sizes
4. printed parts with lock nut holders failed to keep nuts from spinning - needed to use regular nuts since there's no room in the printed part to hold lock nut with needle nose pliers
But even with those issues, I'm glad I got it. It's a solid kit and great starting point for upgrading as one learns more. Also the fact that quite a few other people have them means there's more community to communicate with about issues and upgrades (for example, this guy's Youtube videos helped me discover the INVERT_X_DIR issue: [youtu.be], and this guy's assembly video would have helped me if I'd seen it before: [youtu.be])
Thomas
