Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 11:08AM |
Flish
Got my kit finally delivered, assembled, configured (re-assembled, re- reconfigured)...
My X axis endstop doesnt seem to work right... - because of this, the carrage ended up sliding off the linear rail. (was able to get this back on without losing any ballbearings)
When homing, all the carriges rise up to the top and bump the switch -which activate the stop but the X axis seems to keep 'grinding' away after the switch is pressed and the light comes on. It grinds like this for a few seconds, causing alot of vibration and belt skipping - then it seems to finally register and stops... -like theres a delay.
I believe the connections are all good and the motor seems to perform like it should otherwise... I haven't tried swapping the end switches yet.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 02:41PM |
Flish
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 02:50PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 02:55PM |
Djkingsley
Flish
I had one end stop switch that was hitting the slide rail. I carefully bent the switch so that it was free moving.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 16, 2015 02:58PM |
MakerFront
They seem to have had an issue with their endstops lately, I put together 10 of their machines and had to re-crimp 2 of the 3 wires on the black connector side of the end stop cable. I had to do this for 12 out of 30 end stops.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 08:55AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 09:12AM |
I have to unscrew both ends of the teflon tube every time I change filament. Run a few cm's out of the extruder, then slip the tube down on it and screw in place. Extrude enough to get past the other end of the tube, then thread it into the hole in the top of the hotend before screwing down that end.Quote
Djkingsley
Has this happened to anyone else?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 09:48AM |
Djkingsley
Last night I fed the sample pack of ABS filament into the extruder drive and it would not go, the first issues was it hung in the molded block just before it goes into the hole above the gear. I manually lined up the filament in the block and re-installed it on the stepper motor, then it hit the brass fitting. Again I pulled some more length and got past that snag. It then smoothly followed the PFTE tubing until entering the second brass fitting, I have no idea what it is snagged on in the hot end.
Has this happened to anyone else? and if so how do you fix it. I assume I will have to take the hot end apart and check it to see what the filament is catching on.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 10:18AM |
Which extruder did you print? Do you have a link to the files?Quote
thevisad
First thing I suggest printing is a new extruder, the one that comes with the kit is only good for about half a dozen prints depending on your filament. My print quality increased as soon as I created a new extruder.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 10:21AM |
Deguello
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 10:25AM |
thevisad
It snagged on one of the many protrusions inside the head once out of the bowden there is a collar inside that feeds it into the shaft and then through the shaft to the throat, down through the throat into the bottom of the head. When I change my filament, I heat the head, unscrew both bowdens and extrude it to 3 inches past the end of the PTFE tubing. Straighten the filament out, then you can slide it into the head and you will fee the stops. The hothead is about 3 inches top to bottom, so if you get it right, it should extrude a little plastic as you manually insert it.
thevisad
Replacing pronterface/slic3r and moving to Simplify3d also increased the speed, accuracy and reliability of the prints. Thee last prints I made on normal with Simplify3d were absolutely stunning. I handed them to my son and he asked me where I go them. When I said I printed them, he freaked out and started inspecting them.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 11:34AM |
Djkingsley
Are you talking about the molded block the extruder gear fits into? if so I have already decided it had to go, one of my office mates found a design that works much better on his upscale version of the Folger design.
Djkingsley
I will eventually get Simplify3d, I am using the Folger printer as a stepping stone to prove the design of a line of products I am working on for the high power model rocket community.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 12:17PM |
thevisad
Djkingsley
Yes sir, that hunk of junk, which one did you go with?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 12:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 01:04PM |
Flish
I got the bed autolevel probing and clicking all the spots -so physically it works for me but, I added g29 and the deploy probe codes to Cura and it goes thru the probing routine then tries to print from the z probing height...
I'm new to gcode and 3D printing for that matter... so follows is the default start print routine in Cura with what I inserted in red:
;Sliced at: {day} {date} {time}
;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
;Print time: {print_time}
;Filament used: {filament_amount}m {filament_weight}g
;Filament cost: {filament_cost}
;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
;M109 S{print_temperature} ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
M280 P0 S5 // lowers the z probe thingy
G29 // autolevel probing
M280 P0 S120 // raises the z probe thingy
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...
What am I missing?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 02:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 02:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 02:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 02:36PM |
thevisad
Flish
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
What am I missing?
Z probe height is a negative value in the firmware, did you add it as a positive?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 03:03PM |
Flish
thevisad
Flish
G21 ;metric values
G1 F{travel_speed}
M117 Printing...
What am I missing?
Thanks... Went thru the trouble of making sure the X and Y offsets were correct so my probe didnt keep falling off the bed and left the Z a positive.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 03:08PM |
Deguello
Sounds like a great idea. My only question is how to account for a glass build plate since the proximity sensor is inductive. It would detect the aluminum bed under the glass. I guess I could give it something like M206 Z-2.5 after auto level.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 03:18PM |
Printing on blue tape is fine, but it's a bit of a pain to clean off. I use a piece of glass coated with purple AquaNet hair spray. Works great for both ABS and PLA. ABS has to cool down completely before it lets go, so I have several plates ready. PLA lays down beautifully and pops loose after it cools just a couple of minutes.Quote
TheLost
Correct me if i'm wrong, but you print directly to the Aluminum plate covered in either Blue (or Kapton) tape.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 03:27PM |
Deguello
I set up "Glass" and "No Glass" buttons in Pronterface to set the Z offset accordingly with M206.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 03:45PM |
TheLost
I'm still waiting on my kit...
But i'm wondering why more people haven't given up on the servo driven z probe and moved to a proximity sensor? Has anybody actually done it yet?
I use a proximity sensor (LJ12A3-4-Z/BX) on my Folger i3 and i've got one waiting for my Folger Kossel.
- + and - go directly to the PSU.. simple voltage divider in the middle.. one signal wire to the ramps (no power issues)
- No need to swing up/down the prob arms (Having been in the RC hobby for decades i know how 'accurate' low cost 9g servos are.. spoiler.. not very accurate)
- No change to firmware.. just leave out the servo setup.
- 1 extra line to your start gcode not 3.... G29 and be done with it.
- ~$7 from Amazon (prime)
I've seen some posts here that say the auto leveling in Marlin is messed up.. thats not true. I've used both v1.0.2 and the dev branch with no issues (other then commenting out a few 'safety checks' because the X & Y axis are backwards on my i3 to what the auto level code expects)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 07:41PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 07:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 09:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 10:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 17, 2015 10:49PM |
Cutting the carbon rods is a bit of a pain. Find an archery shop. They have a saw for cutting arrows to a specific length.Quote
coshtor
4. Offer pre-made calibrated rods for a small extra fee.
These springs?Quote
coshtor
5. I consider myself a smart guy, but I cant see anywhere in the manual where the springs are used.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level April 18, 2015 01:03AM |
Deguello
coshtor
These springs?Quote
coshtor
