Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 18, 2015 06:51AM |
cislom
I tired printing the same thing in PLA and it worked - so I think this must be heat related.
I will try putting a small fan on the board to see if that helps, I do have the board mounted under the heatbed like in the instructions, but was a little leery about that to begin with. If this is the solution I may try rewiring the board to be elsewhere.
Thanks for the quick response, I'll let you know how it goes.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 18, 2015 01:14PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 18, 2015 02:11PM |
cman8
Can you change slicr to have a circular graph?
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 18, 2015 06:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 01:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 12:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 12:52PM |
matthew900
I recently bought one of these kits and I was really disappointed with the quality of the linear rails. None of the 3 slide smoothly and one of them is so bad it keeps hanging up in one spot in the middle. I don’t trust these for the build. Is there another source of better quality rails at a reasonable price that you all would recommend? I’m building this with my 10 year old. It’s our first 3D printer and I know there will be allot of troubleshooting to get it working accurately but I don’t want to jinx us out of the gate by using garbage parts in the build.
BTW the printed plastic parts were shady. 1 of the 3 for the bottom and 1 of the 3 for the top where clearly the result of an inferior print run that they were hoping they could get away with using if only 1 out of each 3 in the set used the bad prints. There are even places on those bad prints where they cut of layers that delaminated so they knew they were bad and used them anyway. I’m not sure who they think they are tricking.
Given all the good things people have said about the kit I was a bit disappointed. I knew the linear slides might be an issue based on what I read here but the attempt to pass of the bad printed parts by mixing them in with good printed parts was really shady and disappointing. Please let me know if anyone has any suggestions on the linear rails. Thanks!!!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 01:10PM |
gaddcasey1
My printed parts where bad, i replaced them with metal ones from robotdigg, as for the rails you can always switch to v-rollers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 01:49PM |
matthew900
Genius! I’m stopping my build now to order these.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:08PM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:21PM |
matthew900
I followed the previous directions I found on here to use the WD40 and then grease (I used white lithium grease). There was no visible gunk on them like others reported but I went ahead and cleaned them anyway in the hope they would improve. I looked at the bearings where you can see them little between the rail and slide, they look clean.
I would be hesitant to use gun cleaning oil since it is designed to remove metal deposits and I do not know what components are inside the slides.
I think there is a bad bearing or possibly debris from manufacturing in the one since it has a clear dead spot where it catches and does not want to slide. This is my first 3D printer but no my first rodeo working on something mechanical. These bearings definitely have issues.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:28PM |
matthew900
gaddcasey1
A couple questions, I wanted verify 1 set came with all 3 top and bottom pieces, and does the top parts include the idler pulleys? Are there any other parts I need to order to use these? Thanks!!
This is designed to remove deposits:Quote
matthew900
I would be hesitant to use gun cleaning oil since it is designed to remove metal deposits...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:36PM |
Deguello
I contacted RobotDigg about metal parts, but the shipping was almost as much as the parts. I guess I'll make do with plastic corners until Folger gets theirs back in stock.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 02:57PM |
matthew900
3D52
Contact Folger and they will replace them!
Their customer service was quick to respond and they already said they would replace the bad one. I was just hoping there was better quality option out there. Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 03:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 03:43PM |
matthew900
gaddcasey1
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 03:49PM |
Deguello
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 04:02PM |
gaddcasey1
when mine came it did not, but i contacted robotdigg and they sent them to me for free(just arrived today). but it is not just an easy swap, the parts are 2mm thicker so all of you bolts need to be replaced and the bed mount will not work anymore. i am working on making a new bed mount. it came with 3 top and 3 bottom and when all put together is sturdy.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 04:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 06:26PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 07:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 08:33PM |
gaddcasey1
[attachment 54929 corneridler.jpg]
Here is the corner idler i got form robotdigg. it seems to fit the fanged bearings that came in the kossel kit, but i have no idea what the laser cut parts are for.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 08:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 10:03PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 10:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level May 19, 2015 11:01PM |
