Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 28, 2015 05:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 28, 2015 05:42PM |
dc42
I hang the PanelDue from the top front extrusion of my Kossel. See my autocalibration video for a picture. Not sure whether a Folger 2020 Kossel has enough width to do that though.
What firmware changes are you thinking of making? Very few Duet owners compile their own firmware.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 01:53AM |
thevisad
Koenig
Well the carriages of those are not a direct replacement, the boltholes on the MGN12H is 20*20mm CC apart (Width/Height) and misumis carriages are either 25*20mm or 20*15mm, doesn't matter much though it's easy enough to just drill a couple of new holes in the carriages if you choose to with 20*15mm, otherwise you will have design new plastic parts for the carriages.
EDIT: I was wrong about that seems they have long carriages as well but not when you search for SEBNL20 on their site (European version)
BTW, have you gone duet yet?
I have not come around to it yet, I have had so much trouble getting PETG to print with this printer.
The ones that I selected were 20 x 20 on the mini rails, the long rails don't have them like you indicated. Here is the catalog page for those rails.
thevisad
I got my Duet the other day and was finally able to compile the firmware on my own. DC42 is shipping me a duet screen controller and I should have that sometime in the next week or two. My next step is to determine where to place the screen unit. I am considering designing an enclosure that will sit on top of the delta, in the "front" of the printer.
thevisad
I updated all of the wiring for the printer as well and eliminated the single strand wires with looms. I ended up using all igus wiring, with the following part numbers,
CF240-01-04 (26awg, motor only), CF240-03-14 (22awg, hot end (5 amps max, hotend uses 3.3)), CF240-01-07(26awg endstops and LED lighting). This is the stuff that we will be using in our product, it's shielded, torsion resistant to 3m/s, heat resistant to 80c and can travel unsupported for 50m.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 04:23AM |
Koenig
That will surely look real nice, I just sleeved the cables and used cable-wrap like this where there many cables.
For now I have my electronics sitting on the side of the "Z-tower" for easy access my plan is to place it either in the bottom or underneath the top once I have everything dialed in to satisfaction. I would also like to place my PSU underneath the bed.
Koenig
I ordered some 0.9 degree steppers the other day wich I think is my next step, but I think at that point I will have to go for the duet as well to be able maintain a reasonable high travel-speed of the effector.
Koenig
I saw that you had thoughts about going for optical end-stops as well which I've seem many others do as well. As I understand it this improves the accuracy of Z-height so I'm thinking of doing something similar but using a capacitive proximity sensor, I remember seeing a video on youtube of a sensor with very high accuracy and repeatablity.
Not sure wich would be most accurate, optical vs capacitive, taking into account ease of installation/configuration.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 05:05AM |
dc42
dc42
Koenig
I still use mechanical endstop switches, and mine are reproducible to +/- 1 microstep using the 1.8deg motors. Using a Duet you can do auto calibration after homing to eliminate any small variations in the endstop switch trigger points. Even 3 factor autocal would be sufficient if you just want to correct for the endstops.
If you use a capacitive probe, check it for sensitivity to temperature and humidity. Whatever probe yo use, mount it as close to the nozzle as possible, because on a delta it's hard to get the effector staying completely flat as it moves n the XY plane.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 09:13AM |
Koenig
I can't find the video now but I think he was using a delta with a digital micrometer mounted at the effector and a capacitive sensor as a probe, and the tolerance was just a few microns over the repetitions he showed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 10:23AM |
Koenig
Did you incorporate the lines for dimension-correction in this as well?
EDIT: Anyone who can give me a hint of where to get only the short extrusion for a larger size kossel, I would like 2*20X60 and 2*20X20 in the length so I can fit a 300mm bed (I already have 1m extrusions as towers)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 11:04AM |
thevisad
I am going to put the electronics under the build plate like before. With the metal corners there is additional space under there that we don't have with the Folgertech plastics. I am going to design an enclosure for the Duet that will allow for all of the wiring to be fed through and keep it neat underneath.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 02:15PM |
dc42
thevisad
It's nice to have the electronics under the bed, but here are some points to watch out for:
1. Make sure you can access the USB and Ethernet ports and SD card socket without taking the printer apart. Although accessing the SD card socket is rarely needed after commissioning.
2. Preferably, make the Erase and Reset buttons accessible too. This is more difficult, because the buttons are on the face of the board. I added a gcode command for preparing the board for firmware upload (M999 PERASE) to avoid the need to press Erase, but occasionally it seems to leave the flash in a locked state and I have to press the Erase button. I am told that there is a Bossac command to unlock the flash, but I haven't tried it. The Reset button is less important, because you can power the board off and on again, or use software reset.
3. In a confined space under a heated bed close to motors and perhaps other heat-generating components, fitting a small fan to blow air over the electronics would be wise.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 02:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 02:43PM |
EdwinCal
Alright guys from my post earlier about the ramps board missing the 20 pins for the lcd display. I contacted Folger about it and they told me I needed an adapter that was supplied, but I have the adapter. The adapter is not the problem the missing pins are.
I emailed "I see the 20 04 adapter for the lcd but the ramps board itself does not have the pins.(pic)"
Folger response was "The location of where you hook up your LCD screen is up to you
The LCD was a separate purchase, we do not support it."
So Im confused because I purchased the lcd from them, and from everywhere I've seen selling ramps boards they all have those pins.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 03:27PM |
wrangellboy
EdwinCal
You definitely need those pins. I just installed the lcd they sent, and while it does come with an adapter, that adapter requires a single row of pins that you're definitely missing.
Edit: If you're ok with a soldering iron you could buy some pins and solder them on, that might be quicker than trying to get an RMA...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 05:36PM |
EdwinCal
Thanks for verifying there should be pins there.
Im not great at soldering, I can really only solder two wires together. I'm confused by their response as I like you bought the lcd from them when I bought the kit. So for them to say they dont support is well weird. I already bought some 2 pin connectors because I was short from the kit.
Almost at the end of the road with this kit :/
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 06:28PM |
EdwinCal
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 06:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 29, 2015 07:33PM |
EdwinCal
I appreciate your guys offers I may take you up on it. In in TN 37040. If someone is close enough and doesn't mind having me for an afternoon, heck Ill drive there. with the printer. Maybe learn a few things from ya too
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 02:17AM |
thevisad
1. Are you comfortable with soldering and assembling various electronic components?
2. Are you comfortable with compiling and installing your own firmware from the Arduino platform?
3. Are you comfortable around a toolbox? Meaning the tools in it, screw drivers, wrenches and how to properly use them?
4. Are you capable of understanding and diagnosing issues that arise with your printer or have access to those who can? This includes using forums like this to support you.
5. Would you buy furniture at Ikea and assemble it?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 02:20AM |
SlowFoot
thevisad
Buggers, I failed on the last one (I boycott IKEA because of the nasty habit to steal good design form small companies who can't afford a court fight.)
Hi all!
A few days ago I placed an ordered for a Kossel Delta 2020 kit from Folger.
I'm a mechanical engineer located in Sweden and been doing 3d modeling since the mid '80. In my work I have designed and built a few robots for various product testings.
Since 4 months back I am the frustrated owner of a Velleman Vertex K8400 3d printer. It works but the mechanic components are very crappy and I just got kicked out of the official Velleman forum for being a bit too outspoken about it. Faulty settings in the makers firmware is not a new thing to me either.
Point 2 above is not my strong side so I will pester you with a lot of questions when I get that far and probably sooner too.
Cheers!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 03:37AM |
SlowFoot
thevisad
Hi all!
Cheers!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 05:37AM |
Koenig
Hi there!
I'm a Swede as well.
I bought this kit as my first 3D-printer, if I had known then what I know now I would have sourced all the parts my self, but since it was my first and I had zero knowledge about 3D-printing I see as part of the learning.
I'm about half way through one roll of PLA (1kg) and about the same with one roll of PETG and still haven't got a real usable part from it yet...
I looked at buying a Velleman before I ended up buying this kit, maybe I did the right choice there atleast.
But half the fun is in tinkering and upgrading.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 07:30AM |
thevisad
There should be several questions asked before buying a kit. If you answer no to any of these questions then you should question your desire to buy, assemble and run a "kit" printer and instead purchase a pre-assembled unit. While they also have challenges, the level of these is completely different then the ones that arise in a "kit" printer.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 08:46AM |
EdwinCal
wrangellboy
EdwinCal
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 09:46AM |
fattmann
EdwinCal
wrangellboy
EdwinCal
I would definitely get a hold of Folger Tech, that is pretty bad. Much worse than my bent components and single broken pin.
I love how people so passively dismiss these defective/damaged parts as a fact of life. I feel for ya, hang in there. I think I'm up to 8 missing items and two broken, I'm nearly at the end and still discovering things. trying to get a full list to send to Folger Tech.
Good to know on the LCD screen support.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 09:48AM |
fattmann
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 09:59AM |
wrangellboy
For me it's not passive dismissal so much as impatience. If my choices are wait weeks for an RMA or fix it myself, I'm likely going to fix it myself. That said I'm debating contacting them now about a bad linear rail. One of mine sucks despite my best efforts to fix it and it consistently ruins prints by overheating the stepper and/or binding. The part price on the rails is too high for me to just suck it up and order a new one (not to mention Amazon doesn't have them...)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 30, 2015 10:01AM |
dc42
thevisad
Worth pointing out that several kits on the market come with pre-made leads that don't require any soldering or crimping, so electronic assembly is limited to fitting the controller board in place and connecting the wires. Also some kits don't require you to compile and install firmware from the Arduino program, either because they use controllers with firmware normally distributed in binary format, or because the controller board has the firmware pre-installed. So (1) and (2) apply to some kits but not others. (3) certainly applies to all kits, and (4) not only applies to all kits but probably to most ready-made printers too.
I like your Ikea test!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 07:19AM |
thevisad
For extrusion, you want to buy directly from Misumi. They will custom cut any size for you and give you price breaks on the overall length you buy. 2 pieces will be cheaper then 1, etc. Search the site for part number HFS5-2020-SIZEYOUWANTINMM (ie HFS5-2020-350 is 350 mm). That is series 5 20-20 which is what we use.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 07:51AM |
Koenig
thevisad
Would 350mm suffice to fit a 330mm bed?
I see it varies between the the different kits out there, Robotdigg (haver their corners) as an example uses 360mm but a 300mm bed, my thought is to fit a 330mm heated bed and a 300mm glass on top of that.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:03AM |
thevisad
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level July 31, 2015 10:19AM |
thevisad
wrangellboy
I am the same way, I have spares of most of the items in the kit, including blank 2020 and 1515 extrusion. So for me, it's pretty easy to just swap something out and contact the company to send a replacement. There are a few things you can do if you want to eliminate the rails. One is switch to these wheels (3 per plate minimum) and a plate on the 2020 extrusion. You can then mount your carriage to that and have the whole length of the extrusion to run up and down.
