Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 04, 2015 09:59PM |
fuubar67
The arm are cut to 230mm from center of eyelet to eyelet, The manual asked that the rails to be set 170mm from the bottom, checked that 3 times. The resulting Z height ended up to be 264mm, I can adjust that and see what happens.
I still have an issue that the software allows the soft end stops reach the corners even if the build area is circular. Is there a max bed radius setting?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 04, 2015 10:33PM |
tadawson
There is in 1.0.3 . . . not sure about the stuff Folger provides, since I walked away from it about 5 days in . . . but in the new stuff, at least, you set DELTA_PRINTABLE_RADIUS in the Delta section to set that limit.
- Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 04, 2015 11:57PM |
fuubar67
tadawson
- Tim
The folger tech version of firmware does not have the DELTA_PRINTABLE_RADIUS, they are using the soft end stops and the machine over travels, thinking it has a square work area. I'll start moving to later version firmware or try to configure version from repetier. I looked for revision of the FW but cant find anything in the source code.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 04:23AM |
thevisad
fuubar67
This is the section Tim is referring to above The radius is created autoamtically from all of the settings that you enter at this location. The location of your probe also makes a difference in what your build location is during the bed leveling routine. If you have your location off then it will try to reach a point it shouldn't. The picture should correspond to the X/Y coordinates of the z probe in relation to the settings in your firmware for the location of the z probe.
Also, this is described in the configuration manual located at the google drive in step 15 utilizing the Folgertech firmware.
[drive.google.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 05:52AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 06:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 08:50AM |
Sven.L
PS: why is the word "melborP" (read backwards) banned?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 10:06AM |
2004 LCD display controller with adapter for RAMPS 1.4 August 05, 2015 05:11PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 06:02PM |
Re: 2004 LCD display controller with adapter for RAMPS 1.4 August 05, 2015 06:56PM |
robodog
Hi
I've been using my 2020 for about a month now. No real problems other than errors in the installation documents. THEN, I tried to install the LCD display that I purchased from FolgerTech. I have not found any documentation on the display installation. I did use a flick from youtube (https://www.youtube.com/watch?v=wP0LlOF8z58) that led me to the proper way to plug the device into the RAMPS board as well as a hint about configuration changes that may or may not be required. I tried using the config changes suggested in the flick. No go. So I reverted back to the FolgerTech provided Marlin. As a result I have the following results:
With the PC to Arduino USB cable unplugged, powering up the Arduino gives me cooling fan rotation but no life in the display (as if not attached)
With the PC to Arduino USB cable installed, PC on, but the power supply for the printer off, I get the display illuminated, but with no display content. (Arduino not powered ???) The contrast pot works as expected.
With the PC to Arduino USB cable installed, PC on, power supply for the printer on, the printer works as it did prior to the installation of the display (Repetier controls the printer).
If you have that bit of knowledge that I am missing, I would really appreciate your assistance.
Bill
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 07:47PM |
Bert3D
Ok, I have to ask. The pictures here show small carriers running on a track/rail attached to the extruded aluminum. The pictures in the folger 2020 Kossel on ebay, and at the Kossell site, show wheeled carriers running in the groves of the 2020 extrusions. The folger site says nylon slider wheels. Which actually comes with this printer?
And which works better? Linear track, or wheeled trucks? I see both on delta printers, but most of the larger ones seem to have wheeled trucks.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 08:23PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 05, 2015 10:01PM |
fattmann
Holy shit. They just upgraded all the parts I've been having trouble with, AND drop the price? Talk about a kick to the crotch. They just gave me flack about asking for more T-nuts cause they shorted me.
Got it two weeks ago and I still can't get the damn thing to even move the motors...
Fantastic.
(yes i'm gonna whine and cry about it)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 12:14AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 04:16AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 08:19AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 10:18AM |
Sven.L
Hey, and it's me again! With the next problem:
Instruction:
Base and Top Corners
Slide the 300mm aluminum extrusion on to the T-Nuts, tighten the screws from the other side, the T-Nuts will swivel and lock in place.
Alrite, done. I tightened the bolts as much as possible, and as far as I was able to ensure when sliding the aluminum extrusion into the right place, the T-nuts are all at the right position, too. But still, some of the aluminum extrusions are able to move in and out. What's wrong? And how to solve? Are there spare bolts I can use or are the bolts counted and included to the exact number as needed?
Even worse: on attempting to fix them firm, a fine metal dust appears, and the result is that these bolts cannot be fastened anymore nor opened, as the hexagonal hole for the hex key is now too widened. The metal of these bolts appears as way too soft. Not a good quality. I have now even the problem to get those widened bolts out, in order to exchange them with other bolts. Any idea?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 12:46PM |
tadawson
Ironically, you can see the gap due to the corners being extruded wrong in thier photos . . . for those of you whonhave read my thread on that topic . . .
The good news is that they finally got rid of the crap extruder block thatbate bearings!
And myself, having gotten my rails smooth with nothing more than ample lube and use, I'm not sure I see the wheels as anything other than a downgrade . . . and not having the linear rails bolted to the frame (9 places each) will likely reduce the overall rigidity of the frame.
- Tim
frame rigidity is all depending on a few tiny bolts,by what I can see. |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 02:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 03:31PM |
SlowFoot
tadawson
- Tim
I have not read your post and I may very well end up with a set of the corners, is there a link that I missed?
And the bottom corners are splitframe rigidity is all depending on a few tiny bolts,by what I can see.
Well, making a few extra holes is not that hard I suppose and plates to cover the bottom rails would also help and look good too.
Cheers!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 03:38PM |
Sven.L
Instruction:
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 04:08PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 04:47PM |
Sven.L
Hi.
The T-nuts are all fitting, I made sure that. mentioned it before. :-)
I just think, because the nuts are made of cheap and too soft metal, it is not possible to really fasten them good enough. I will try to replace them with nuts of a better quality.
But my question now is, how many M3-8mm bolts are required for the construction of the Kossel 2020?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 04:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 05:04PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 05:06PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 05:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 05:17PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level August 06, 2015 07:37PM |
llamatrails
fattmann
It seems that the PC will only recognize the Arduino if I plug it in without the power supply running. Once the PC recognizes it, then I can plug in the power supply- is this normal?
If I have the power supply connected AT ALL Pronterface will not recognize it.
I have found your symptoms to be somewhat normal if your power supply is wired in backwards. Quadruple check that the polarity is correct. Then, check again.
Rick
tadawson
Any chance you are on the wrong thermistor port? There are three on tne RAMPS, and you are only using two . . . And is your MOTHERBOARD definition set to type 33? The RAMPS really does not have much on it to fail - it is mainly a pin fanout for the Arduino . . . and heater power control.
- Tim
echo: SD int fail
[ERROR] Can't write to printer (disconnected?)(serialException): Write timeout
