Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 10:37PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 10:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2015 11:58PM |
etSelection at /Volumes/Repetier-Host Mac.app/Repetier-Host Mac.app/Contents/Resources/Slic3r.app/Contents/Resources/lib/std/Slic3r/GUI/Tab.pm line 844|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2015 08:26AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 11, 2015 09:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2015 10:22AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2015 07:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2015 09:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 12, 2015 09:18PM |
ohecht
OK, thanks again. So I guess G29 runs the routine and makes all the adjustments based on the readings in one step?
I seem to be having issues getting the PLA to flow, especially at the beginning of the prints...the extruder keeps "skipping" a lot, I think. What are the variables I should be adjusting to get a consistent flow of material?
As I watch it print, it looks like the nozzle is getting pinched against the bed on one side of the print and preventing the material from flowing despite running the autolevel routine with each print. This is from left to right on a print that's only about 1.5 inches across. Is it possible that the bed is that warped or the settings are that far off?
That's definitely what's going on, but I have no idea how to adjust that. Here are some pictures to show the issue close up and relative to the scale of the bed. The nozzle is digging into the bed on one side of a very small print and so far from the bed on the other side that the filament is stringing along randomly, and all of this is right after running the auto-level routine.
I just ran the autolevel without a print, and here are the values I see in the Log Window...not sure how to interpret them, but they look all over the place for readings that I would expect to be pretty close together if they're all supposed to be the same measurement to the plate at different points:
< 7:56:09 PM: 0.927 0.927 0.927 0.557 0.885 0.885 0.885
< 7:56:14 PM: 0.510 0.510 -0.650 -0.933 -0.518 0.595 0.595
< 7:56:21 PM: 1.497 -0.245 -1.358 -1.728 -1.288 -0.173 1.775
< 7:56:28 PM: 1.395 -0.373 -1.375 -1.725 -1.310 -0.130 1.725
< 7:56:35 PM: 2.087 0.367 -0.633 -0.913 -0.540 0.575 2.387
< 7:56:40 PM: 1.782 1.782 0.780 0.475 1.002 2.047 2.047
< 7:56:43 PM: 3.000 3.000 3.000 2.742 3.250 3.250 3.250
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 07:45AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 10:03AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 03:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 03:45PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 03:47PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 03:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 04:19PM |
MakerFront
I don't see how it is of no use, the bed is fixed-mounted with no adjustments. This would provide the necessary offset for the bed being installed at a slight angle without having to make endstop calibrations.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 13, 2015 04:44PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 14, 2015 09:58PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 15, 2015 01:59AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 15, 2015 02:16PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 15, 2015 10:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 15, 2015 10:21PM |
Fozzie1410
Does anybody know where I can find a replacement for the push to connect coupling that goes into the top of the hotend? Mine won't grip the tube anymore. I'm having trouble figuring out what size this part is. I've asked the FolgerTech folks if they sell replacements, but no response yet. I'm sure they'll respond eventually, but I'd like to get up and running as soon as I can.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 15, 2015 11:53PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 12:40AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 12:46AM |
iceman62
Has anyone setup the 12864 LCD with the marlin firmware?
If yes can you share what is define in the sketch to get it to work?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 07:47AM |
Plasticmonkey
iceman62
I got my 12864 working by just un-commenting out the line below and installing the u8glib library in the arduino IDE...
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
but not sure if I am the best to give advice since I am still stuck on calibrating...
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 11:55AM |
Plasticmonkey
I have been trying for a few hours to get auto-home to work. I have quadruple-checked the wiring, cable stress, required lengths reflected in the firmware, etc but it always does X perfect, Y good ( when near the top) and then Z drops. I have tried inverting each axis (#define INVERT_Z_DIR) but it only helped the Y axis.
example: [www.youtube.com]
I followed the manual to the letter, but since this is my first printer build I am not sure what else to do. Any suggestions are very much appreciated.
Also, they forgot the auto-level switch but I followed the instructions as if I had one. If I want to disable, do I need to change anything in the firmware?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 12:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 01:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2015 01:41PM |
