Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 12:28PM |
FirmwareFool
It does, but it goes about 40 mm from endstops, not 20.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 02:20PM |
paul_delta
It's OK, it's actually 20mm that we set in Configuration.h in ENDSTOP_X/Y/Z_BACK_ON_HOME plus some margin that firmware calculates.
So, just follow the video and adjust your endstops using G28, G131, G132:
[www.youtube.com]
FirmwareFool
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 02:49PM |
FirmwareFool
paul_delta
[www.youtube.com]
FirmwareFool
Alright, I followed the video, but about halfway through, during bed height correction, my inductive sensor went beyond the bed and thus crashed the nozzle into the bed. I will try again, but what do you think the problem is? In the bed height correction window, I have the max x and y radius set to 80 and the min x and y radius -80 respectively.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 04:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 04:33PM |
FirmwareFool
The paper test went fine at x0 y0 z0. I got a z max length of 236.6. At each of the 3 points near the edge, the print head was too high, and couldn't reach the bed, so it seems I have a convex print bed, although I'm not entirely sure which parameters to change to account for that.
As an side, when Z probing earlier with G32 S2, I got a report of
9.19
9.63
8.34
So, those values are supposed to be close to each other, but they seem a bit far to me.
Should I send you my Configuration.h file?
EDIT: Also, why the hell do they call the the motors/towers X Y and Z? The axes are already called X Y and Z. Calling them A B and C would avoid so much confusion. Oh well.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 04:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 04:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:03PM |
FirmwareFool
I think the problem is something to do with what either Firmware, or RepetierHost thinks my bed size is. Maybe they are conflicting? I can't think of any other reason why my sensor would go beyond the print bed and lower than z0.
I mean no offense, but out of curiosity, is English your first language? Your wording seems a bit different to me.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:05PM |
paul_delta
Did you set your printer in Repetier host as delta? [forums.reprap.org]
Check you z-probe height in eeprom. You must set real probe height - G1 X0 Y0 Z5 and slowly do down by 1mm and then by 0.1 and write down the height when z-probe will trigger (red light).
FirmwareFool
No, English my even not second - third language and when I am in rush - it's just boring for me to construct Hemigway-style phrases
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:20PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:27PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:30PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:34PM |
FirmwareFool
Z probe height is set to 0.900
That is correct. I tested it. At z = 0.9 the z probe LED turns on
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 05:39PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 06:30PM |
FirmwareFool
That is correct too. Z max length is 236.6 and the paper is pinched a little bit at z0
Is there something else I should change?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 09:46PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 09:55PM |
FirmwareFool
Here is the image of the Bed Height Map report. It only measured around half of the bed in a chunk closest to the Y tower. Like I said, the min/max for X and Y were -30 and 30 for both
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 09:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 10:12PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 19, 2015 11:11PM |
FirmwareFool
OK, I ran it again. It was still in the same small chunk near the Y tower. I realized though, that you said something about Autoleveling enabled/disabled. My RepetierHost automatically enabled Autoleveling before I ran the Bed Height Map tool. So, should I shut it off right before I start it?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 20, 2015 01:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 20, 2015 01:34PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 20, 2015 02:01PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 20, 2015 02:08PM |
FirmwareFool
Here is a picture of the EEPROM settings so far. I'm not sure what to change about the endstops, or Delta Radius or the Z probe
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level December 20, 2015 02:15PM |
