Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 09:51AM |
Legrand
I work in a machine shop and just checked it against a gauge. It has an M6 X 1.0 thread.
capacitor
Does anyone know what the thread size is for the push in fitting on the Folgertech stock hotend.
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 09:54AM |
Legrand
If so, then yes, they're all the same, M6 X 1.0
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 09:59AM |
The one on my Extruder came with half of the blue clips broken off, so it doesn't hold the PTFE tubing in at all. They should be identical though, as they weren't labelled separately.Quote
capacitor
The blue clip came off of mine and I had to super glue the tube into the fitting for know and would like to make sure I order the correct size before I take it apart
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 10:50AM |
capacitor
Is that the one on the hotend. I know that's the size for the extruder but the one on the hotend looks like 1/8 npt to me. The threads are definitely bigger then the push in fitting on the extruder.
Legrand
capacitor
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 01:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 02:04PM |
EvilBetty
What can I look for that might cause the tilt and raise / lowering of the effector platform?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 02:11PM |
EvilBetty
On carriages, the smooth rods measure within .2mm of each other.
On the effector plate, the smooth rods measure within .4mm of each other.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 02:32PM |
paul_delta
EvilBetty
We have a tilt because of
1. diagonal rods are not equal
2. diagonal rods are not parallel
If one of screws on the effector/carriage is too tight - it may compress the plastic making this pair of rods not parallel. Double check that.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 02:41PM |
EvilBetty
They are not exactly parallel. They are 2-4 mm narrower at the carriages then they are at the platform.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 29, 2016 03:31PM |
paul_delta
Too much... you have to fix it using washers, etc.
PS: Probably carriages and effector were printed on different printers.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 03:35AM |
EvilBetty
paul_delta
Well that didn't make any difference. All widths between rods are now 52.0mm - 52.8mm.
I spent the last 2 hours measuring every angle, span, and joint and can't find any non-square surfaces or corners, and non-parallel rods or beams.
The rods are all within .5mm in length (screw head to screw head) and within .8mm in parallel.
The towers are all square with the base and top, and within .3mm of each other at all points from top to bottom.
The only way I can see something wrong is watching the effector platform tilt, and by printing.
The end stops are the same distance from the bottom, top, and bed.
I'm trying to print this to test.
[www.thingiverse.com]
But I can't even get the first layer to lay down at the outside of the bed.
The X-Y side will go very low in the corners, and normal in between.
The Z side will not be low enough, causing it not to stick to the bed.
On a normal print, it results in a bulge in that will eventually start striking the nozzle and cause the belt to skip and then skew the print.
The last thing I tried was running the Z tower end stop down 3mm. Didn't make any difference.
The nozzle dug in enough to catch the tape, screwing up the video I was trying to capture of it, but maybe it will help. If not I'll make another tomorrow.
[www.youtube.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 10:50AM |
EvilBetty
[www.youtube.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 12:05PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 12:49PM |
Captain_Tim
So I am finally getting at calibrating my Kossel after my move. Following the video that paul_delta provided a few pages back, I am at the step where you take the Build Surface Radius and get the 3 tower points by using COS() and SIN() with the tower angles. I got my angles, but my printer won't move to them. For example, my X Tower should be at X-78, Y-45. If I do this "G1 X-78 Y-45 Z10", it won't move. If I do "G1 Y-45 Z10" it'll move, but if I do "G1 X-78 Z10", it won't. So I assume that it's something wrong with the X axis, but I can move it to -77, it just won't go any higher. What seems to be my issue?
Also, separate issue, It seems that Y45 is closer to the edge of the build plate then Y-45, but about 10mm or so, what can cause this?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:06PM |
Arduino: 1.6.7 (Windows 10), Board: "Arduino Mega ADK"
sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
#include
compilation terminated.
exit status 1
Error compiling.
This report would have more information with
"Show verbose output during compilation"
enabled in File > Preferences.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:11PM |
Captain_Tim
Arduino: 1.6.7 (Windows 10), Board: "Arduino Mega ADK" sketch\libraries\twi.c:1:17: fatal error: twi.c: No such file or directory
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:24PM |
Captain_Tim
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:28PM |
Captain_Tim
So it's uploaded now, and I changed the values, but still nothing. Still can't move the X to -78
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:29PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:34PM |
Captain_Tim
Here is my EEPROM file.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:38PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:39PM |
Captain_Tim
paul_delta
Captain_Tim
Looks OK... Try to increase Max printable radius, let's say to 95.
After increasing it to 95 it seems to work well. Now to continue calibrating it I suppose
Thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 01:42PM |
paul_delta
PS: here is my google spreadsheet that helps to calculate coordinates:
[docs.google.com]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 30, 2016 08:09PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level January 31, 2016 09:59PM |
paul_delta
You didn't answer my question:
How did you calibrate your printer?
Did you perform a paper test - not only in the center of bed but near towers and opposite to tower points?
What I see is banal uncalibrated printer.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 06:26AM |
EvilBetty
I calibrated it setting the Z_MAX using the paper test, and then using the Auto-Level probe. It will fail the paper test at other points on the bed. (too high, too low)
The problem is, because the effector platform is tilting (like a pendulum would) through the x - y movement, The Z-Probe is higher or lower at spots outside the center of the bed.
I think before I can do anything else I need to figure out why this is happening. I went through and double checked the smooth rod lengths and parallel again. My next step is to make sure the everything is OK with the carriages. When I twist on the effector platform while it's toward y-x it wants to cant the Z carriage. Makes sense. There's no play in the carriages (having to twist pretty hard).
Other suggestions?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 09:04AM |
EvilBetty
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 09:18AM |
Captain_Tim
So when I get to the part of the video where I check and adjust the Horizontal Rod Radius, if the hot end doesn't reach the bed when Z is 0, do I add or subtract value from the Horizontal radius, or is it the Z max Height that I need to adjust?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 10:02AM |
EvilBetty
Other suggestions?
Legrand
Are you running a G29 (auto level) before printing?
paul_delta
I had the same tilting issue, spent days trying to level the bed using original probe mount and finally did everything manually using drill bit instead of paper. It gives more room for initial calibration than paper test. Forget about this shitty probe mount, save your time and nerves and calibrate your printer manually using dc42 calculator.
