Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 10:09AM |
EvilBetty
I may have to do that, but the probe seems to be working fine. The problem is the probe is tilting in relation to the print head. I'd like to get that fixed first.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 10:25AM |
paul_delta
EvilBetty
Good luck )) I still have some tilt but my prints are close to ideal. Especially after the probe mount I designed to get rid of offset : [www.thingiverse.com]
paul_delta
Yes. But you have to level your bed manually first to get it relatively flat. Than use this calculator to polish your values.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 10:32AM |
EvilBetty
So what process do you start with, to eliminate tilt from the platform?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 11:27AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 12:02PM |
paul_delta
Captain_Tim
So when I get to the part of the video where I check and adjust the Horizontal Rod Radius, if the hot end doesn't reach the bed when Z is 0, do I add or subtract value from the Horizontal radius, or is it the Z max Height that I need to adjust?
First, adjust Z height and endstop offsets in eeprom to get correct Z0 near towers. Then adjust your Z height in eeprom again to get correct Z0 in the center of bed. Then play with horizontal radius to put near-tower points in level with the center of bed - decreasing the horizontal radius to rise side points or increasing to lower them. The starting point - to increase/decrease the horiz.radius to value of height you need to rise/lower side points multiplied by 2.2.
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 12:55PM |
Captain_Tim
4. Check the points near the Towers and adjust the Horizontal Radius so the hotend passes the paper test when Z0. Increase the Horizontal radius to lower the hotend, and decrease the horizontal radius to lift the hotend.
I don't understand the last part though, could you explain it a bit better, if you could?
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 01:21PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 01:37PM |
Captain_Tim
Ok, so after I re-adjust the Z height after I do the tower offsets, then I move towards the towers and I then adjust the horizontal radius based on whether or not my it's not touching the build plate at Z0 or not? And the adjustment value is the height difference * 2.2?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 01:41PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 01:45PM |
Captain_Tim
Ok, so set Z height, check towers, set Z height, check Horizontal Radius, repeat. Got it. Then after this calibration, I should, in theory be alright with using the above mentioned calculator to help calibrate it. Lots of work, but it'll be worth it.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 01:46PM |
paul_delta
Captain_Tim
I think you may try to use calculator after first hor. radius correction.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 02:57PM |
paul_delta
EvilBetty
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 03:29PM |
spiffcow
paul_delta
EvilBetty
I tried out your probe and got great results by reducing my bed height in the EEPROM by 70mm to account for the probe height.. The problem was that it did not recognize the Z correction when fixed the Z height after dismounting the probe and refused to home. I tried a lot of settings trying to accept the probe "in place" with the correct Z height, but it kept slamming into the bed with G32 (G30 homed correctly though and accounted for the distance).
Any advice on firmware settings? I'm using the latest Repetier version (0.92.8 I think)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 03:31PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:10PM |
paul_delta
No, this is wrong way. You have to set z-probe height in Eeprom just once. Firmware will do all height calculation automatically - only during z-probe procedures.
I'm going to test 92.8 version soon and check how the updated bed leveling procedure works.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:15PM |
spiffcow
That's what I tried at first, but it seems that the bed height isn't being honored by the G32 command, but it is for the G30 command. Heh, looks like maybe I have some firmware hacking to do.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:18PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:25PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:27PM |
spiffcow
Thanks, please let me know what you find! I didn't see a download location for 0.92.6, but I'll look a little harder when I get home.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:37PM |
paul_delta
You can play with my configuration if you want, here is an archive of my 0.92.6: [forums.reprap.org]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:44PM |
spiffcow
Are your rods really 230mm? I built to instructions and came out with 240mm rods, and had concavity problems until I increased the firmware value to something around 260/160 for my rod length/bed radius. I *still* have concavity problems with that setup at the outer 15mm..
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:53PM |
paul_delta
spiffcow
Yes, 230mm. Earlier versions of manual recommended 230mm. Actually, It's too short - the printable diameter is only 158mm.
To fight concavity you have to adjust horizontal rod radius, not the bed radius. Set your real diagonal rod lenght, and play with horizontal rod radius. Here is the screenshot:
[attachment 71449 horizontal-rod-eeprom.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 05:58PM |
spiffcow
paul_delta
spiffcow
I tried that, but I get an "Invalid Delta Move" exception when the rod length setting in the firmware isn't increased to compensate.. I'm wondering if they're not taking into account the effector width. I used Repetier's configuration tool to set it up initially.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 06:20PM |
spiffcow
Also, I apologize, I meant rod radius earlier. I know bed radius isn't a factor in this (although possibly related to the invalid delta move problem?)
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 06:36PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 06:45PM |
Captain_Tim
When I move my effector to say X5 Y80 Z5 to check the Z tower, and lower the effector closer to the bed, it seems to jerk/slip as it lowers. What causes this and how can I fix this?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 06:56PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:03PM |
Captain_Tim
vRef is all good, and acceleration is only 100mm. Could it have to do with the arms? As it only happens on at the Z tower, when I'm testing the tower point. It would also appear that when the effector is at X0 Y0, it's not centered and is 6mm closer to the Z Tower.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:05PM |
paul_delta
Captain_Tim
May be your bed is off-center. Did you perform G131,G132 to get the real center before calibration?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 01, 2016 07:08PM |
Captain_Tim
