Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 02:36PM |
Sven.L
I cannot get anywhere those 2-pin connectors, I went to more than 15 shops earlier this day. But I purchased, in hope they can fit, these parts you see on the attached photo below. Let's see and hope, at least one of these two types can fit.
[attachment 72127 Photo7492.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:02PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:21PM |
Captain_Tim
Quick question, why is it that when I do a Height Map and set the Min and Max of both X and Y to 70 and -70 respectively, I can do the map no problem, but if I change the values to 80 and -80, it will scrap the bed as it checks the point.
P.S Just for show and tell, I've attached my height map for X Min: -70, Y Min: -70, X Max: 70, Y Max: 70 after I've gone through G29 S2 to add zCorr. It looks great to me, what's your thoughts on it?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:32PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:41PM |
Captain_Tim
With it set to 60 instead, this is the result.
7.69-4.52= 3.17mm height fluctuation across measured square...|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:49PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 10:55PM |
paul_delta
Captain_Tim
Looks like you didn't calibrate your printer at all7.69-4.52= 3.17mm height fluctuation across measured square...
For example here is one of my test heat maps, right after 15 min manual calibration and one DC42 calculator iteration.
[www.youtube.com] (look at results at 1:16 minute).
As you can see - the height fluctuation is 0.15mm across measured square. And this is not the best, actually.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 08, 2016 11:01PM |
paul_delta
PS: if you have standard FT probe mount with big offset from the nozzle - this is the results of effector tilt. As I said many times - FT probe mount is piece of junk. High probe offset on delta printer will never provide good calibration.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 12:44AM |
Folger Tech
For the needed sensor cable, you would use the 3pin Red,White, and black cable (...).
Following the wiring diagram, the white will be cut and taped as only 2 wires are needed.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 01:01AM |
Sven.L
I communicated with Folger Tech, and they told me to use the triple wire (white, red, black) to connect to the servo triple wire (orange, red, brown), and to cut off then the white wire, so only the red and black wire are connected to the switch. While the PDF manual speaks about a 2-pin connector, in reality it is a 3-pin connector and a white-red-black wire (not the black-red wire as mentioned in their PDF). With such wrong information, it is no wonder that I had all these problems...
But the resulting wire length of both the connected orange-red-brown and white-red-black wire is now 50 inch. Still wondering if that makes sense...
Folger Tech
[attachment 72143 Photo7493.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 01:31AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 01:50AM |
Sven.L
Folger Tech
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 01:56AM |
Gingerbreadman
I think I know what is going on with your wiring. That extra cable is intended to be cut. You use the small female end for connecting to your board, the other female end (the one in your pic is not used) First you strip back some of that thick black cable coming from your inductive bed sensor, then you solder the two resisters, I think 10k&15k ohm, between the black and the red (look at the diagram to be sure of that setup) , the white is not used and can be taped back the blue and brown run to your 12v power supply. Brown is + and blue is -. You use the small male end with its Frankenstein resistor combo to connect to the board with the white wire (check for sure it was late when I completed that step) to the outside facing away from the servos, it goes between the two end stop sensor connections . I was confused until I figured it out. My sensor lights up and senses the bed well with this setup. Hopefully my explanation will help you make sense of the folgertech wiring diagram, some of the trace lines are kinda muddy and difficult to read.
Sven.L
Folger Tech
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 02:05AM |
Gingerbreadman
Sven.L
Folger Tech
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 02:41AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 11:03AM |
spiffcow
I lost my resistors and decided to just try hooking all 3 wires up to the 5V next to the other endstop leads. Worked like a charm.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 01:49PM |
Gingerbreadman
Can I ask the merits of your method for connecting the Rev B induction sensor, besides sounding a lot simpler. Are there any relative drawbacks/compromises? Just looking for a better understanding. This was my first build and Im still stunned my printer didn't burst into flames (given my nonexistent arduino/ramps board skills) when I plugged it in. Thanks
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 07:15PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 08:57PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 09, 2016 10:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 03:51AM |
dc42
spiffcow
Is your calculator code available? I'm wondering what would happen if I just plugged 100+ points into it
It's written in Javascript, so you can view the source in your browser. The C++ source it is derived from is in my RepRapFirmware github repo.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 04:20AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 04:23AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 04:44AM |
dc42
The Javascript is derived from the C++ code that I added to RepRapFirmware, which is GPL.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 05:29AM |
Sven.L
I followed the instructions, and connected the white-red-black triple wire with its triple connector to the triple connector of the orange-red-brown wire coming from the servo, and also cut off the final last inch of the white wire.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 06:00AM |
Captain_Tim
Does anyone else find it hard to feed the filament into the extruder? This is my first Bowden setup, so maybe it's something I'm doing. I only managed to get it into the PTFE tubing by removing the push to fit connector from the extruder, as well as the PTFE tubing from the push fit. Then I feed the filament through the extruder gears and through the hole, manually thread it through the push fit connector, then add the tubing. Once I did that and pushed it all the way to the hotend, it didn't go any further either. Either 190C isn't hot enough, or it wasn't going in correctly. Any advice on this?
Also, my PSU's fan keeps revving up really high every like 30 seconds when I have the hotend and/or the bed heating. I'm assuming it's because it's getting warm with the power draw, but I just wanted to see if anyone else has this happening to them.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 08:24AM |
Legrand
The difficulty or ease with which you can feed the filament in will vary. Since the filament comes on coils and develops a circular "set", I normally have to bend the end a bit more straight before feeding it in. Many times I have to run it back and forth to get it past some edge of an internal part. That aluminum block by the extruder motor is the first problem. Maybe I'll design a funnel opening for it. Once the filament is in near the hot end, then it can get caught internally there as well. Again, feeding back and forth sometimes works, if not then you have to pop the Teflon tube off to help line it up.
As for your PSU fan, you're correct, that's normal as it heats up with the additional draw from the heat bed and extruder.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 12:31PM |
Captain_Tim
I'll give that a try later tonight, thanks.
Could someone help me to understand how to use dc42's calculator? I know you input the dimensions, but what do you do with the generated points to get the calculations? I've manually calibrated my printer, and everything is really close. I could do some more adjustments on the offsets, but for right now, it's ready to go, in my opinion. I'd just like to run through this calculator to get it even closer.
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 10, 2016 12:38PM |
spiffcow
For each suggested point perform a move to that point and then probe.. For example, 'G1 X86.6 Y50 Z40' moves to 86.6/50 on the X/Y plane, 40mm above the bed. Then perform a 'G30' to probe the point. Record the results in the calculator, and set the EEPROM settings indicated in the calculator. Be sure to read carefully regarding the sign of the Z error on the calculator. You may need to reverse the sign of the recorded value.
My suggestion would be to take your hot end out of the effector and install the probe in its place, and make a script for probing all the points. Keep running the script and inputting the values until you get a very small error, then put your hot end back in the effector.
