Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:25PM |
spiffcow
Also, I'd be happy to collaborate on this project if you're interested. Having active help increases the priority of this project for my free time allotment![]()
spiffcow
Does Repetier Host support plugins? If so I might do that.. Or submit a patch to them if they don't.
paul_delta
PS: I understand that serial communication is a piece of work... I think the best place for such calculator/calibrator- is the sub-menu in Repetier Host (right under Height map menu) that has all needed procedures to communicate with printer.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:26PM |
spiffcow
Awesome! That means minimal work to convert it!
I salute you, Captain Tim
Captain_Tim
I believe that Repetier Host does indeed support custom plugins, as This Site seems to point to them being made inC++ by my guess (would make sense to be C++ as Repetier runs on Windows, Mac, and Linux)C#, as the page says it's just a C# Library being used.
spiffcow
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:33PM |
paul_delta
Actually, I had 0.15mm using default drivers and just one shot of 6-factor dc42 calculatorHere is the video [youtu.be]
spiffcow
BTW, one thing I did during this process that made a *huge* difference was switch to DRV8825 stepper drivers. They're much quieter, double your step accuracy, and cost about $12 shipped for a set of 5. I received them after I had already done several passes of calibration, and the addition of the stepper drivers allowed me to go from ~0.25mm between the highest and lowest point down to ~0.15mm between highest and lowest. Well worth it IMO.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:43PM |
spiffcow
That's pretty good! I had to saw my carbon rods with a pocket knife, so I'm pretty certain there's a good deal of physical error in mine.
I was able to get a very small error in the dc42 calculator, but it fell apart once I added more data points. I once got it down to .05mm in the dc42 calculator, but when I actually ran G33 there were other points with a lot higher error. I think that's the big weakness in the dc42 web calculator, in that it just doesn't allow enough data points. It would be fine if you could assume the physical build is perfect, but that's an assumption that will never actually be true (at least not in my case).
spiffcow
BTW, your videos helped a lot in my initial build. I didn't realize that was you. Thanks!
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:47PM |
paul_delta
spiffcow
No, the only videos I published - is this one and two more with attempt to print at 120mm/s.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 01:52PM |
paul_delta
spiffcow
Does your probe have X/Y offset from the center of effector? Slight tilt and even small offset may cause z-probe values fluctuation across the bed.
I think 0.1-0.15 is the maximum we can get for this kind of construction because of many factors like slight backlash in joints, carriage rollers, etc.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 02:13PM |
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 02:35PM |
dc42
spiffcow
There is NO LIMIT to the number of data points you can use in the web calculator, if you are patient enough to wait for the computation to finish.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 02:51PM |
spiffcow
dc42
spiffcow
Apologies again, you are correct. I was looking at the directions in step 4, but did not try just setting a higher value.
Is there a significant delay with more points? My app is just a port of your code to C#, and calculation of 100 probe points is nearly instantaneous.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 03:45PM |
Captain_Tim
As a student completely my 3 year advanced diploma for programming, and a 3D enthusiast, I for one would be highly interested in helping out with this, if I had more time.
spiffcow
spiffcow
paul_delta
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 03:51PM |
spiffcow
I'll take a look at converting to a plugin this weekend and keep you informed. I might also look into converting their bed height calculator to use better points for delta printers (the whole grid-based height map doesn't really correspond to where you typically find errors for delta printers after all).
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 03:52PM |
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 03:58PM |
Captain_Tim
Do keep us informed. I for one am interested to see this type of plugin implemented, and it would be a life saver for a lot of people using Delta printers. After the basic plugin is made, perhaps auto-corrections to the EEPROMs could be the next feature. So when they start to probe the bed, it will take the height error and do the math, then ask the user if they'd like to "change the EEPROM values to the following: (List the new EEPROM Values)". That would really streamline it.
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 04:02PM |
spiffcow
Yep, that would be pretty awesome! You could just set it on auto-calibrate and stop it once it's as close as you want it. It would also allow testing targeted points for a settings change (e.g. test an angle correction based on the expected output of the previous data points to determine if it corrected the problem).
I'm getting kinda psyched about this project.
Captain_Tim
spiffcow
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 04:48PM |
spiffcow
[Is there a significant delay with more points? My app is just a port of your code to C#, and calculation of 100 probe points is nearly instantaneous.
spiffcow
Also, I notice there is a copyright notice now that I didn't notice before: "These calculators are COPYRIGHT Escher Technologies Ltd. Please don't steal them!" Does your previous statement (that the code is GPL) hold true? If not I will take down my app. Likewise if you personally would prefer that I remove it until I re-implement the calculations on my own. I mean no offense by deriving from your work.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 07:11PM |
dc42
spiffcow
I am happy for you to use and adapt the code if you acknowledge me as the source of the original.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 08:16PM |
Sven.L
Nebbian:
I am just not sure about anything. One the one side, Paul tells me that the probe has a cable going to the RAMPS and another cable goes to RAMPS from the switch. On the other hand, my manual says I need to connect the orange-red-brown cable (from the probe) to the white-red-black cable (with the cut-off white wire, from the switch). But that also means, that there is no wire at all going to the RAMPS. STRAAANGE!!! And there is no additional slot for any connection to the RAMPS. Could it be, that the manual of Folger Tech tells me wrong things? HEEEEEELLLLPP!!!!!
[attachment 72667 Photo7499b.jpg]
This is, how it is now, based on the Folger Tech instructions:
[attachment 72668 Photo7497.jpg] [attachment 72669 Photo7499.jpg]
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 08:28PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 08:43PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 08:51PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 16, 2016 08:54PM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 03:23AM |
): If you don't know what to do with your spare endstop, use it as a z probe: [www.thingiverse.com]|
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 06:24AM |
Gingerbreadman
Having problems when I run g29.
The head moves as though it is scanning the bed, in the x and y but steps up incrementally on the z until it hits the endstops at home. At that point I have to kill switch it or it will jam against the end stops.
I'm using repetier host v1.6.0, folgertech kossel rev b with the inductive probe, and the folgertech configuration rev.b file. I've set bed height and the z probe register correctly (lights up and shows in the log) . The g28 code works well, and the printer responded correctly when I ran a test calibration spiral print, though that was a sad print to say the least.
I'm sure I have wired or miscoded something since I am thrashing in the dark here and would like to preemptively apologize if the solution to this problem was offered earlier in this thread . My sad excuse for a 3d vocabulary hinders my search and comprehension of what little I have found and "understood"...thanks
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 06:32AM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 07:26AM |
Legrand
I'm having a problem where my print space is being limited somewhere to a square about 155-ish mm (~6in) and looks something like this (it's supposed to be printing a circle):
Can someone please tell me where this is happening? I have my print space (bed shape) set to circular in slicer with a diameter of 200mm, so this shouldn't be happening as far as I can tell... Is there something in the firmware limiting this?
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 08:09AM |
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 08:26AM |
Sir_Death
YES
P.S.: If you tell us what Firmware you are using, we might be able to help you... :-)
Legrand
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 08:49AM |
Sven.L
If my understanding is correct, I am short of one (un-cut) white-red-black wire.
Sven.L
To afford 14 to 50 US$ for shipping, it feels not so right, too, if the value of the cable is only 2 US$ and if a regular letter for 2 or maximum 5 US$ can do the job. In my private life, I do seed swaps with many people all around the world, and thus I know the prices of regular letters from the USA or Europe or Asia to Jamaica. And such a cable is not thaaat sensitive, it can be sent inside a regular letter.
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 09:14AM |
Anonymous User
Re: Folger Tech Kossel Delta 2020 Full 3D Printer Kit w/Auto-Level February 17, 2016 09:55AM |
Legrand
Sorry. Should have been more detailed.
I'm using the FT marlin firmware.
