Extruder design limiting speed? You bet. January 08, 2015 12:44PM |
Re: Extruder design limiting speed? You bet. January 09, 2015 11:34PM |
Re: Extruder design limiting speed? You bet. January 10, 2015 01:38PM |
Re: Extruder design limiting speed? You bet. January 10, 2015 05:44PM |
Re: Extruder design limiting speed? You bet. January 10, 2015 11:26PM |
Re: Extruder design limiting speed? You bet. January 12, 2015 12:33AM |
Re: Extruder design limiting speed? You bet. January 12, 2015 09:47AM |
Re: Extruder design limiting speed? You bet. January 12, 2015 01:13PM |
Re: Extruder design limiting speed? You bet. January 12, 2015 01:29PM |
Re: Extruder design limiting speed? You bet. January 12, 2015 03:09PM |
Re: Extruder design limiting speed? You bet. January 12, 2015 03:33PM |
hercek
Nice. Btw, I do not believe "no lash" is important for a bowden extruder. You get lash of about 8 mm in the bowden, so few tens of mm in the extruder itself does not matter.
Re: Extruder design limiting speed? You bet. January 12, 2015 10:07PM |
Re: Extruder design limiting speed? You bet. January 13, 2015 05:27AM |
jaguarking11
I am not sure where your getting 8mm of lash from. Can you enlighten me? I used to run 4.5mm - 5mm retraction with 1m worth of bowden tube.Quote
hercek
Re: Extruder design limiting speed? You bet. January 13, 2015 09:51AM |
Re: Extruder design limiting speed? You bet. January 13, 2015 12:46PM |
shadowphile
@jmf: I'm bummed too. I've been wrestling with this stuff since October. I finally got myself running at 60+ mm/sec but I'm going in circles trying to calibrate this thing, especially since I can't seem to get the auto-bed-leveling to work using G29 or G30 in either RichCattel or Johan firmwares.
I'm also running 3mm filament, which wasn't my choice and does not seem to be a good choice for a Kossel Mini either, the Bowden tube torques the effector too much.
My Bowden tube is a snug-fit (3mm) thick PTFE tube cut as short as I could get away with, about 18 inches. I did this to minimize feed friction. I also decreased my hob size (Mk 8), built a tighter filament hob-clamp, and put cooling fan on my extruder driver heat-sink. I was STILL having problems trying to inch my way forward past 10 mm/sec. When I jumped to 60, surprisingly it didn't fail in a steaming mess like I would have guessed.
But the key to getting from 10 to 60 mm/sec? I changed the retraction from 1.5 to .5 mm. If I release the hob on the extruder motor from the filament and push in in and out, I get about 1-2 mm play.
I would guess that you need at least that much + some amount to actually suck the molten tip back into the nozzle. At .5mm, I'm probably not doing any retracting at all. It doesn't seem to be hurting my parts much; I do get some strings I don't want. If the retraction is too much, it pulls molten PLA above the hot-zone in the heat-break, where it can't remelt and you end up with jammed hotend. Personally I don't see how this ever DOESN'T happen. One thought is that it is that at high speeds the actual melt-zone is further toward the nozzle and you can afford to retract further because when the filament slows down, the heater catches up and the molten threshold moves closer to the top end of the hot end and remelts anything that might have tried to stick to the walls.
In order to lower the sideways torque which I'm sure is causing all kinds of geometry errors, I put back the original tubing: FEP, about 2.5 ft, sloppy internal fit, maybe 4 mm? With that in place I can measure about 5 mm of play, MUCH worse. It means a lot more back and forth with my extruder motor and I'm now getting jams again, although I've been messing with everything including the version of software so who knows..
Re: Extruder design limiting speed? You bet. January 13, 2015 09:24PM |
Re: Extruder design limiting speed? You bet. January 16, 2015 02:56AM |
Re: Extruder design limiting speed? You bet. January 16, 2015 03:24PM |
Re: Extruder design limiting speed? You bet. January 16, 2015 07:53PM |
5:1 gear down is too much. You should try to find something smaller. I use 2:1 and retract speed of 200 mm/s and 10 mm retract. Works fine. It is good if you can get retract time below 0.1s.Quote
ChrisT88
I'm currently seeing 60mm/second retracts, have you checked yours to find your extruders limit? I usually run about 4.7mm of retract, anymore and I start seeing the width of seams increase on say a vase being printed without vase mode enabled increase.
Re: Extruder design limiting speed? You bet. January 16, 2015 10:28PM |
hercek
ChrisT88
Re: Extruder design limiting speed? You bet. January 17, 2015 07:00AM |
Re: Extruder design limiting speed? You bet. January 21, 2015 12:17PM |
