Re: MakerGeeks.com Mini Kossel Kit - Junk! May 19, 2015 04:31AM |
shadowphile
...For this reason alone I have seriously toyed with converting to 1.75, although that eliminates any possibility of flexible materials...
shadowphile
I have since realized that the standard 170 diameter plate is too small for many of my desires; if I have the patience (and cost of different parts), I would definitely move up to a 220 or bigger.
shadowphile
I am curious though how you worked out that the the electronics combo you mentioned (which comes with the MakerGeeks kit and NOT one of the issues I've had) is under-powered.
shadowphile
If I decide to just buy a working assembly how much can I expect to use it vs doing maintenance? Should I bother with a delta or stick with conventional cartesian? It seems like the biggest attraction for most people is 'It looks cool'.
shadowphile
Does anybody have suggestions about working out the jamming issues? That is the scary part for me because it is so hard to get feedback about what is happening. Either it is sticking to something, or the hole is clogging, or the filament flow properties have changed somehow. Trying to troubleshoot all three seems to reduce to: try,try, try! Maybe there is better forum or thread for this issue? It's not really delta specific.
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 19, 2015 06:09PM |
Dark Skunk
... I replaced the extruder mechanism with a more powerful one (it's a beast)...
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 19, 2015 06:50PM |
dc42
You can certainly get Ninjaflex in 1.75mm.
dc42
One of the nice things about the delta design is that you can easily use a large bed without having to worry about how to move it, or how to power the bed heater - you can use mains power and an SSR, without the safety concerns of flexing wires carrying mains voltage. I now have a 330mm bed with 300mm printable diameter. It has a 240V 350W silicone heater. The SSR for the heated bed and the 12V 100W PSU for the rest of the printer are under the bed. I'll publish more about this design in my blog (see link in my signature) when I have finished the conversion to 2020 extrusions and metal corners.
dc42
... metal corners should sort that out (you already have 2020 extrusions, so it is an easier conversion for you)...
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 20, 2015 01:29PM |
shadowphile
I also don't see any insulation under your heater pad.
Doesn't the overhead thermal plate cause a lot of heat build-up? I found some 1/16" inch cork sheet with adhesive at the local hardware store for lining shelves, and it is PERFECT for slapping a couple layers of thermal insulation on the bottom side of the heater plate. Despite that, there will still be heat build up, plus those hard-working steppers inside as well. I've been thinking about the need to force air through the space just to keep the steppers cool.
shadowphile
I looked at the RobotDigg parts; a full set of anodized vertex parts for $55? That is a no-brainer. Thanks for the reference! In fact I am looking at the metal carriages and their extruder mechanism as well. Alas, it would all ship from China. I've been leery of Chinese parts so far due to reputation of quality, although I know even Apple has their parts made there. I've been told that if you do some hard baby-sitting you can get quality out of China, but not as a default. I had a friend engineer who flew their several times to set up manufacturing and he was very under-impressed with their factories.
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 21, 2015 07:58AM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 21, 2015 10:10AM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 21, 2015 10:23AM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! May 30, 2015 02:35AM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! June 01, 2015 07:34AM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! July 13, 2015 10:02PM |
Re: MakerGeeks.com Mini Kossel Kit - Junk! July 13, 2015 11:15PM |
