Re: Anyone interested in a differential IR Z probe for deltas? May 09, 2015 08:50AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 09, 2015 10:41AM |
sungod3k
Im interested as well, since my cheap IR probe failed me on unreliable reflectivity across the bed. On what kind of surfaces have you tested this?
Re: Anyone interested in a differential IR Z probe for deltas? May 09, 2015 10:45AM |
dc42
sungod3k
I have tested it on plain glass, glass covered with Kapton tape, glass.coated with ABS juice, and BuildTak. I do not recommend using it on mirror glass, because the strong reflection from the back interferes with the weaker reflection from the front that the sensor detects. Likewise, if you have glass on top of aluminium then I recommend putting a sheet of black paper or thin black plastic between them, although it isn't essential.
Re: Anyone interested in a differential IR Z probe for deltas? May 10, 2015 09:55PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 11, 2015 02:35AM |
sungod3k
Ah great. As long as it works on paper or sprayed glass, or even the backside of a mirror Im all in. You maybe remember my thread from a few weeks ago with the unmodulated IR probe, which wasn't very reliable across normal paper.
Re: Anyone interested in a differential IR Z probe for deltas? May 11, 2015 02:07PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 13, 2015 05:22PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 16, 2015 07:35AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 16, 2015 01:10PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 16, 2015 02:24PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 16, 2015 05:46PM |
David J
More information than I expected!
That's excellent - the info will give me a chance to create something in openSCAD in anticipation of the board's arrival. I'll also draw up a cover to go over the top.
Re: Anyone interested in a differential IR Z probe for deltas? May 17, 2015 06:05AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 17, 2015 06:24AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 17, 2015 07:01AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 17, 2015 07:31AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 17, 2015 03:44PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 11:49AM |
dc42
I've made a firmware change and some component changes, in order to provide automatic switching between digital and analog output. After power up, the board now waits 4 seconds to allow the printer electronics to initialize everything, and then senses whether or not there is a pullup resistor on the output pin. If a pullup resistor is found, it provides a digital output that emulates a normally-closed microswitch. If no pullup resistor is found, then it provides a 4-level analog output, which Duet electronics can use to slow down probing as the target height is approached.
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 11:52AM |
David J
Z-probe received - small, isn't it!
dc42
Does this mean that in future, if I decide to fit one of these on my RAMPS-powered Prusa, I can just connect it up and go? Assuming that the config is set correctly of course!
Perhaps you should add this info to your mini-probe web page? And while you're in there editing, could you make the Duet wiring diagram a bit larger - or make a 'click-on-the-image' link to a larger diagram? My poor old eyes find the current diagram a bit of a struggle, and I've got a big monitor too...
Thanks for all your efforts,
David
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 01:57PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 02:43PM |
David J
Thanks Doug - same diagram, but a lot bigger!
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 03:43PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 04:29PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 04:56PM |
David J
David J
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 05:12PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 19, 2015 06:22PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 20, 2015 04:48AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 20, 2015 06:12AM |
David J
For PLA I used to use hairspray on the glass - I presume that the IR detector can cope with that? (no different to a smear of stick glue, I guess). ABS juice was also successful.
Re: Anyone interested in a differential IR Z probe for deltas? May 21, 2015 11:00AM |
dc42
BTW for anyone who has already received one with the new firmware, at startup it flashes the LED twice to let you know it is in digital mode, or four times to let you know it is in analog mode.
Re: Anyone interested in a differential IR Z probe for deltas? May 21, 2015 12:19PM |
Re: Anyone interested in a differential IR Z probe for deltas? May 22, 2015 02:07AM |
dougal1957
I just can't get to grips with Open Scad at all just totally aliegn to me but can do the majority/Basic stuff in Freecad maybe need to try and get to grips with Open Scad but finding the time is not easy!!
