Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 02:54AM |
Koenig
Have you made any more of these?
I have the 1.0 version of this already but I just bought a E3D v6 genuine and I don't think the earlier version will work with that and your fanshroud.
So I'm interested in a new one!
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 03:28AM |
dougal1957
Koenig
If you check DC$"'s Thingiverse link there are 2 STL's in there one for the V1.0 board and one for the 1.1 so you should be ok.
(I also have 2 x 1.0 boards but have yet to print the shroud as I have not quite got the 2nd Delta ready for it).
Doug
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 03:59AM |
Koenig
I have it wired to the duet, it flashes four times when starting up, but it doesn't trigger when going down.
If I put a piece of white paper on the glass I get it to trigger at ~Z=1.50, but if I remove the paper it doesn't trigger at all and the reading in the web-interface doesn't change either, the sensor reading stays at 0 all the way down until the nozzle touches the bed at Z=-0.1.
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 05:05AM |
dc42
Koenig
Sorry to hear you are having problems. Two questions:
1. How thick is the glass, and what sort is it?
dc42
2. When the nozzle is touching the glass, how high above the glass is the edge of the board?
dc42
I have about 4 version 1.1 boards in stock and another batch being manufactured next week.
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 06:46AM |
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 07:06AM |
Koenig
I'm gonna try redesigning my fanshroud so the board gets 0.7mm closer to the bed to see if that solves it.
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 07:08AM |
dougal1957
Koenig
Have you tried putting some Black Paper/Card underneath the Glass (This is what Dave recommends and I use successfully with the probe approx. 2.5 mm above the Nozzle) this is a much quicker test If you don't have any to hand just print a page of all Black (Use a paint package or something to generate a all black page)
Doug
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 01:24PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 01:31PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 01:41PM |
shadowphile
I had same problem with not triggering on glass.
I would try a flat black sheet of paper like construction paper. Permanent marker on glass is very shiny. He also recommended painting the aluminum plate, not the glass if I recall correctly. That should optically decouple the backside better.
But get the height correct first . Maybe make the mount adjustable? I also had to bend the IR component slightly as shown in his Z-probe blog.
BTW, I used a drill bit to physically measure the gap, better precision if you have a full set of bits.
Re: Anyone interested in a differential IR Z probe for deltas? September 06, 2015 10:52AM |
Re: Anyone interested in a differential IR Z probe for deltas? September 06, 2015 11:27AM |
Re: Anyone interested in a differential IR Z probe for deltas? September 06, 2015 04:30PM |
dc42
G32 and G30 use the M203 maximum speeds as the movement speed to the probe position, so you probably have the M203 values too high for your motors and/or the firmware. Try lower M203 values. Upgrading to my latest firmware (1.09j) may also help achieve high speeds.
autocal log
17:57:47M666
Endstop adjustments X-0.22 Y0.18 Z0.03
17:54:07M665
Diagonal 250.42, delta radius 121.02, homed height 463.72, bed radius 105.0, X -0.09°, Y -0.02°, Z 0.00°
17:50:59G32
Calibrated 6 factors using 10 points, deviation before 0.118 after 0.118
17:49:53G32
Calibrated 6 factors using 10 points, deviation before 0.120 after 0.118
17:39:56G32
Calibrated 6 factors using 10 points, deviation before 0.119 after 0.116
17:38:45G32
Calibrated 6 factors using 10 points, deviation before 0.156 after 0.115
17:37:48Connection established!
17:37:48Page Load complete!
manual cal
M665 R121.1 L250.42 B105.0 H463.66
M666 X-0.67 Y0.07 Z-0.35
Re: Anyone interested in a differential IR Z probe for deltas? September 06, 2015 05:54PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 12:27AM |
dc42
0.118 deviation after autocal isn't very good, you should be aiming for 0.05mm or less. The deviation could be caused by the trigger height varying with XY position. This is how I check mine:
1. Heat the bed and hot end to operating temperature.
2. Move the effector to one of the XY coordinates used for bed probing.
3. Lower the nozzle slowly, in 0.025mm steps to finish with, until the nozzle just grips a sheet of paper.
4. Send G92 Z0 to define that point as Z=0, and remove the paper. Optionally, use feeler gauges to measure the height of the edge of the sensor board above the bed.
5. Raise the nozzle to about 5mm, then send G30 S-1 to measure the trigger height. Repeat a few times to get an average. On my delta, the trigger height is reproducible to within about 0.01mm at a given point.
6. Repeat steps 2 to 5 to establish the trigger heights at the other probe points.
If the bed surface is reasonably consistent and the effector does not tilt with varying XY position, then the trigger heights should be the same everywhere. If they are not, there are a couple of possibilities:
1. The effector tilt is varying with XY position. This can be caused by the diagonal rods in a pair not being quite the same length, or the spacing between the bearings at the upper and lower ends of the rods being not quite the same. On my machine, there is a 0.25mm change in trigger height close to the Z tower, caused by a combination of a loose Traxxas joint and the sideways force of the Bowden tube acting in different directions at different XY positions.
2. Bed surface changing a lot between probe points. This could be because you have coated the centre e.g. with glue, but the edges where some of the probe point are have not been coated. Or one of the probe points places the sensor too close to the edge of the bed. Some glues and hairsprays affect the trigger height by around 0.2mm while other brands have little effect.
It's best to get rid of any trigger height differences if you can. For any that remain, you can use the H parameter in the G30 commands in bed.g to make a correction at each probe point.
HTH David
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 11:21AM |
dc42
HTH David
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 12:01PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 12:48PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 04:05PM |
web log
21:57:09M666
Endstop adjustments X-0.16 Y0.66 Z-0.50
21:57:03M665
Diagonal 250.42, delta radius 120.78, homed height 463.68, bed radius 105.0, X 0.43°, Y 0.01°, Z 0.00°
21:56:53G32
Calibrated 6 factors using 10 points, deviation before 0.019 after 0.011
21:56:08G32
Calibrated 6 factors using 10 points, deviation before 0.017 after 0.012
21:55:24G32
Calibrated 6 factors using 10 points, deviation before 0.015 after 0.009
21:54:41G32
Calibrated 6 factors using 10 points, deviation before 0.015 after 0.012
21:53:56G32
Calibrated 6 factors using 10 points, deviation before 0.019 after 0.014
21:53:13G32
Calibrated 6 factors using 10 points, deviation before 0.013 after 0.009
21:52:28G32
Calibrated 6 factors using 10 points, deviation before 0.017 after 0.005
21:51:43G32
Calibrated 6 factors using 10 points, deviation before 0.039 after 0.013
21:50:48G32
Calibrated 6 factors using 10 points, deviation before 0.244 after 0.033
21:49:56Connection established!
21:49:56Page Load complete!
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 04:34PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 07, 2015 05:44PM |
Koenig
Would adding more probe-points decrease the deviation further?
I only have a 220mm bed so perhaps adding another 3 points would be meaningless?
Re: Anyone interested in a differential IR Z probe for deltas? October 05, 2015 05:35PM |
G32 Calibrated 6 factors using 16 points, deviation before 0.027 after 0.027
Re: Anyone interested in a differential IR Z probe for deltas? October 06, 2015 04:34AM |
roboprint
David, what is your deviation for your printer with 0.9-degree steppers?
Re: Anyone interested in a differential IR Z probe for deltas? October 06, 2015 06:21AM |
Re: Anyone interested in a differential IR Z probe for deltas? October 06, 2015 06:24AM |
Re: Anyone interested in a differential IR Z probe for deltas? October 06, 2015 08:40AM |
shadowphile
David, doesn't the calibration fit a flat plane to least squares of the probe points? I got my large delta finished but my cal results won't go below about .13 St Dev. It seems like the results won't be good unless the physical accuracy is right on.
Re: Anyone interested in a differential IR Z probe for deltas? October 19, 2015 01:13PM |
X100 Y100 Z:0.6525 C:522 Y100.1 Z:0.6413 C:513 Y100.2 Z:0.6338 C:507 Y100.3 Z:0.6237 C:499 Y100.4 Z:0.6175 C:494 Y100.5 Z:0.6112 C:489 Y100.6 Z:0.6062 C:485 Y100.7 Z:0.6037 C:483
Re: Anyone interested in a differential IR Z probe for deltas? October 19, 2015 04:57PM |
Re: Anyone interested in a differential IR Z probe for deltas? October 20, 2015 03:37PM |
Re: Anyone interested in a differential IR Z probe for deltas? October 20, 2015 04:35PM |
