Re: Anyone interested in a differential IR Z probe for deltas? May 22, 2015 02:10AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 22, 2015 03:52AM |
Re: Anyone interested in a differential IR Z probe for deltas? May 22, 2015 11:20AM |
Re: Anyone interested in a differential IR Z probe for deltas? June 03, 2015 11:29AM |
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 09:03AM |
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 09:31AM |
dougal1957
Off Topic but from your Blog re large kossel you say your rods are 315 mm long is that center to center of the joints or the length of the bare carbon tube?
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 09:40AM |
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 02:38PM |
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 05:00PM |
sungod3k
In the video it seems to work well on glass...
Re: Anyone interested in a differential IR Z probe for deltas? June 04, 2015 08:12PM |
Re: Anyone interested in a differential IR Z probe for deltas? June 05, 2015 05:52AM |
Re: Anyone interested in a differential IR Z probe for deltas? July 25, 2015 04:31AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 09, 2015 05:04AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 09, 2015 05:31AM |
dougal1957
Dave
As I am not normally a Scad user can you post the Configuration.scad file and advise which parameters to change to alter the position of the effector mounting holes.
Looks like I will be needing a new board from you as well some time soon so I can use the design (Existing boards will prob get used on another printer)
Doug
// Main mounting holes
for (a = [60:60:359]) {
rotate([0, 0, a]) translate([0, 12.2, 0])
cylinder(r=m3_radius+m3VertExtraRadius, h=12.2, center=true, $fn=12);
Re: Anyone interested in a differential IR Z probe for deltas? August 24, 2015 05:00PM |
Re: Anyone interested in a differential IR Z probe for deltas? August 24, 2015 11:52PM |
Re: Anyone interested in a differential IR Z probe for deltas? August 25, 2015 03:17AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 27, 2015 03:31AM |
dc42
I designed a new E3Dv6 fan duct to mount it on:
You can find the files at [www.thingiverse.com].
Re: Anyone interested in a differential IR Z probe for deltas? August 27, 2015 04:22AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 27, 2015 11:29AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 28, 2015 10:36AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 28, 2015 12:56PM |
Re: Anyone interested in a differential IR Z probe for deltas? August 31, 2015 11:45AM |
Re: Anyone interested in a differential IR Z probe for deltas? August 31, 2015 05:41PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 01, 2015 08:48AM |
dc42
If you want to use the original E3D 30mm fan and duct, you could perhaps adapt this design [www.thingiverse.com].
Re: Anyone interested in a differential IR Z probe for deltas? September 01, 2015 11:43AM |
Re: Anyone interested in a differential IR Z probe for deltas? September 01, 2015 12:46PM |
David J
Hmm...
David, I think I owe you an apology!
I reverted to my old design, using the original E3D fan and shroud... and the filament is still jamming.
It looks like I have an issue with the hot-end itself. Investigations continue (and I'll stop clogging up this thread).
Cheers,
David
Re: Anyone interested in a differential IR Z probe for deltas? September 01, 2015 01:15PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 04, 2015 05:01PM |
Re: Anyone interested in a differential IR Z probe for deltas? September 05, 2015 01:36AM |
