Delta arms with traxxas joints February 18, 2015 08:20AM |
Re: Delta arms with traxxas joints February 18, 2015 08:34AM |
sungod3k
I just received my delta arms from tridprinting.com with traxxas joints and I see that the sideways motion of the joint is only about 30 degrees which is only enough to reach the the outer limits of the frame but isn't able to go further. This limits my print surface from 50cm diamter to 30. Is there an effector that adds another degree of freedom the joints or am I limited until I buy magnets?
Cheers
Re: Delta arms with traxxas joints February 18, 2015 08:54AM |
Re: Delta arms with traxxas joints February 18, 2015 09:05AM |
sungod3k
Im using parts of the cherry pi already, so I had this on my list but with this being my first delta I decided for the easier complete kit of arms, all glued and ready. This makes of course a good case for magnets for my next upgrade but for now im stuck with traxxas.
Re: Delta arms with traxxas joints February 18, 2015 09:36AM |
Re: Delta arms with traxxas joints February 18, 2015 11:50AM |
sungod3k
Re: Delta arms with traxxas joints February 18, 2015 12:05PM |
Re: Delta arms with traxxas joints February 18, 2015 12:33PM |
Re: Delta arms with traxxas joints February 18, 2015 12:40PM |
the carriage they are connected to should be is well above the effector, so the actual angle of the arms relative to the carriage and effector is less than 30 degrees
Re: Delta arms with traxxas joints February 18, 2015 01:10PM |
sungod3k
I dont think the vertical position changes the relative angle of the horizontal movement. Its limited to the same angle horizontally not matter where it is vertically.
sungod3k
In your foto is that the maximum position your arms can reach? If that is the case you could have a bigger bed if you had more reach right?
Re: Delta arms with traxxas joints February 18, 2015 01:28PM |
Re: Delta arms with traxxas joints February 18, 2015 02:30PM |
etfrench
The print area of a delta is not a circle. It's just convenient to make the bed round.
etfrench
In your diagram, it's not possible for the arms of the lower left tower to reach the effector position shown.
Re: Delta arms with traxxas joints February 18, 2015 05:04PM |
I disagree - it's entirely possible, unless the arms are too short. Bear in mind that the diagram is a 2D projection of a 3D structure.
Re: Delta arms with traxxas joints February 18, 2015 06:32PM |
sungod3k
... but if you take the rule of thumb that the arms are 3/4 of the triangle side, then the distace from one tower to the opposite triangle side is roughly the arm length. as here in my case
Re: Delta arms with traxxas joints February 19, 2015 02:24PM |
Re: Delta arms with traxxas joints February 19, 2015 02:57PM |
Re: Delta arms with traxxas joints February 26, 2015 10:47AM |
Re: Delta arms with traxxas joints February 26, 2015 06:45PM |
Re: Delta arms with traxxas joints February 26, 2015 06:58PM |
Re: Delta arms with traxxas joints February 26, 2015 07:26PM |
Re: Delta arms with traxxas joints February 26, 2015 10:05PM |
Re: Delta arms with traxxas joints February 27, 2015 04:16AM |
Re: Delta arms with traxxas joints February 27, 2015 01:39PM |
