Rostock Mini Pro Issues February 20, 2015 09:33PM |
Re: Rostock Mini Pro Issues February 21, 2015 07:16AM |
andychang28
Aside from that problem, whenever I try to home my printer, the carriages move up as they are supposed to, but once they have all reached the top endstops, they suddenly turn around and move down slowly for a centimeter or two. Then, they come back up at the same slow speed, and this time they stop when they hit the tops.
Finally, whenever the motors stop, (this includes homing, moving through manual control in Repetier, etc) they make a very high-pitched whining noise. I feel like they're still running but stopped at the same time.
My priority target for now is the fact that my printer does not seem to know when its hot end has reached the print bed. I have tried lowering the z axis length in my Configuration.h file, even going so far as to set it at 114 mm, but nothing seems to work. I have checked the EEPROM settings as well, and they are all set to 114 mm. However, the motors keep on pushing the hot end down into the print bed.
Re: Rostock Mini Pro Issues February 21, 2015 12:38PM |
Re: Rostock Mini Pro Issues February 21, 2015 05:36PM |
Re: Rostock Mini Pro Issues February 22, 2015 02:54AM |
Re: Rostock Mini Pro Issues February 22, 2015 10:40AM |
Re: Rostock Mini Pro Issues February 22, 2015 11:09AM |
Re: Rostock Mini Pro Issues February 22, 2015 01:43PM |
andychang28
I can make plastic melt and come out of the hot end by manually pushing it through, but if the extruder motor tries to do so it doesn't work. The extruder motor runs fine, so the problem must be somewhere between the motor and the hot end. I think calibrating the extruder motor might help this. Any advice?
Re: Rostock Mini Pro Issues March 01, 2015 11:34AM |
Re: Rostock Mini Pro Issues March 01, 2015 11:43AM |
Re: Rostock Mini Pro Issues March 05, 2015 01:40PM |
Re: Rostock Mini Pro Issues March 05, 2015 03:49PM |
Re: Rostock Mini Pro Issues March 05, 2015 04:43PM |
dc42
To fix that problem, decrease the delta radius setting in whatever firmware you are using. A good starting point is to decrease the delta radius by twice the excess height at the centre of the bed compared to the edges.
Re: Rostock Mini Pro Issues March 05, 2015 04:54PM |
Re: Rostock Mini Pro Issues March 05, 2015 05:18PM |
Re: Rostock Mini Pro Issues March 05, 2015 07:15PM |
andychang28
Just to clarify, I should be changing the parameter "DELTA_RADIUS", not "DELTA_MAX_RADIUS", correct?
Re: Rostock Mini Pro Issues March 05, 2015 08:36PM |
Re: Rostock Mini Pro Issues March 06, 2015 03:19AM |
Re: Rostock Mini Pro Issues March 07, 2015 09:17PM |
Re: Rostock Mini Pro Issues March 16, 2015 08:39PM |
Re: Rostock Mini Pro Issues March 17, 2015 06:07AM |
Re: Rostock Mini Pro Issues March 18, 2015 04:19PM |
Re: Rostock Mini Pro Issues March 18, 2015 09:39PM |
Re: Rostock Mini Pro Issues March 19, 2015 07:20AM |
andychang28
I've got a small fan that came with the printer, but I don't see any way that it could cool down the hot end. Why would plastic melting too high up be a problem?
Re: Rostock Mini Pro Issues March 23, 2015 08:34AM |
Re: Rostock Mini Pro Issues March 23, 2015 08:49AM |
andychang28
What I gather from these comments is that I need a fan for my hot end, or at least the gray area with vents above it. How much would this fan cost, and would there be any other way to keep the plastic cool?
andychang28
P.S. Is it possible that defective filament could be causing the white tube thing holding the plastic to pop out of the extruder motor housing?
Re: Rostock Mini Pro Issues March 23, 2015 09:59AM |
dc42
Normally, the extruder motor skips steps rather than forcing the tube out. So the pneumatic connector (or whatever else is holding the end of the Bowden tube) may need to be replaced, to hold the tube more securely.
Re: Rostock Mini Pro Issues March 25, 2015 07:41PM |
Re: Rostock Mini Pro Issues March 26, 2015 07:30AM |
Re: Rostock Mini Pro Issues March 26, 2015 08:45PM |
