Delta Printer bad prints - Part II (ABS)
Posted by Stephanel
Re: Delta Printer bad prints - Part II (ABS)
February 26, 2015 05:15AM
I have changed the PID settings, and restarted the printer from beginning. I input them in the firmware and ran the M301 command to make sure that the PID were loaded. Still however, the extruder temperature will not go over 240degC if I set the target to 250degC. It keeps on hovering around the 240degC mark...
February 26, 2015 07:36AM
Stephanel
Check your Configuration.h for the following lines and make sure you have enough headroom for the temp's
open | download - MLN Temps.JPG (30.2 KB)
