RichRap 3DR build - Electronics problem - SOLVED February 24, 2015 04:09PM |
Re: RichRap 3DR build - Electronics problem February 24, 2015 05:09PM |
Re: RichRap 3DR build - Electronics problem February 25, 2015 01:29AM |
Re: RichRap 3DR build - Electronics problem February 25, 2015 03:36AM |
Re: RichRap 3DR build - Electronics problem February 25, 2015 03:41AM |
Re: RichRap 3DR build - Electronics problem February 25, 2015 05:24AM |
Re: RichRap 3DR build - Electronics problem February 25, 2015 04:30PM |
Re: RichRap 3DR build - Electronics problem March 18, 2015 10:00AM |
Re: RichRap 3DR build - Electronics problem March 19, 2015 12:39PM |
Re: RichRap 3DR build - Electronics problem March 19, 2015 12:48PM |
OK, thank you very much, I'll try that, but what model of RAMPS are you using? (mine is 33, so RAMPS 1.3 / 1.4 (Power outputs: Extruder, Fan, Bed)Quote
zitman
HI Pablo,
Yes it was the motherboard setting but it did not work when I changed it to a numeric value I ended up using the following:
#define MOTHERBOARD BOARD_RAMPS_13_EFB
Hope that helps,
Z
Re: RichRap 3DR build - Electronics problem March 27, 2015 05:08AM |
Re: RichRap 3DR build - Electronics problem March 27, 2015 11:18AM |
Ok thanks. I've tried that too, but no result.... the smart full graphic controller is not working.... tried everything but .... blue backlightlight only....Quote
zitman
Sorry for the delay in replying. Yes #define MOTHERBOARD BOARD_RAMPS_13_EFB is defined in boards.h as 33. One thing I did find though was when I tried #define MOTHERBOARD 33 it didn't work!
Z
Re: RichRap 3DR build - Electronics problem March 27, 2015 02:07PM |
Have you installed the correct library in arduino ...u8glib ?????Quote
pabloevaristo
zitman
Z
Any other suggestion??
Re: RichRap 3DR build - Electronics problem March 27, 2015 02:40PM |
Yes, I've seen all tutorials out, search over the web, followed all the steps....Quote
bigfilsing
pabloevaristo
zitman
Z
Thanks friend, but neither google knowsQuote
bigfilsing
Google search is your freind
Re: RichRap 3DR build - Electronics problem March 27, 2015 11:12PM |
Re: RichRap 3DR build - Electronics problem March 27, 2015 11:45PM |
no pot in the back of my smart lcd (red pcb version ), there's only one in the front, but checked and nothing. I'll look for the contrast in Marlin.Quote
bigfilsing
Cables the right way round ??
Contrast pot adjustment on the back of the board
If i remember rightly there's a contrast setting in Marlin as well somewhere but ive never had to deal with it. Might be worth verifying as well
Re: RichRap 3DR build - Electronics problem - SOLVED March 28, 2015 12:01AM |
Re: RichRap 3DR build - Electronics problem April 03, 2015 04:13PM |
Re: RichRap 3DR build - Electronics problem April 04, 2015 05:22PM |
Re: RichRap 3DR build - Electronics problem - SOLVED April 04, 2015 05:40PM |
Re: RichRap 3DR build - Electronics problem April 04, 2015 09:11PM |
you don't have to include the u8glib, that's already done in the code. Only import the library.Quote
gregfuji
Problems with my 'full graphic smart controller'. I've tried everything, I think I'm getting close but still not working.
This is my compile error: "" Configuration.h:6:20: fatal error: U8glib.h: No such file or directory
#include "U8glib.h" "" I have put this file everywhere I can think of but it still can't find it. HELP
(also I have tried it with out the quotation)
Re: RichRap 3DR build - Electronics problem April 05, 2015 01:17AM |
gregfuji
