3DR issues. February 27, 2015 03:04PM |
Re: 3DR issues. March 03, 2015 01:49PM |
Re: 3DR issues. March 03, 2015 05:53PM |
Re: 3DR issues. March 04, 2015 01:20PM |
Re: 3DR issues. March 05, 2015 08:29AM |
Re: 3DR issues. March 08, 2015 08:26AM |
Re: 3DR issues. March 08, 2015 09:44AM |
j.smith1995
Okay new issue, rebuilt the printer at a larger size with gt2 belts instead of spectra line, Followed jay coutures delta setup guide and got it so that when z=0 the hot end just catches a sheet of paper on the bed at 3 points, one in front of each tower and one in the centre.
Well I did a dry run print and it jsut doesnt work out, it's high at the edges and crashes the bed in the middle despite being level when you input manual commands to move to xyz locations.
Not sure what I have done wrong but I really hope one of you do. I'm running repetier 0.92 now.
Thanks,
Smithy
Re: 3DR issues. March 08, 2015 10:26AM |
Re: 3DR issues. March 08, 2015 10:41AM |
j.smith1995
cheers for the reply, I discovered my error, for some reason I didnt set slic3r centre to 0,0, not sure how that causes what happened but after changing that setting it seems okay.
I had already calibrated the build surface to within a paper thickness, that link looks pretty useful,definitely bookmarking that for later use.
Movement still seems steppy but it is a lot better than it used to be.
Re: 3DR issues. March 08, 2015 11:38AM |
Re: 3DR issues. March 08, 2015 12:57PM |
Re: 3DR issues. March 08, 2015 01:40PM |
Re: 3DR issues. March 08, 2015 02:38PM |
Re: 3DR issues. March 09, 2015 03:20PM |
Re: 3DR issues. March 09, 2015 07:52PM |
Re: 3DR issues. March 10, 2015 02:30PM |
Re: 3DR issues. March 12, 2015 01:26AM |
