Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 06:55AM |
#define Z_PROBE_OFFSET {21.00, -9.0, -5.30, 0}
#define Z_PROBE_DEPLOY_START_LOCATION {0, 0, 30, 0}
#define Z_PROBE_DEPLOY_END_LOCATION {0, 0, 30, 0}
#define Z_PROBE_RETRACT_START_LOCATION {0, 0, 30, 0} // X, Y, Z, E start location for z-probe retract sequence
#define Z_PROBE_RETRACT_END_LOCATION {0, 0, 30, 0}
// Y axis carriage hits the endstop when it's 25 due to the Z probe offset
#define AUTOLEVEL_GRID 20 // (24) Distance between autolevel Z probing points, should be less than print surface radius/3.
// These are the offsets to the probe relative to the extruder tip (Hotend - Probe)
// X and Y offsets must be integers
// (-21.00, 9.30, 5.30)
#define X_PROBE_OFFSET_FROM_EXTRUDER 21.0 // KosselPro actual: -22.919
#define Y_PROBE_OFFSET_FROM_EXTRUDER -9.0 // KosselPro actual: -6.304
// Kossel Pro note: The correct value is likely -17.45 but I'd rather err on the side of
// not giving someone a head crash. Use something like G29 Z-0.2 to adjust as needed.
#define Z_PROBE_OFFSET_FROM_EXTRUDER -5.30 // (-17.25) Increase this if the first layer is too thin (remember: it's a negative number so increase means closer to zero).
#define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 1000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 100 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 2 //How much the extruder will be raised when traveling from between next probing points
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 07:10AM |
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 05:28PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 05:53PM |
patrickrio
Hi AndrewBCN,
Have you uploaded the files for that minimalist extruder? Have you tried it yet? Do you have a picture of it assembled???
Here is the one I was looking at:
[www.thingiverse.com]
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 07:06PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 07:22PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 07:43PM |
It's an optional stepper shaft key, based on a design by Marty Rice. Available on Thingiverse here: [www.thingiverse.com]Quote
patrickrio
what does the orange part do?
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 08:25PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 26, 2015 09:18PM |
Re: The Delta Steel, a slightly modified Delta-Pi April 27, 2015 11:01AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 05, 2015 01:08PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 05, 2015 03:51PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 05, 2015 04:17PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 05, 2015 04:37PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 06, 2015 09:20AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 06, 2015 05:11PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 06, 2015 05:37PM |
And I like the trigonometric formulas too.
Re: The Delta Steel, a slightly modified Delta-Pi May 07, 2015 05:49AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 07, 2015 06:28AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 07, 2015 06:51AM |
dc42
Andrew, can you confirm that your design is for 30mm fans?
RAWING-V5-SINK.jpg"|
Re: The Delta Steel, a slightly modified Delta-Pi May 07, 2015 07:52AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 07, 2015 08:14AM |
dc42
Thanks Andrew & Dougal. I think I have a V6. The current fan is 40mm but is mounted higher than in Andrew's photo, and the bottom of the fan is lower than in the photo. I'll try to adapt Andrew's design for the V6 when he publishes it. I'll also need to add something to mount the IR sensor on.
Re: The Delta Steel, a slightly modified Delta-Pi May 08, 2015 08:05PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 09, 2015 12:07AM |
janpenguin
I have one question. Does blowing cold air to tip of the nozzle improve printing quality?
Re: The Delta Steel, a slightly modified Delta-Pi May 14, 2015 12:21AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 14, 2015 12:57AM |
Re: The Delta Steel, a slightly modified Delta-Pi May 14, 2015 03:51PM |
Re: The Delta Steel, a slightly modified Delta-Pi May 22, 2015 07:39PM |
Re: The Delta Steel, a slightly modified Delta-Pi September 30, 2015 05:36PM |
