Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 03:00PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 03:20PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 03:26PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 05:24PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 06:19PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 14, 2015 06:36PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 12:20PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 01:49PM |
Dark Skunk
If I undo the spring and get the filament out of the way, it does go in first rotations without any issues. If I put resistance on the gear when it's turning (even two fingers simply putting pressure on the pinion, it will stop until I let go. I'm putting moderate pressure on it but nothing crazy.
Not sure if the motor is bad or something else. I've been considering a geared one but am not positive what it will take to mount it. I haven't gotten a single print off this machine yet. Kind of sucks...
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 02:45PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 02:56PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 03:05PM |
Dark Skunk
UPDATE:
So I think I know most if not all of the problem is. I didn't confirm the length that the extruder was 'extruding'. Maybe I missed that step. In any case, when I put in 2mm it's goes 30mm (based on pronterface input). That can't be good. Maybe the problem is that I'm simple forcing the crap out of the filament and the extruder.
I'm going to calibrate and see if it's works. Probably a small chance. Likely beat the motor up already. That's on me...
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 04:12PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 04:25PM |
6.3 steps isnt right...it cant be unless as pointed out you dont have micro steps enabled. Check under the stepper driver ....are all the jumpers installed ??Quote
Dark Skunk
I'm interested in your statement. I don't think I missed any jumpers. I do recall putting some on prior to putting the other board on top of it.
I just calibrated the extruder so now it's 1mm to 1mm. Still no luck though. It just won't extrude. I'm running 220 temp for PLA. Should be gushing I would think. 225 for the first layer. I have this now:
#define DEFAULT_AXIS_STEPS_PER_UNIT {94.1, 94.1, 94.1, 6.3} // ( Was {100, 100, 100, 450} Makergeek said 94.1176 for x,y,z and 92.3 for e)
I don't know....
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 04:48PM |
Dark Skunk
I just ordered the link below. Probably over priced but I don't know enough to do differently. I went with 3mm as the tube and presumably the extruder were designed for.
[www.ebay.com]
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 09:01PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 09:09PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 09:21PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 15, 2015 11:35PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 16, 2015 12:05AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 16, 2015 12:06AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 16, 2015 06:40PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 16, 2015 09:41PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 17, 2015 05:40PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 17, 2015 11:15PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 18, 2015 01:51PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 18, 2015 02:26PM |
well if thats the case that explains the extruder stepper stallingQuote
Dark Skunk
It is 11.9, NOT 119. so much lower. I will swap the stepper driver tonight with one of the others. I just ordered a back up in case that's the issue.
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 18, 2015 08:39PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 18, 2015 10:46PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 20, 2015 07:57PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 21, 2015 01:23AM |
