Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 21, 2015 08:53AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 21, 2015 09:25AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 22, 2015 12:25PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 22, 2015 04:49PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 22, 2015 05:31PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 22, 2015 05:35PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 22, 2015 08:31PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 24, 2015 09:19PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 24, 2015 10:48PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 24, 2015 11:01PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 24, 2015 11:16PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 07:00AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 07:18AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 07:38AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 08:42AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 08:45AM |
dc42
It may be a silly question, but have you checked that the hot end fan is working and turning the right way, i.e. blowing air over the hot end cooling fins?
If you can feed 3mm filament into your hot end and have it come out of the nozzle at least sometimes, then your hot end is designed for 3mm filament. If it was designed fort 1.75mm, then the filament wouldn't fit into the Bowden tube or the hot end.
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 09:19AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 06:24PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 06:54PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 25, 2015 10:10PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 07:46PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 07:57PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 08:04PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 09:06PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 09:31PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 26, 2015 11:37PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 27, 2015 04:31AM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 27, 2015 05:59PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 27, 2015 06:58PM |
Re: Kossel Extruder Motor: I presume it's blown? Best Alternative? March 27, 2015 07:04PM |
