Test print jittery head March 15, 2015 02:51PM |
Re: Test print jittery head March 15, 2015 04:40PM |
Re: Test print jittery head March 15, 2015 04:47PM |
Re: Test print jittery head March 15, 2015 06:37PM |
Re: Test print jittery head March 15, 2015 10:26PM |
Re: Test print jittery head March 16, 2015 01:01AM |
Re: Test print jittery head March 16, 2015 08:02AM |
Re: Test print jittery head March 17, 2015 12:19AM |
Re: Test print jittery head March 17, 2015 07:21AM |
Re: Test print jittery head March 17, 2015 08:33AM |
vreihen
Why not try Repetier firmware? The web-based config tool will build your config by answering questions, and from many people's experiences it is slightly less taxing on the limited 8-bit CPU resources.....
Re: Test print jittery head March 17, 2015 09:29AM |
Re: Test print jittery head March 17, 2015 10:09AM |
Thanks for the replyQuote
dc42
The jitter sounds like not enough CPU power to perform delta segmentation fast enough. The initial homing moves the head in the Z direction only, so no segmentation is needed. Marlin then fine-homes the 3 axes individually, so delta segmentation is required.
Even though you are not using a graphical LCD, are you sure the firmware isn't configured to drive one?
Personally, I would never run a delta printer with an 8-bit controller, although other people seem to get it to work as long as the board isn't also driving a graphical LCD. Modern 32-bit controller boards not only have enough processing power to run a delta printer much more easily, they also give you software control of stepper motor current, which makes getting the current right much easier. Some provide a web interface too.
Re: Test print jittery head March 17, 2015 12:11PM |
dc42
Personally, I would never run a delta printer with an 8-bit controller....
Re: Test print jittery head March 17, 2015 12:30PM |
AndrewBCN
What does the number of bits of the MCU have to do with anything?
Re: Test print jittery head March 17, 2015 01:20PM |
Re: Test print jittery head March 17, 2015 01:40PM |
dc42
Re: Test print jittery head March 17, 2015 01:48PM |
bigfilsing
Im not using an LCD panel at all and reducing the delta segments has no noticeable effect which leads me, somewhat logically, to think that while the symptoms of my issue are very similar
in nature im not experiencing the "typical" CPU problem.
What i found interesting was that when i increased the speed the problem remained just at a higher frequency. In itself not groundbreaking but if i was having CPU handling issues it should have
worsened considerably
Re: Test print jittery head March 17, 2015 03:01PM |
grat
The Azteeg X5 has a nice form factor, but until recently, has had no useful LCD options for my printer (Why Smoothie doesn't support the discountreprap smart controller is beyond me).
Re: Test print jittery head March 17, 2015 07:10PM |
vreihen
grat
I've been running an RRD GLCD clone with my Azteeg X5 Mini (V1.0) since last fall, and it most certainly *is* supported in Smoothieware if you roll up your sleeves and make your own adapter cables. Granted, it would have been nice if the Smoothie folks made an official adapter, but Uberclock has filled that void and I will have it in my hands tomorrow if the USPS doesn't let me down. The Google Deltabot group purchase cleaned Uberclock out of the adapters, so there may be a wait for the next batch. I would never expect RRD GLCD support on an Azteeg board, since they make the VIKI LCD interface.....
Re: Test print jittery head March 17, 2015 09:13PM |
grat
I didn't say GLCD. I said the smart controller, with the 4 line text display. For form-factor / aesthetic reasons, it's what I have on my Kossel Clear, and I've been told by Arthur Wolf, that while the pinout is the same as the GLCD, the code isn't, and no one has written it.
Re: Test print jittery head March 18, 2015 12:24PM |
vreihen
grat
I keep forgetting that RRD also made the LCD-2004. Is it a parallel LCD that might work with the Universal Panel Adapter?
Re: Test print jittery head March 19, 2015 09:09AM |
Re: Test print jittery head March 19, 2015 09:48AM |
bigfilsing
So ive tried a few more things
Different PC ( laptop) and USB cable in case communications were the issue = No change
Of course the feed back and conclusions above seem to point to the handling of delta segments so thinking back to my build i revisited the diagonal rod length again.
At the time i made carbon fiber rods with traxxis ball ends and made them 217mm long. I really cant remember why 217 but it was after considerable research on the net.
I think at the end of the day i wasn't absolutely sure so went with a figure i gathered from somewhere.
So to revisit it i have downloaded the openscad files and reconfigured the config to my build it tell me i should have diagonal rods of 204 mm
so my questions are is it possible that my 217 rods are the cause of the problem ??
Re: Test print jittery head March 19, 2015 02:03PM |
Re: Test print jittery head March 19, 2015 03:23PM |
Re: Test print jittery head March 19, 2015 03:55PM |
Re: Test print jittery head March 19, 2015 08:56PM |
Re: Test print jittery head March 19, 2015 09:05PM |
dc42
Is the judder at a constant rate, or does the judder happen more often when you move the head faster?
Before I converted my Mini Kossel to Duet electronics, I had it working with RAMPS/Marlin and I didn't get that judder - at least at typical printing speeds. The version of Marlin I was using is at [github.com]. You might like to try that version, after making any essential changes to the configuration file to account for differences between your Rostock and a Mini Kossel.
Re: Test print jittery head March 19, 2015 11:59PM |
Re: Test print jittery head March 20, 2015 12:23AM |
