Best hot end ? E3D, MK V-BV or Promotheus ?? March 25, 2015 12:42AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 25, 2015 02:57AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 25, 2015 06:40AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 26, 2015 03:16PM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 26, 2015 04:02PM |
Lerathel
Bigfilsing, is this an e3d clone ? I think it is from the nozzle shape are you satisfied with it ?
Andycart did you post detailed instruction how to fix the chinese e3d clone in another post ? I think I saw something like that but I cannot find the post anymore.
Im thinking of buying this nozzle :
[www.aliexpress.com]
Seem complete and come with the hard to find/costly push fit connector.
Seem good to you ?
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 26, 2015 06:12PM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 26, 2015 06:23PM |
Lerathel
Witch nozzle size do you favor ? For me, print time is not really an issue, its detail precision. I was going for 0.4mm or 0.3mm any advice ?
I will be ordering the e3d v6 clone tonight if I find nothing bad against it.
I would love to buy the original but the price difference including shipping is too high.
There is only china that offer me a shipping option below 10 $ Even ordering from Canada cost me more then that in shipping... (im from canada)
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 26, 2015 11:04PM |
Lerathel
Seem good to you ?
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 27, 2015 02:20AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 30, 2015 02:29AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 30, 2015 03:11AM |
AndyCart
You don't need to do too much to get a clone set up. First dismantle it to component parts. The threaded tube that joins the cold side to the hot side needs to have its ends smooth and exactly at 90 degrees. Same for the nozzle threaded portion. I use a fine file and emery paper. When you re-assemble make sure you wrap the threaded tube with PTFE plumbers tape to seal the threads. That's it really. I would also advise a 0.4 nozzle
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 30, 2015 06:18AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 30, 2015 07:50AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 30, 2015 08:51PM |
bigfilsing
The heat transition/conduction up the hot-end is stopped by the finned barrel with a fan blowing on it.
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? March 31, 2015 01:48AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 02, 2015 01:46PM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 04, 2015 07:33PM |
bigfilsing
The cynic in me says they are finally admitting to all the V6 jamming problems reported in their forums and going with a PTFE lined solution and selling the "combat copies" as a smoke screen.
bigfilsing
Couple of public school boys who think they are in an episode of "Foyles war" pretending to be engineers.
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 05, 2015 02:55AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 07, 2015 06:22AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 07, 2015 10:19AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? April 24, 2015 04:24PM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? November 28, 2015 02:24PM |
...and so it died.
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 06:31AM |
bigfilsing
The heat transition/conduction up the hot-end is stopped by the finned barrel with a fan blowing on it. Taping the heatbreak with teflon/PTFE is insulating it and preventing the fan from being effective IMO
Of course we are only talking about a minimal amount of conducted heat that " manages" to get past the thin turned section but still. I was under the impression that was the whole point of an "all metal" hot end
If anything, i think it would be better to apply thermal paste to the heat break section that screws into the barrel.
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 06:52AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 07:58AM |
bigfilsing
The whole point of the heatbreak ( or throat tube) being so small is to stop the heat traveling up the hot end assembly hence the transition area (on the E3D for example) being turned down to a minimal diameter so there is less material to conduct the heat. The aim is to keep the filament as solid as possible for as long as possible before it reaches the heater block and nozzle chamber.
Any heat that does ( inevitably) "creep" up the heatbreak ( throat tube) needs to be dissipated into the cool fin element and not into the filament. Hence applying PTFE to it will prevent the heat being dissipated properly and isn't in line with the principle working.
Considering PTFE costs a couple of cents im sure the manufacturers would recommend it if it were an advantage !!!!
The only thing i do during assembly is to apply a thin layer of graphite grease to help when it comes to dis assembly. Dissimilar metals ( SS & Alu) have a remarkable ability to bind together after repeated heat cycles.
Much like RC Nitro engines , a bit of care when assembling them can reap massive benefits when its time to strip them down
Good luck
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 08:55AM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 01:53PM |
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 04, 2015 08:18PM |
dougal1957
Just to add a little here I have recently purchased 2 more V6's from E3D and they are now supplied with a small sachet of thermal compound which should be smeared on the threads that screw into the Heatsink and NOT on the heatblock side.
HTH
Doug
Re: Best hot end ? E3D, MK V-BV or Promotheus ?? December 05, 2015 03:16AM |
bigfilsing
dougal1957
HTH
Doug
Interesting indeed. Is there any brand/ type of the paste ?? I wonder what the temp rating is and if it's a standard "CPU" type of paste.
