Starting with a Delta April 20, 2015 03:34PM |
Re: Starting with a Delta April 20, 2015 04:33PM |
Re: Starting with a Delta April 20, 2015 05:49PM |
Re: Starting with a Delta April 20, 2015 07:29PM |
Re: Starting with a Delta April 21, 2015 01:14AM |
Re: Starting with a Delta April 21, 2015 01:43AM |
Re: Starting with a Delta April 21, 2015 06:43AM |
Re: Starting with a Delta April 21, 2015 06:50AM |
Re: Starting with a Delta April 21, 2015 08:22AM |
dc42
I agree with your conclusions, except that the Duet is also a good 32-bit board for running a delta. Currently, it is the only board with firmware that supports fast single-iteration auto calibration (using a least-squares fit), and that supports segmentation-free delta movement.
However, you may not find a kit that has anything other than Arduino/RAMPS, so you may have to make do with that and upgrade later. Think3DPrint3D recently did a variant of the Mini Kossel kit with Duet electronics instead of Arduino/RAMPS for a contact of mine. However, an advantage of starting with a standard kit is that all the wiring looms should be pre-made and the right length, and so easier to put together and get working.
Re: Starting with a Delta May 08, 2015 03:57PM |
dc42
Re: Starting with a Delta May 08, 2015 05:04PM |
Re: Starting with a Delta May 08, 2015 06:21PM |
