RAMPS + Arduino set-up plan Question for K800 April 26, 2015 08:27AM |
Re: RAMPS + Arduino set-up plan Question for K800 April 27, 2015 05:51AM |
Re: RAMPS + Arduino set-up plan Question for K800 April 27, 2015 07:31AM |
Re: RAMPS + Arduino set-up plan Question for K800 April 27, 2015 09:28AM |
[b]D1, D2 - Diodes[/b]
These must be placed in the proper orientation. The band on the diode must be turned the same way as the mark on the board.
Definitely solder D2 in. D2, F1, and F2 are shown installed here.
D1 should only be installed if the 5A rail is powered by 12V. It can be omitted and the Arduino will be powered from USB. You will want D1 installed if you add components to print without a PC. To reiterate, D1 MUST be omitted if you are powering the 5A rail by more than 12V, or the power is not absolutely clean, otherwise you may damage your ramps.
