Building a Rostock Delta, need someone with experience smiling smiley
Posted by TehStranger
May 08, 2015 04:19AM
Hello all,
I am going to be building a Rostock Delta soon and I need to know exactly how many nuts, bolts and spacers I will be needing?
This is the exact build I am going for: [www.thingiverse.com]
Cheers.
Edited 1 time(s). Last edit at 05/08/2015 04:20AM by TehStranger.
Re: Building a Rostock Delta, need someone with experience smiling smiley
May 09, 2015 09:03AM
bump
May 09, 2015 10:47AM
Rostock is an old design. You are likely to get more help if you build one of the more recent derivatives, such as Kossel or Cherry Pi.
May 09, 2015 02:49PM
dc42
It's ok I found out everything I need. How does the Rostock differ in terms of performance compared to a Kossel or Cherry Pi?
May 09, 2015 05:00PM
Hi !
I have built 2 rostocks and been calibrating and modifying it for about a year, i might be able to help some.
the main thing i thing you should consider, don't build to high, and if you do, build it sturdy.
I built my first with print height about 400mm with only two wooden boards in the same direction, i should add another in the opposite direction so it wouldn't wobble.
Original joints in plastic caused some problem for me, on the outer regions the print got cramped together, got a post about it here on the forums
Changed to magnetic that is much more stable, but buy strong magnets, no china-crap, been there, done that smiling smiley
But i really like my printer and wouldn't choose another design, maybe kossel but still delta.
///Mats, Sweden
May 09, 2015 11:07PM
mrg78
Hi !
///Mats, Sweden
Thanks for the input!
I am buying 1 metre rods (1000mm) what does that translate to in build volume? Should I just stick to 762mm?
Also, do the wooden parts require a laser cutter or CNC machine at all?
Thanks!!!
May 10, 2015 03:28AM
Yeah, i used 1 meter rods as well, but since they stick out on each side you can just let the stick out even more on the top, and maybe cut them of if there in the way.
But if you build it really sturdy it may not be a problem for full 1 meter height, i guess.
It is pretty important to get the angles exact on the baseplate and top.
I printed the drawing on a A1 printer and drew from that on the board, put two boards together and used a band saw so they where exactly the same.
A friend of mine used a jigsaw to cut but it didn't turn out straight, I don't recommend using that.
May 10, 2015 03:29AM
mrg78
the main thing i thing you should consider, don't build to high...
///Mats, Sweden
TehStranger
Yes.
May 11, 2015 08:33AM
mrg78
AndrewBCN
mrg78
///Mats, Sweden
TehStranger
Yes.
Really sorry for the late reply, guys.
I bought the 1 metre rods and I'll see how it goes.
What voltage should the motors be set to?
May 11, 2015 01:51PM
What type of motor is it? (Data sheet will say something about the max current)
Also what type of driver do you have?
This is a nice guide, [reprap.org]
May 12, 2015 12:37AM
mikes3ds
I have Nema 17 motors and A4988 drivers
Links: [www.ebay.com.au]
[www.ebay.com.au]
Another question: In the Rostock bill of materials it says use PFA tubing for the extruder but I can only find PTFE, does it really matter?
Cheers.
Edited 1 time(s). Last edit at 05/12/2015 12:44AM by TehStranger.
May 12, 2015 01:39AM
Servo:
Rated Current: 1.2A (That is what the ebay site says; however, I like looking at the datasheet as well)
ITrip can be equal or lower than current rating.
Resistor
Rs=0.2 ohm (StepStick)
Vref = I_TripMax * 8 * Rs
Vref = 1A * 8 * .2
Vref = 1/6
Just follow a video or this on how to do it [reprap.org], its really easy.
[Deleted] Posted twice on accident
Edited 2 time(s). Last edit at 05/12/2015 01:40AM by mikes3ds.
May 12, 2015 03:45AM
mikes3ds
Servo:
Resistor
Vref = 1A * 8 * .2
Vref = 1/6
Can I adjust those separately or do they work off the current I set it to?
I'll watch a video soon to try and get a better understanding of it.
Cheers.
May 12, 2015 02:09PM
Just watch the a video, it will make since
