New firmware 1.09a-dc42 for Duet electronics May 17, 2015 05:11PM |
Merged in zpl's latest changes to Network and Print Monitor modules. DHCP and Netbios names are now supported (thanks RRP/zpl)
Added command M999 S4321 to unlock flash memory, reset and boot to BOSSA port (so you don't need access to the Erase button on the Duet)
Z dive height is now relative to Z probe trigger height and the default is reduced to 3mm. As before, you can use the M558 H parameter to adjust it.
Added experimental support (not yet complete) for an acoustic Z probe for delta printers (Z probe type 5)
Bug fix: when using a simple modulated IR probe, very high readings were occasionally read
Bug fix: on Cartesian printers, the firmware once again prevents Z homing before X and Y are homed, if the Z probe is used for Z homing
Various code tidying
Re: New firmware 1.09a-dc42 for Duet electronics May 19, 2015 11:14AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 19, 2015 04:49PM |
wayno complaino
Does this mean 1.09 has all of your fork included up to and including 1.04f?
Re: New firmware 1.09a-dc42 for Duet electronics May 28, 2015 10:02AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 28, 2015 01:29PM |
dougal1957
After running the Autocal routine will the M665 and M666 commands show the changes made...
dougal1957
... and what would be the effect of running it multiple times.
dougal1957
When you say the Z Height offset am I right in thinking that if I need to lower the effector by 0.5 mm from probe trigger point to get the sheet of paper right then I set my Z offset to 0.5 in the G31 command?
Re: New firmware 1.09a-dc42 for Duet electronics May 28, 2015 02:08PM |
dc42
dougal1957
Yes. However, the autocal routine tells you what changes it made anyway. If you are using the web interface, look in the log on the gcode console page. To see a more detailed view of what is going on, connect Pronterface and send M111 S1 P4 to enable Move debug before your run G32. Don't forget to cancel it with M111 S0 before you print.
dougal1957
If your Z probe gives reprodicible results, the calibration values shouldn't change significantly, unless they were a very long way out to start with.
dougal1957
Yes, that's how you tell the firmware at what probe height the probe reading crosses the threshold set by the G31 P parameter is (for any printer type, not just deltas).
Re: New firmware 1.09a-dc42 for Duet electronics May 28, 2015 02:56PM |
dougal1957
Thanks Dave
That confirms what I thought although the results I am seeing only give me the Endstop adjustment's and the total height.
dougal1957
...so for example if I set me Z Height to be 430 and it is actually detected as 417.xx then if I run the G32 again then it has a large offset for the dive so starts much higher up so.
dougal1957
Given this is it an idea to graft the results into the config.g file (Give a little) especially for the height parameter.
dougal1957
I will video the autocal routine later and then try and figure out how to upload it/attach the link to a post. The Mini sensor is very impressive and is repeatable in it trigger.
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 04:20AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 05:34AM |
Admin Registered: 16 years ago Posts: 13,874 |
dougal1957
How do I attach a Video to a Post
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 05:38AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 05:55AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 05:57AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 06:35AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 07:56AM |
dougal1957
Video of DC42 Autocal in operation
Takes all of 35 seconds to calibrate my Large Kossel
Auto Calibration Video
Doug
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 09:54AM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 11:32AM |
David J
dc42
Apologies for the poor quality, I'm not used to making videos.
A tripod is a wonderful device...
(only teasing)
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 11:55AM |
dc42
David J
dc42
(only teasing)
Yes, along with a device to pan the camera smoothly, a remote zoom control, better camera... and most of all, a better idea of what I should be doing! Time to google for tutorials on making videos I think.
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 12:14PM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 12:37PM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 01:18PM |
Error: Delta calibration error: 5 factors requested but only 3, 4, 6 and 7 supportedToo tired to figure out what I've done wrong.
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 01:23PM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 01:27PM |
asbo
I've set up my ir probe today, got the latest duet firmware from here and duet web control 1.06 from the Ormerod section. Is that the right web interface version DC?
asbo
When I click the Auto bed compensation button the print head whizzes around and then gives me this:Error: Delta calibration error: 5 factors requested but only 3, 4, 6 and 7 supported
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 02:51PM |
Re: New firmware 1.09a-dc42 for Duet electronics May 29, 2015 06:27PM |
asbo
How do you get those autocal etc buttons to show up on the paneldue?
Re: New firmware 1.09a-dc42 for Duet electronics May 30, 2015 06:51AM |
