Solving effector tilt on dual extrusion delta printers
Posted by dc42
June 03, 2015 11:46AM
In using my mini differential IR sensor board, I've become aware that it isn't easy to keep the effector perfectly level as it translates in the XY plane. Any slight difference between the lengths of the diagonal rods in a pair, or the spacing between rods in a pair at the two ends, will cause the effector angle to vary with XY position. There may be other factors I haven't thought of that cause the tilt to vary.
It occurred to me that varying effector tilt will also be a big problem when using a dual-extrusion head such as the E3D chimera. I have a dual extrusion Ormerod printer, and one of the issues is to prevent the non-printing nozzle interfering with the printing nozzle. Even if they are at exactly the same height, the non-printing nozzle leaves slight marks if it passes over filament that just been printed. With varying effector tilt, there will be times when the non-printing nozzle will be slightly lower than the printing nozzle, making the situation worse.
This led me to the following idea. Suppose we deliberately tilt the effector so that the non-printing nozzle is higher than the printing nozzle? Consider the following setup. The effector carries two nozzles, one offset from the centre in the +X direction, the other offset in the -X direction. On the Z carriage slider, we use a small servo, or two solenoids, or a voice coil, or some other mechanism to rotate the carriage by a few degrees about the Y axis, thereby changing the relative heights of the two diagonal rod bearings. This will in turn cause the effector to rotate about the Y axis, raising one of the nozzles above the other.
This approach could be generalised to more than two nozzles, but depending on the arrangement of the nozzles on the effector, it may be necessary to rotate two or all three of the carriages.
Re: Solving effector tilt on dual extrusion delta printers
June 03, 2015 12:07PM
dc42
Very interesting Idea that Dave.
Haven't a clue how it would be implemented particularly in the FW (But that's where you come in I guess) mechanically it would need for the tilting carriage's to pivot arround a center point between the rod fixingings whilst at the same time remaining pretty solid.
I suspect that if the towers lean at all (Apart from in line with their position) could also cause this effect.
Will watch this thread with great interest.
Doug
June 03, 2015 12:56PM
Rather than rotate the whole carriage, I think it would be better to use a horizontal lever at the top of the carriage, pivoted on a bearing at its centre, and with the diagonal rod bearings attached to the ends. There could be a solenoid under each end of the lever, so I can energise one solenoid or the other. Like this:
Edited 1 time(s). Last edit at 06/03/2015 12:56PM by dc42.
June 03, 2015 01:49PM
Dave
How would fine positioning work?
Could you use a High Quality Servo and use PWM to fine set the positioning something like a good digital servo with metal gears would have to have extremely good holding torque tho.
Like the concept tho but maybe a beam with F623 bearing's one from each side just to help hold lateral positioning?
Doug
June 03, 2015 01:55PM
dougal1957
Dave
Doug
I don't see that fine positioning is needed for just 2 nozzles, all I need to do is be able to select 2 different tilt positions (i.e. with the beam tight against one or other solenoid) and switch between them in a reproducible manner. Small solenoids are available cheaply from China - I already have a selection of them from when I was toying with the idea of a solenoid-deployed Z probe.
June 03, 2015 02:19PM
I've seen a revolving effector somewhere that turns like the lenses of an old microscope, that'll keep the unused hot end really far away buy mechanically challenging.
June 06, 2015 08:31PM
Spiderbot has Tilting Dual Head.
(http://www.spiderbot.eu/images/stories/rotatingdualhead.jpg)
Edited 1 time(s). Last edit at 06/06/2015 08:32PM by janpenguin.
June 07, 2015 02:56PM
July 03, 2015 06:15AM
Only just found this and it seems the perfect solution for a delta.....
RepRap.me Diamond
July 03, 2015 09:42AM
The trouble with multiple extruder single nozzle hotends is if you're not using all the inputs at once the melted plastic goes back up the side not in use and clogs it up.
July 07, 2015 10:09AM
why not mount the effector on a small slide or linear bearing and shaft and turn a solenoid on and off that pulls the nozzle up say 1/4". i realize your adding mass to the effector but you can get some pretty small solenoids. this is one reason i like the idea of the diamond hotend. 3 filaments into one nozzle and no nozzle drag at all.
July 11, 2015 06:42AM
this guy should be contacted:
[www.youtube.com]
I think this is a good solution towards the use of dual hotends on a delta!
and seems to fix the "second-hotend-oozing" - problem at the same time
Alex
July 11, 2015 08:25AM
I have a dual extrusion Ormerod and have never had a problem with oozing from the inactive nozzle, using PLA filament, 10mm retraction (the slic3r default), and 150C standby temperature. So I think I ll stick to my plan, which keeps the weight of the actuator mechanism off the effector.
December 15, 2015 12:54PM
dc42
Not to resurrect an old thread but as you know david I am obsessed with effector tilt. And during my googling process I found out that is what the spiderbot does. The dual head effector. One is tilted.
