Re: Feel lost June 30, 2015 06:06AM |
Re: Feel lost June 30, 2015 09:45AM |
Re: Feel lost June 30, 2015 10:21AM |
Re: Feel lost June 30, 2015 12:19PM |
Re: Feel lost June 30, 2015 01:35PM |
Re: Feel lost June 30, 2015 02:12PM |
Taz-dig
asbo,
I have no issue pushing the filament through, I can feel the back pressure though and I am concerned this hot end may not work for this machine.It does extrude, but it does it in a horrible fashion. I think due to the slipping on the filament.
LarsK,
I have a Chinese copy and have ordered a real one from E3dv6 to make sure this is not the issue. I have multiple nozzles and will open one up to .5 and one to .6 to test.I have tried both PLA at 215C and ABS at 255. I have gone as high as 265 with the ABS and 250 for the PLA, but just burned it at that temperature.I am also ordering a new hob to see if this is an issue as well.
I want to thank you for this information. It helps to hear from others that I am at least looking in the right direction.
Re: Feel lost June 30, 2015 07:11PM |
Re: Feel lost June 30, 2015 10:10PM |
Re: Feel lost July 01, 2015 04:51AM |
Re: Feel lost July 03, 2015 07:53PM |
Re: Feel lost July 05, 2015 03:26AM |
Re: Feel lost July 05, 2015 08:58AM |
Re: Feel lost July 05, 2015 09:17AM |
Re: Feel lost July 05, 2015 10:06AM |
Re: Feel lost July 05, 2015 11:58AM |
Taz-dig
I just printed this.The walls have separation in them. You can see the wall not smooth as well. Settings as follows,
.2mm layer height
20% infill
2600 mm/min on print speed
Re: Feel lost July 05, 2015 04:58PM |
Re: Feel lost July 05, 2015 08:50PM |
Re: Feel lost July 05, 2015 09:08PM |
Re: Feel lost July 06, 2015 03:24AM |
Taz-dig
another problem that may be causing this, If someone could throw there thoughts would be great. I checked the carriages and they move fine with no resistance. They are adjusted just enough to get the play out of the carriage but not over tightened. While checking the carriages, I have 2 magnets that the chrome is coming off. I have attached a picture. could this cause my printing issues?
Re: Feel lost July 06, 2015 06:45AM |
Re: Feel lost July 06, 2015 12:03PM |
Re: Feel lost July 06, 2015 01:50PM |
Taz-dig
ekaggot,
Doug,
I don't understand what you are trying to explain. The carriages are built with the magnets at the top of the carriage to get a higher build volume.
Re: Feel lost July 09, 2015 11:34PM |
Re: Feel lost July 16, 2015 10:45PM |
Re: Feel lost July 16, 2015 10:54PM |
Re: Feel lost July 17, 2015 06:05AM |
Re: Feel lost July 17, 2015 06:18AM |
Re: Feel lost July 21, 2015 12:40PM |
