Z-axis movement after homing
July 13, 2015 12:54PM
Hi everybody,
I am building a Rostock Mini Pro, so far the frame is finished, motors and carriage attached, electronics wired and firmware flashed. During the initial setup I found an issue in the manual movement, after homing the printer with the three endstops on top, I am not able to move the z-axis down with Repetier host. If I move the carriage down manually, I could move up and down in a certain range, x/y-axis is working as well. What I don't understand is, when I use Pronterface and perform exactly the same sequence, I am able to move the z-axis down after homing.
I am not sure if I messed something up with configuration (attached), but I used it nearly as provided on Github. Can anyone give me a little support on that? I'd like to stay with Repetier host where I drive my Robo3D with. Thanks
open | download - Configuration.h (32.8 KB)
Re: Z-axis movement after homing
July 16, 2015 02:08AM
After some further search how to debug the end switches, I found that is possible to manually move after homing IF I send a M114 command after homing. It seems that Pronterface is doing this automatically, while Repetier host doesn't. Is this behavior normal?
