Kossel Mini nozzle wont extrude, clog instantly, help ! July 16, 2015 09:25AM |
It's been more then a month since I'm stuck with this problem. Help would be appreciated.|
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 16, 2015 12:45PM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 19, 2015 06:22PM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 20, 2015 09:29AM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 01:47AM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 09:14AM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 10:39AM |
LarsK
Using thermal grease is symptom treatment - Not problem solving. If it worked as a quick fix then sure. But now you should try to find the root cause for your problems. Also if you have 130 degree on the upper part of the heat break you have a serious problem.
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 11:25AM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 12:07PM |
LarsK
If he has so high temperatures on his upper heat-break that it dries out any normal CPU paste then he has an underlying problem. Applying better and more sophisticated grease is symptom treatment. End of story.
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 12:29PM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 12:44PM |
Lerathel
After 3 day it started to automaticaly clog again. I think my cppu thermal paste with a max of 130 degree died. I could not find a higher temp solution. appart from an industial product rated for 1000 degree C, sold in 5 gal only... hahaha. $$$$$.
Look like I will have to spend a lot a money changing the thermal paste every couple days.
source for any thermal grease supporter 250 degree C ?
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 01:03PM |
LarsK
If you read my post above you will see that I present a good number of possible things to investigate.
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 01:22PM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 01:33PM |
Re: Kossel Mini nozzle wont extrude, clog instantly, help ! July 22, 2015 02:28PM |
