Z height for X, Y, Z does not match Center July 22, 2015 10:14PM |
Re: Z height for X, Y, Z does not match Center July 22, 2015 10:40PM |
Re: Z height for X, Y, Z does not match Center July 22, 2015 11:12PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 02:37AM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 04:44AM |
tadawson
Adjust "DELTA_SMOOTH_ROD_OFFSET" until it is correct. This is in Configuration.h, and unfortunately, is not in EEPROM, so will require recompile/reload to set.
PS:
Just looked it up . . . To lower the effector in the center, you increase the value. Start small . . . a little goes a long way . . .
- Tim
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:40AM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 02:50PM |
Koenig
tadawson
PS:
- Tim
You can use M665 to set it in EEPROM, no need to recompile.
From what I understand though, adjusting the radius does not rise/lower the middle, you will have to do a new endstop calibration (same if you choose to do it by adjusting the "DELTA_SMOOTH_ROD_OFFSET").
You can think of it like straightening out a curve where the center of that curve is represented by the center of the buildplate and Z=0.
Re: Z height for X, Y, Z does not match Center July 23, 2015 02:53PM |
MarkIngle
Thanks Tim! I have Z level on all points now! However I noticed my X carriage bottom out when testing height on the right side of the bed. I'll dig around for setting limits on print radius. Thanks so much for the help!!!
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:17PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:35PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:38PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:45PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:54PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 08:59PM |
Re: Z height for X, Y, Z does not match Center July 23, 2015 10:54PM |
Re: Z height for X, Y, Z does not match Center March 30, 2016 08:18PM |
MarkIngle
Paying attention to detail is so important!!
[attachment 58704 Probe_Ori.PNG]
Thanks for all of your help Tim!
Re: Z height for X, Y, Z does not match Center March 30, 2016 09:31PM |
