Koenig
TehStranger
dc42
Try reducing the feed rate in that G1 command. 8000 is rather high and may be difficult to achieve if your motor currents are not quite right. So try 3000.
I tried that already, same problem only it goes slower
Have you put correct length of the rods in configuration.h?
And/or correct steps/mm?
I have done the correct rod length but I have not adjusted the Steps per mm. I am now using this calculator: [
prusaprinters.org] I do not know which "driver microstepping" to select, I have StepStick A4988 drivers.
