New RepRapFirmware 1.09d-dc42 for Duet electronics July 31, 2015 07:54AM |
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics July 31, 2015 02:07PM |
First start after M665 and M666 filled with all params: 16:25:20 M666 Endstop adjustments X-1.30 Y0.58 Z0.72 16:25:19 M665 Diagonal 214.35, delta radius 105.08, homed height 236.29, bed radius 90.0, X -0.16°, Y -0.62° 16:25:13 G32 Calibrated 6 factors using 16 points, deviation before 0.059 after 0.047 16:26:25 M666 Endstop adjustments X-1.28 Y0.60 Z0.68 16:26:23 M665 Diagonal 214.35, delta radius 105.08, homed height 236.30, bed radius 90.0, X -0.07°, Y -0.88° 16:26:17 G32 Calibrated 6 factors using 16 points, deviation before 0.047 after 0.034 16:27:25 M666 Endstop adjustments X-1.27 Y0.53 Z0.74 16:27:24 M665 Diagonal 214.35, delta radius 105.09, homed height 236.28, bed radius 90.0, X -0.16°, Y -0.85° 16:27:19 G32 Calibrated 6 factors using 16 points, deviation before 0.048 after 0.043 16:28:30 M666 Endstop adjustments X-1.27 Y0.54 Z0.73 16:28:28 M665 Diagonal 214.35, delta radius 105.18, homed height 236.31, bed radius 90.0, X -0.12°, Y -0.95° 16:28:21 G32 Calibrated 6 factors using 16 points, deviation before 0.048 after 0.043 16:29:29 M666 Endstop adjustments X-1.25 Y0.52 Z0.72 16:29:27 M665 Diagonal 214.35, delta radius 105.19, homed height 236.33, bed radius 90.0, X -0.20°, Y -0.89° 16:29:22 G32 Calibrated 6 factors using 16 points, deviation before 0.056 after 0.052 16:30:29 M666 Endstop adjustments X-1.25 Y0.57 Z0.68 16:30:28 M665 Diagonal 214.35, delta radius 105.04, homed height 236.31, bed radius 90.0, X -0.17°, Y -0.88° 16:30:22 G32 Calibrated 6 factors using 16 points, deviation before 0.054 after 0.050 Reboot and start again: 16:31:59 M666 Endstop adjustments X-1.28 Y0.60 Z0.68 16:31:57 M665 Diagonal 214.35, delta radius 104.99, homed height 236.29, bed radius 90.0, X -0.12°, Y -0.82° 16:31:53 G32 Calibrated 6 factors using 16 points, deviation before 0.039 after 0.033 16:33:01 M666 Endstop adjustments X-1.28 Y0.55 Z0.73 16:32:59 M665 Diagonal 214.35, delta radius 105.09, homed height 236.29, bed radius 90.0, X -0.15°, Y -0.69° 16:32:54 G32 Calibrated 6 factors using 16 points, deviation before 0.051 after 0.044
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics July 31, 2015 04:01PM |
roboprint
Thank yor for additional M665 params. It is now possible to save calibration results and print without bed leveling.
Also, results of calibration is slightly differs, is it ok?
roboprint
Also, web-interface affects print on Duet+RepRapFirmware like graphic LCD affects RAMPS1.4+atmega2560. There is audible clicks every 250 ms (as web ui refreshes) then printer moving hotend from X0 Y0 Z230 to X0 Y0 Z1 with speed F15000. (my setting is 100 steps/mm). This clicks become hard to hear at F9000-F12000 speeds. Also, if something is printing and I go to settings page of web ui then printer pauses print for about 300-600 ms causing melted plastic blobs.
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 08:31AM |
M665 R105.08 L214.350 B90 H236.31 X-0.20 Y-0.98 M666 X-1.26 Y0.56 Z0.70 ; put your endstop adjustments here, or let auto calibration find them M92 X100 Y100 Z100 ; Set axis steps/mm M906 X1000 Y1000 Z1000 E700 ; Set motor currents (mA) M201 X5000 Y5000 Z5000 E5000 ; Accelerations (mm/s^2) M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min) M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 11:50AM |
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 04:33PM |
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 06:08PM |
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 06:19PM |
Re: New RepRapFirmware 1.09d-dc42 for Duet electronics August 15, 2015 06:23PM |
