Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 06:23PM |
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 06:31PM |
DRTak
#define DEFAULT_AXIS_STEPS_PER_UNIT {80, 80, 80, 100} // x 75 87.3 was my default but prints are 10.6mm not 10mm
#define DEFAULT_MAX_FEEDRATE {300, 300, 300, 300} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {1000,1000,1000,1000} // X, Y, Z, E max
I hope everyone elses looks similar?
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 09:15PM |
DRTak
Also, I noticed that I was not getting enough filament and my parts were kinda off. Small parts that is. Im trying to print LEGOs which are impossible.
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 19, 2015 11:23PM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 12:09AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 12:21AM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 04:46AM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 06:50AM |
o_lampe
slic3r 1.2.9 has known issues with perimeter gap filling.
Check the slicer-subforum for more.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 06:52AM |
Sir_Death
o_lampe
-Olaf
Da****! sh**! Piece of crap!
Sorry for these ugly words :-)
I'm new to 3D-printing, and this is my first printer.
Lost many hours the last two weeks (must be over 30 hours) just trying to get Slic3r 1.2.9 to work.
I might change to Slic3r 1.1.7 - but I think I don't want to see the bastard slic3r anymore.
(Little word joke - the german word for bastard sound phonetically simillar to Slicer... )
What do you think of Cura?
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 08:57AM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 11:58AM |
nebbian
More upgrades.
I was sick of my probe binding and not working properly, so made a piece of metal like this, with a piece of teflon tube inside it:
[attachment 64425 IMG_4751.jpeg]
It gets attached to the effector like this:
[attachment 64426 IMG_4752.jpeg]
It works quite well, no more binding, the guide really helps to keep the allen key where it should be. Now I just need to upgrade to the RC of marlin-dev to actually use the thing!
Someone smarter than me would probably use a 3D printed piece. But I am impatient, and had the aluminium handy...
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 01:14PM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 01:33PM |
dc42
You might also want to consider using my IR probe instead of the mechanical one. See [miscsolutions.wordpress.com] for details.
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 02:18PM |
I can highly recommend DC42's probe (I am just about to order a third one)Quote
hacker
dc42
Thanks, David, I'm already considering it for quite a while now. ;-)
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 03:01PM |
hacker
Keep calm and use all slicers. Cura, slic3r, kisslicer, mattersomething, you don't have to stick to one. I regularly get mad at the slicer I use and switch to some other then go back, etc. ;-) Also sometimes depending on the nature of the part you're printing you may chose different slicer. Embrace the whole wonderful world of slicers ;-)
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 04:03PM |
dc42
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 04:40PM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 04:49PM |
Sir_Death
Just gave Slic3r one last try.... Version 1.1.7
G-Code says: ; perimeters extrusion width = 0.40mm
Measured: 0.49mm
Never ever Slic3r 1.2.x anymore
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 06:16PM |
Re: Ebay SINTRON Kossel Mini full kit October 20, 2015 08:57PM |
dc42
You don't need to change Marlin at all to use the IR probe. Use the same firmware configuration that you would use for a normally closed microswitch, i.e. active high signal and pullup resistor enabled.
See the instructions I linked to earlier for what bed surfaces do and don't work with the IR sensor.
Re: Ebay SINTRON Kossel Mini full kit October 21, 2015 02:38AM |
DRTak
dc42
Ok. Im very interested but I have a silly question. I have always wanted to do the z probe auto deploy trick. Can this IR probe make that happened? Or how does it all work?
Re: Ebay SINTRON Kossel Mini full kit October 21, 2015 02:43AM |
theda1
OK being a Newbee to 3d Printing I have 2 questions to throw out there
1. Why blow air over the heatbed while printing ?
2. I managed printing without the Z Probe completely using bed leveling for fine tuning. Why is The Z Probe needed when a G28 Removes it.?
Re: Ebay SINTRON Kossel Mini full kit October 21, 2015 02:44AM |
theda1
Re: Ebay SINTRON Kossel Mini full kit October 21, 2015 02:51AM |
o_lampe
1. It's a compromise between no cooling and cooling the part with a fan attached to the effector ( which adds weight )
Re: Ebay SINTRON Kossel Mini full kit October 22, 2015 07:46AM |
nebbian
Re: Ebay SINTRON Kossel Mini full kit October 22, 2015 08:31PM |
GrAndAG
Actually, z-probe allen key should go through opposite hole in hot-end mount. I.e, in aluminum mounts this hole even has smaller diameter then others, and it definitely points on the fact that this hole is not for screw.
[attachment 64508 hot-end_mount_z-probe_hole.jpg]
If it still stuck (mine is not) you can drill this hole (in the mount and the effector) and insert PTFE tube there.
Re: Ebay SINTRON Kossel Mini full kit October 23, 2015 06:45AM |
Re: Ebay SINTRON Kossel Mini full kit October 23, 2015 07:46AM |
Sintron kit does have this part. It's slightly different in shape because it incorporates fan mount. But it still recognizable from the picture above. Here it is:Quote
hacker
But sintron kit doesn't have this part, does it?
Re: Ebay SINTRON Kossel Mini full kit October 23, 2015 07:49AM |
GrAndAG
hacker
[attachment 64575 sintron_hot-end_mount.jpg]
Re: Ebay SINTRON Kossel Mini full kit October 23, 2015 08:03AM |
