Ebay SINTRON Kossel Mini full kit
Posted by Miamicraft
Re: Ebay SINTRON Kossel Mini full kit
November 01, 2015 03:50PM
dc42
DRTak
So If I dont use an Arduino Ramps. How do I use my Kossel? What other system can run it.
Arduino/RAMPS has a number of issues, of which the lack of enough current from the 5V rail is the most frequently encountered. My recommendation is to use a modern 32-bit controller board such as Duet or Smoothieboard or one of their clones. These board are available from $50 + shipping including the drivers, although well-made ones not built in China cost more (just like Arduino and RAMPS).
For delta printers, I particularly recommend the Duet 0.8.5 which is available from Think3DPrint3D. It supports a fast auto delta calibration, segmentation-free delta movement, and a built-in web interface. See [miscsolutions.wordpress.com] for how I upgraded my delta from RAMPS to Duet. The calibration instructions in that series are out of date because it's completely automatic now if you have a Z probe.
If you want to spend less, you can get a Replikeo Duet 0.6 for $50 + shipping, although the quality seems to be variable.
If you want to continue using Arduino/RAMPS, see [forums.reprap.org] for how to work around the 5V power problem.
I second that, I got duet 0.8.5 from think3dprint3d and DC is my hero ;-) The only downside is that the printer is a bit louder now ;-) And I changed arduino/ramps that was working just fine for me, more or less all hardware/software problems resolved. Still, I'm a happier man now.
I'm thinking of upgrading the old i3 to smoothieboard now just for variety's sake.
November 01, 2015 04:16PM
DRTak
So If I upgrade to a duet then I have to buy your Panel DUE to get LCD function right?
It seems so, though I'd be happy to hear about something cheap and basic that I can use. Right now I'm fine without LCD, but would love to have one. I only want to see things, don't want to control from LCD, network is okay with me.
November 01, 2015 04:20PM
DRTak
Currently the only LCD supported by RepRapFirmware is the PanelDue. That's because when I sounded out Duet users about providing an LCD display, although I intended to do a low-cost mono graphics one, the overwhelming response I got was that folks would rather spend more and have a colour touch screen.
Alternatively, connect the Duet to your home network, then you can use a smartphone or tablet to control it via the web interface.
Edited 2 time(s). Last edit at 11/01/2015 04:21PM by dc42.
November 01, 2015 04:48PM
I've just finished initial calibration of the printer and ready to continue with melting plastic.
Now I have more generic questions because I'm warring about hot-end jams (maybe I can read that topics somewhere?):
- How to do very first print? Just push filament to the nozzle and kick print button in Pronterface? Or the nozzle should be preheated before inserting the plastic?
- How to retract the filament (i.e. for replacement)? Is it enough to put another filament after that without nozzle cleaning? Again, is it cold operation or preheated?
- How to abort the print in emergency and do not get the jam in the nozzle after that?
- If hot-end is heated is it must to extrude something or is it safe to have melted filament in the nozzle without extrusion?
- Could someone share Slic3r config.ini for this printer?
November 01, 2015 06:15PM
Heat hotend to 190 ish for PLA. Then you can manually push filament through to see if it works.
The lcd screen has a panic switch which u can use to kill the process. I use this all the time
To replace filament. Heat hotend. Manually pull out old filament once hotend is up to the correct temp. and replace with different color.
The printer is basically a CNC machine with a glue gun attached to it. So yes you always have to heat the hotend just like u have to heat a gluegun to get it to work
November 01, 2015 06:17PM
dc42
DRTak
DC. I think I'm going to have to buy your stuff. Lol. So the duet board. How do I input all of my config.h files from marlin into the duet? And do u sell your z probe on the think 3d website so i can buy everything at once
November 01, 2015 06:36PM
Hacker. Why is your kossel loudER now with duet?
November 01, 2015 06:38PM
DRTak
I'd love to hear expert opinion myself. I attribute it to the lack of segmentation for now — after all it affects how it moves and therefore the sound it produces, but I'd love to hear expert opinion.
November 01, 2015 06:46PM
hacker
DRTak
I chalk it down to the fact that they have implemented the "decay hack" on the drivers.
November 01, 2015 10:46PM
If the printer is louder since uograding to the Duet, the most likely explanation is that the motor currents are set higher. I haven't heard that the decay change makes any difference to noise when using A4982 drivers.
November 02, 2015 04:08AM
dc42
That was my initial thought, but I didn't notice any change after changing currents both up and down. But it was all kinda "while I'm at it", so unless I dedicate some time to this issue, it's not conclusive.
November 02, 2015 04:17AM
dc42
I run mine at lower current with the duet than what I did with ramps and a4988 and 8825's, it's still louder + it got a different "singing" to it.
I have never modified any driver with the "decay" hack so I wouldn't really know what the difference in actual sound may be, that's probably why I chalked it down to that.
November 02, 2015 05:35AM
talking about currents... i just realise ive never even adjusted those. just plugged the drivers in, and started moving the printer. Is there a guide on how to find the best current for a delta printer and set the drivers accordingly? I dont even know what a too high a current or too low even does (except for frying your steppers, or overheating the drivers)
November 02, 2015 06:35AM
Tha_Reaper
You should adjust the current of your drivers to about 70-80% of your motors rated current but you should not exceed what your drivers can handle without overheating.
There's a "guide" in the wiki, try searching there by the name of your driver.
Do take note that you also have to look at your sense resistors to get the math correct.
(the Chinese manufactured driver-boards sometimes uses different resistors than what is mentioned in the wiki)
November 02, 2015 07:24AM
For the axis motors, set the current high enough so that you can get the acceleration you want, but low enough to minimise the damage caused if you get a gead crash etc. This will typically be between 50% and 80% of rated current, a higher percentage for short motors than for long ones. Too low a current may also cause the motor not to respond to jogging by small amounts sometimes.
For the extruder, set the current high enough to not skip steps during normal extrusion, but low enough to skip steps if the nozzle is obstructed, to avoid grinding a notch in the filament.
November 02, 2015 07:43AM
BTW... Sintron's guys sent me replacement parts which could match their large rod ends. I've received definitely larger belt clips (for roller cars) and rather the same effector plate. Rod end mounting hole on belt clip is moved to 1.5mm farther from carriage. But regarding the effector... I noticed the only change - it's 38.5-38.7mm (instead of 40mm) between mounting points for rods. In the same time belt clips are 40mm in width. So rods wont be parallel after mounting.
The original parts are on the left, the new - on the right (in each pair).
[EDIT]
With new effector rods can be spread wider, but they still interfere. Beside that the minimum angle is also increased a bit, that's not good.
Edited 5 time(s). Last edit at 11/02/2015 10:08AM by GrAndAG.
Anonymous User
November 02, 2015 09:50AM
GrAndAG
BTW... Sintron's guys sent me replacement parts which could match their large rod ends. I've received definitely larger belt clips (for roller cars) and rather the same effector plate. Belt clips mounting hole moved to 1.5mm farther from carriage. But regarding the effector... I noticed the only change - it's 38.5-38.7mm (instead of 40mm) between mounting points for roads. In the same time belt clips are 40mm in width. So rods wont be parallel after mounting.
[attachment 65137 Sintron_larger_parts.jpg]
Got the same replacement parts to. - Useless.
I used 4mm spacers made out of a plastic plate for the carriage-parts and did my own effector out of Aluminium slightly bigger in size, but the same spacing as the carriages.
If you don't have the same spacing, the effector gets tilt and you won't be able to print correct dimmensions and angles!
EDIT:
Here you can find pictures of mine and the construction drawing for my effector (Forum is in german):
http://www.fingers-welt.de/phpBB/viewtopic.php?f=14&t=42&start=975#p107980
Edited 1 time(s). Last edit at 11/02/2015 09:53AM by Sir_Death.
November 02, 2015 10:02AM
GrAndAG
BTW... Sintron's guys sent me replacement parts which could match their large rod ends. I've received definitely larger belt clips (for roller cars) and rather the same effector plate. Rod end mounting hole on belt clip is moved to 1.5mm farther from carriage. But regarding the effector... I noticed the only change - it's 38.5-38.7mm (instead of 40mm) between mounting points for roads. In the same time belt clips are 40mm in width. So rods wont be parallel after mounting.
[attachment 65150 Sintron_effectors_comparison.jpg]
I didn't want to wait for them to ship, but wanted to try their original design first, so I printed out their STLs on the other printer. Indeed I could print, but the radius was like 50-60mm, so I went for traxxas rod ends…
November 02, 2015 10:05AM
dc42
Speaking of currents and other things, does anyone have *numbers* for this particular kit? Like, Olaf, have you got a config.g with nice currents, speeds, acceleration values, etc. values that are probably applicable not just to your assembly?
November 02, 2015 06:34PM
Today I did very first print. It works! Here it is the 1x1x1cm test cube:
The bottom layer is a bit junky because the filament was just inserted and the extrusion was not started at very beginning.
But why the corners are round a bit? Is it normal?
And it seems it over-extruded (but I calibrated extruder precisely: 100mm requested - 100mm got).
The settings was: PLA @ 200C, layer 0.3.
[EDIT]
And after the print I got a thin straight solid thread of plastic 20cm long from last printing point to the nozzle. Not enough retraction at the end? Or wrong temperature?
[EDIT2]
How to eliminate plastic threads while head is moving from object to object without printing?
Edited 2 time(s). Last edit at 11/03/2015 03:12AM by GrAndAG.
November 03, 2015 04:20AM
GrAndAG
[EDIT]
[EDIT2]
I too have a bit rounded corners. Not as round as you. metbe your temp is too high, or overextrusion, that way there is too much filament being forced out on your corners.
So far i print my PLA at 190 deg first layer, 180 for the other layers. crazy low, but it gives me good results.
both the edit problems are because of oozing. you can battle that by using a fast retration of 5-6 mm at 60-100 mm/s ive read. didnt get around to testing those settings myself. 4mm retraction @ 40 mm/s still gives me a lot of oozing and stringing.
November 03, 2015 04:25AM
Sintron offered me a new PSU. I dint expect that. the service is really incredible for a HK seller. I asked if they could send a 20A version, and they agreed for 10 dollar more.
Good deal, good service. parts quality may not be premium grade (as should have been expected for this price), but i'm still happy i bought this set.
Anonymous User
November 03, 2015 05:06AM
Tha_Reaper
More important is the ammount of power, the RAMPS is eating away from the heatbed.
Inputvoltage 11.97V Output RAMPS for Heatbed 9.46V - RAMPS gets very hot!
I don't want to discuss things with sintron anymore - just try to use a relay for heatbed and a PC-Powersupply (360W on +12V available)
But I have another strange behaviour:
I'm printig PLA with Nozzle 0.4mm
Layerheight 0,2mm
Hotend Temp 215°C (less temperature I won't get strong parts) - Temperature checked is 212°C
I can only achive 15mm/sec - seems much to low for me.... trying more Speed, extrudermotor jumps back - it can't push the Filament faster because it won't melt fast enough...
did the volumetric Speed test - only 1.3mm³/sek - read somewhere it should be over 5mm³/sek
So what are your values?
Edited 1 time(s). Last edit at 11/03/2015 09:12AM by Sir_Death.
November 03, 2015 06:32AM
Sir_Death
Tha_Reaper
Layerheight 0,2mm
Hotend Temp 215°C (less temperature I won't get stron parts) - Temperature checked is 212°C
thanks for the heads-up. I have never noticed the RAMPS to run very hot, but i only heated the heatbed to 60 degrees for PLA. Have not tried ABS yet before i can put stronger fans under my heatbed and i have kapton tape (painters tape probably wont like it if i heat the bed to 90 degrees for an extended amount of time. Anyone tried printing without any type of tape or adhesive on the bed by the way?
about the extrusion problem: maybe the current is set too low on the extruder, causing it to skip steps? just guessing, i dont know jack about currents and what the right current would be...
If you tell me how to perform the volumetric test, i will gladly try it and report the results back.
November 03, 2015 08:36AM
Sir_Death
I'm getting good prints at 60 mm/s, at 0.3mm and 0.1mm layer heights in PLA. 210 degrees first layer, 200 thereafter.
Have you adjusted the motor driver currents? You stick a jewellers screwdriver in the little trimpot, and measure the voltage between the screwdriver and earth, while slowly nudging the screwdriver back and forth. Mine is set to 0.45V.
I found that I also had to wind the extruder spring tensioner right up, almost to the stop. Otherwise I was getting grinding of filament occasionally. This would show as occasional thin strings where it should have been a continuous flat sheet. Took me ages to figure out what was going wrong.
For ABS you don't need the extruder tension as high, but I just leave it there because I'm lazy.
Anonymous User
November 03, 2015 09:10AM
Tha_Reaper
Description of Extrusion rate = volumetric Speed (Name of the Parameter in slic3r)
http://www.extrudable.me/2013/04/18/exploring-extrusion-variability-and-limits/
I'm printing directly on the Sintron-Heatbed - works perfect.
nebbian
Sir_Death
I will do measurement of the Voltage/Current again.
Seems there are different types of PLA out there
http://reprap.org/wiki/PLA#Heater_Settings
some melting at 160°C some at 230°C....
Have to check back at distributor, which value is suitable for the Filament I bought....
My Extruder is not grinding away the filament, Stepper-driver ist jumping back with "Clonck, clonck, clonck,..."
Anonymous User
November 03, 2015 10:17AM
Sir_Death
Answer from the Distributor already here: I should use about 220°C smiling bouncing smileysmiling bouncing smiley
So my Printer seems to work already...
Anonymous User
November 03, 2015 03:36PM
nebbian
Sir_Death
Checked Motor driver current - perfect fit.
Increase Hotend temperature to 220/225/230°C - only more stringing, but not more extrusion....
I think, I'll use the Filament as it is, and maybe with next Filament, things get better...
November 03, 2015 04:34PM
Sir_Death
Did you check if there is a jam in the nozzle and (possible) in the heat breaking tube? Overheating PLA can lead to jams.
BTW. I print PLA @ 200C (all layers) with bed @ 45C on blue tape. With 0.2mm layer it prints just perfect. Printing speed - 60mm/s, infill - 120mm/s, movement - 400mm/s.
Anonymous User
November 03, 2015 05:22PM
GrAndAG
Sir_Death
Nozzle was free before printing - could see through. PTFE tube is down all the way through heatbreake - there was a Problem after building the printer, so I had to disassemble and reassemble it, therefore I'm sure, how it is assembled now.
