Ebay SINTRON Kossel Mini full kit
Posted by Miamicraft
Re: Ebay SINTRON Kossel Mini full kit
November 10, 2015 08:58AM
Thats what i tried in the first place. And this also worked for me the first time I had to unmount the noozle. Anyway, fortunately the parts and even the whole printhead is rather cheap. Maybe I should order also another one as spare, just in case.
November 10, 2015 09:15AM
MrPCatt
Indeed, it's got clogged pretty early whether through the fault of mine or not, but it was kinda indication that it will be more problematic, so I didn't spend too much time on it, just put it aside (still lies around) and was happy to replace it with e3d hotend.
November 10, 2015 06:37PM
hacker
Bigkahuna2187
Haha "home" button in the GUI. I will double check but it appears everything is setup correctly according to the diagrams.
Thanks
I figured that, but couldn't resist ;-)
There are many diagrams around and although I'd expect them to be the same and show all motors the same way, you can just compare your X-motor wiring to Y and Z which move in the correct directions. You can often reverse the connector for X and Y motors, but you can't reverse sintron-supplied connectors for Z axis. And the only way you can plug Z in is actually reverse, so I had to reverse direction in firmware. But then again all my motors were moving in the same direction, so it does sound like you did flip one of those…
Here is video I took of the issue. I tried inverting with "true" under #define INVERT_X_DIR but that doesn't work. All my wiring appears correct. It looks like it starts going up but then begins to go down as the others hit the end stops.
[www.youtube.com]
Wiring:
November 10, 2015 06:47PM
Bigkahuna2187
hacker
Bigkahuna2187
Thanks
[www.youtube.com]
Wiring:
This is beyond me, it actually starts moving in the correct direction but halfway it looks like it gets some mechanical problem, some obstacle, maybe rods interferring with each other, but then at the end it seems to be indeed moving the wrong way… Maybe someone more experienced will give you a sound advice, all I can suggest is that you lower the speed and try looking closely checking for mechanical issues…
And yes, your wiring looks like they should be moving at least in one direction unless you specifically invert a single axis in firmware.
Edited 1 time(s). Last edit at 11/10/2015 06:49PM by hacker.
November 10, 2015 07:19PM
Looks like I had a bad stepper drive. Good thing the kit came with an extra!
November 10, 2015 07:21PM
@Bigkahuna2187
That could be a defect endstop, or endstop cable or noise on the endstop line.
The carriages go up until they receive a endstop hit. Then x starts to back up a short distance, tries a second touch, can't find the stop a second time, stops again (because the second move towards the endstop is only 1.5 times the backward move). Then things begin to go completely wrong. Have not analysed this completely but i guess the tower coordinate system is messed up in that case.
November 10, 2015 07:52PM
Bigkahuna2187
Meaning you got it working?
November 10, 2015 09:13PM
hacker
Bigkahuna2187
Yes everything is working properly now. Glad it was an easy fix.
Now, when homing, are the carriages suppose to hit the endstops and stay or are they suppose to go down some?
Edited 1 time(s). Last edit at 11/10/2015 09:14PM by Bigkahuna2187.
November 11, 2015 03:18AM
Bigkahuna2187
hacker
Bigkahuna2187
hit and stay, unless you manually set endstop offsets with M666.
November 11, 2015 04:42AM
Tha_Reaper
Bigkahuna2187
hacker
Bigkahuna2187
But after minute or so, drives go to idle mode and endstops have enough force tp push carriages a bit down. So, usually, when you hit print, printer goes home and starts heating the head. But minute is not enough to reach desired temperature, so it releases motors, they go down a bit and upon starting moving head the height is not accurate anymore. So, I added "M84 S180" to custom start g-code in slicer program to hold motors for 3 minutes instead of one.
November 11, 2015 04:59AM
Bigkahuna2187
hacker
Bigkahuna2187
Congrats ;-) But you're out of spare stepper drivers now ;-) So am I… My extruder stepper has died suddenly and I have no idea why.
I think it depends on firmware, I'm not sure what are Marlin's defaults. At the very least I Think it hits, goes back and then again up? I think you will have opportunity to worry about it later, just try getting things work now winking smiley
November 11, 2015 02:14PM
hacker
Bigkahuna2187
hacker
Bigkahuna2187
Thanks!
Did anyone have to invert their extruder direction? When I click Extrude in Pronterface the filament moves toward the extruder and when I click reverse the filament moves towards the hotend. Hoping my stepper isnt fried for this as well.
November 11, 2015 02:52PM
Bigkahuna2187
hacker
Bigkahuna2187
hacker
Bigkahuna2187
Thanks!
Thats normal. Marlin is stock setup for a geared extruder. This kit comes with a direct drive extruder, so you should set #define INVERT_E0_DIR in configuration.h to true. that way the extruder really extrudes when you tell it to instead of retracting.
November 11, 2015 10:16PM
Is there suppose to be a Blomker .ini file in the slic3r zip?
November 12, 2015 01:14AM
Bigkahuna2187
Nope. "Blomker " is another supplier of 3d printers and it referenced in Sintron's user manuals because Sintron simple "borrowed" them. So, you have to create your own settings for Slic3r from scratch.
November 12, 2015 04:56AM
1. I have a question regarding Printing time.
Printed a mobile phone stand took about 2 hours.
now I am using Cura because Pronterface does not want to work (AGAIN)
now it takes about 5 hours + to print the same thing.
I have played with a few settings but nothing much makes a big difference
I have gone to Default in Cura still slow. 0.1 Layer Height, 2mm shell 100mm/s print speed. 20% fill Density. still slower than before
2. I am a little concerned with the movement of the 3 wheel carrage truck
I thought a 4 wheel Carrage Truck and Delvin rollers would do the trick however Delvin rollers are M3 and Carrage Trucks are M4
I am not good in Cad so maybe I can sleeve them. Any one else Been Here ?
November 12, 2015 05:32AM
Electronics- Yes just reverse the leads on stepper motors take the plug off the ramps and turn it around if it is going in the wrong Direction.
Please put your Power supply output to 13.8 volts it will not over heat the regulators however definately blow a small fan over the ramps board.
Current (amps) is what will cook things the higher voltage helps with less current to give you the watts needed.
Put a heat sink on the Heatbed Tr also
November 12, 2015 05:41AM
theda1
Without knowing what model we're talking about the time isn't of much help, but so far I can see that 0.1 layer is pretty thin and of course yields longer printing times, then there's a travel speed and acceleration to take into account. Check firmware speed and acceleration limits and perhaps raise it. And, well, arduino/ramps has its own limitations as to how much it can do within a given time. Not sure what limits you're bumping in.
Since you mention the difference between "pronterface" and cura, perhaps you may want to somehow look up the settings used for pronterface's slicer whatever slicer it uses, I think it's Slic3r?
November 12, 2015 06:17AM
hacker
theda1
A mobile phone stand doesn't sound very large, so it might be worth looking into "min. layer time" or some setting like that.
November 12, 2015 09:47AM
Hi everyone,
first printer and first post in this forum. I finished building the Sintron Kossel kit yesterday, so today I will start with calibration. However before I start, I have some questions regarding the 'configuration.h' that comes with the Marlin firmware provided by Sintron. Please excuse if some of my questions have already been answered elsewhere...
My main question is: what parameters do I have to adjust and which parameters can be taken just as is?
Printer geometry
From reading this thread and several other sources regarding calibration of the Kossel Mini it seems as if DELTA_EFFECTOR_OFFSET and DELTA_CARRIAGE_OFFSET should be (as long as now modifications have been done to e.g. the carriages) the same for each and every Sintron Kossel printer out there, right? Still, do I have to touch these values in the Sintron 'configuration.h'? From what I understand I only have to adjust the DELTA_SMOOTH-ROD-OFFSET and the DELTA_DIAGONAL_ROD values according to my setup or am I wrong here?
I used a jig milled on my CNC router to assemble the rods using Traxxas joints:
Photo hosted by zimagez.com
Hence, DELTA_DIAGONAL_ROD length should almost perfectly be ~220mm for each rod. However, what I am currently scratching my head on is how to measure the DELTA_SMOOTH-ROD-OFFSET. From my understanding DELTA_SMOOTH-ROD-OFFSET should be affected by the endstop calibration. Hence, until I have not corrected for the endstop offsets adjusting the DELTA_SMOOTH-ROD-OFFSET parameter would not make any sense, right?
Motors
Obviously the DEFAULT_AXIS_STEPS_PER_UNIT are wrong in the Sintron 'configuration.h'. Do you think it makes sense to use a gauge to get the correct steps/mm; i.e. adjusting DEFAULT_AXIS_STEPS_PER_UNIT until a 1mm step on the z axis send via pronterface corresponds to 1mm measured by the gauge for each tower? As an alternative, would it be ok to just set each tower to 80 steps/mm?
Thank you for your help!!
November 12, 2015 10:14AM
HaGeEm
Hi everyone,
Printer geometry
Motors
All in all, I think you're more experienced than I am (you've milled a cool jig, after al!), but I'll try ;-)
The horizontal dimension is based on the parts involved in the first place and is set to theoretical value and if you still have some concave/convex problems you adjust it during the calibration. I think that's one of the things that they got right in firmware.
I think 80mm is a pretty safe bet. You can put a mark on your column, then move carriage, calculate the distance and adjust your firmware values then. I ended up with 80 anyway. Watch out for motors directions! And try being slow and having a power switch off with initial attempts ;-)
I admire your patience, I'd go for calibrating and wouldn't be able to wait for a forum response ;-)
November 12, 2015 10:40AM
Thanks for your reply, hacker!
hacker
Regarding calibration of the printer geometry I guess I'll just adjust the rod length and keep all parameters as provided by Sintron for a first try.
hacker
Marking the carriage positions on each tower is a nice idea for adjusting the steps/mm. I'll give it a try instead of using a gauge (which might be more complicated to set up anyway).
Just another question came up. Currently I have put my RAMPS board below the heatbed. Although I have insulated the space below the heatbed using cardboard and aluminium foil, I currently do not have any fan or something installed to cool the stepper drivers. Do you think I can give it a try or do you think I should definitely cool the electronics before starting with calibration and test printing?
Regarding the jig I milled, if there is any interest I can upload the STL to thingiverse. Although I guess there are already some other jigs floating around there. Further I made an endstop holder, which fits quite nicely using the nuts provided in the kit. It is quite easy to mill/print (when milling/printing the spacers underneath separately) :
I can upload this also...
Edited 3 time(s). Last edit at 11/12/2015 10:55AM by HaGeEm.
November 12, 2015 11:44AM
HaGeEm
I have never installed electronics under the bed. Neither original arduino/ramps, nor the new duet (thinner and cooler) — for no reason ;-) I may get to that later. And my plan is to first measure how hot it is in there ;-) Actually, even on the table the original ramps heatbed fuse was overheating so badly that without fanning it I couldn't heat up bed. Though that was fixed by replacing the fuse.
Yeah, I was mostly referring to the fact that you have CNC mill, which kinda suggests you're into that kind of stuff ;-) And yes, I desired the endstop myself — [www.thingiverse.com] — (also earlier in this thread). For what I can tell by this thread pretty much everyone designs his own endstop for this kit. It sure is way too trivial to use someone else's design and the original part is hardly usable at all.
November 12, 2015 11:54AM
As soon as you heat the bed, or you want to print for a longer period of time, I would make sure you have a fan under the bed blowing over the electronics. I calibrated my printer using an unheated bed since that works fine with PLA. No need to cool the electronics for that also because calibration prints are usually low speed so less chance to overheat your stepper drivers.
I would recommend putting a small heatsink on the 12v rail MOSFET by the way. Mine is acting up otherwise when I heat the bed.
Edited 1 time(s). Last edit at 11/12/2015 11:55AM by Tha_Reaper.
November 12, 2015 12:55PM
Okay, I think I might have an old fan lying around. I'll try to cramp it in there. Tha_Reaper, are you using a specific heatsink for the MOSFET (which can be ordered somewhere)?
hacker
Yeah, at least I now some basic gcode commands and how to use CAD software winking smiley Having a CNC mill is really nice especially for routing PCBs and so on. However, I hope that I can overcome some of the restrictions 2.5D milling has using the Kossel.
November 12, 2015 01:00PM
I know this may be a very broad question, but any tips on printing for the first time since no .ini was supplied? Im attempting without setting up my auto probe retract which im not in a rush to setup. Can I auto level, go to 0,0,0 and begin printing with my .stl file after tweaking slic3r parameters?
November 12, 2015 01:30PM
HaGeEm
I use a similar heatsink as you use for the stepper drivers. You can order like 50 of those for under 10 bucks if you search for heatsink MOSFET on ebay
November 12, 2015 01:55PM
Bigkahuna2187
Here are my slic3r settings. they work for me, but are far from perfect. maybe a good starting point.
Slic3r_config_bundlesintronkossel.ini
I also made a M666 button in pronterface. i use that button before i start every print. after i replaced the tape on the bed, or removed the bed, i totally recalculate the M666 settings again. takes me about 2 minutes to get it manually right if i use my last M666 settings as a starting point.
Edited 1 time(s). Last edit at 11/12/2015 01:58PM by Tha_Reaper.
November 12, 2015 02:51PM
HaGeEm
hacker
hacker
DO NOT put the RAMPS below the heatbed. I did that and I fried my MOSFET. Why? Because you cannot see the fan moving and blowing air. Yes I installed a fan below the heatbed blowing onto my RAMPS. It looks amazing. All electronics hidden. But you cannot see or hear if the fan is on. If for some reason the fan is off. Your RAMPS will smoke and you will not know until it is too late. Also, I insulated the heatbed bottom. But you are still getting cool air below counteracting the heat above. So it takes longer for the heatbed to get hot. I instead did a different method and mounted a new RAMPS setup on the X axis rod. And if DC42 reads this. Yes I have not bought the Duet. Im trying not to spend the $150 to buy that board.
Also HaGeEm what CAD software are you using. I am using TurboCAD pro.
Edited 1 time(s). Last edit at 11/12/2015 02:52PM by DRTak.
open | download - ramps box.jpg (378.8 KB)
November 12, 2015 03:18PM
DRTak
Thats where this thing comes in handy: [www.thingiverse.com]
you can see when your fans are running. I use 2 of those, and 1 30mm fan inside of the frame. The 30mm fan is very, very noisy. as soon as its up to speed you can hear it above all the other printer sounds. Hard to miss when that thing is not on.
I know the risk of smoking the RAMPS is higher, but i still prefer this to external electronics (at least untill i tidied up the cable mess and i'm able to build a good case for the RAMPS)
