Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 03:31PM |
Tha_Reaper
Thats where this thing comes in handy: [www.thingiverse.com]Quote
DRTak
DO NOT put the RAMPS below the heatbed. I did that and I fried my MOSFET. Why? Because you cannot see the fan moving and blowing air. Yes I installed a fan below the heatbed blowing onto my RAMPS. It looks amazing. All electronics hidden. But you cannot see or hear if the fan is on. If for some reason the fan is off. Your RAMPS will smoke and you will not know until it is too late. Also, I insulated the heatbed bottom. But you are still getting cool air below counteracting the heat above. So it takes longer for the heatbed to get hot.
you can see when your fans are running. I use 2 of those, and 1 30mm fan inside of the frame. The 30mm fan is very, very noisy. as soon as its up to speed you can hear it above all the other printer sounds. Hard to miss when that thing is not on.
I know the risk of smoking the RAMPS is higher, but i still prefer this to external electronics (at least untill i tidied up the cable mess and i'm able to build a good case for the RAMPS)
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 06:33PM |
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 06:59PM |
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 07:15PM |
AFAIR, the default Slic3r sequence is: printer waits for bed is heated, then homes, them moves the head closer to the bed, heats the head, and starts printing.Quote
Bigkahuna2187
How long does it take to 'initialize' printing?
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 07:17PM |
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 07:29PM |
Re: Ebay SINTRON Kossel Mini full kit November 12, 2015 07:43PM |
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 03:41AM |
GrAndAG
I can suggest buying solid state relay to connect heating bed via it. It will eliminate all problems with mosfet and fuse overheating.
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 03:47AM |
Tha_Reaper
I also made a M666 button in pronterface. i use that button before i start every print. after i replaced the tape on the bed, or removed the bed, i totally recalculate the M666 settings again. takes me about 2 minutes to get it manually right if i use my last M666 settings as a starting point.
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 03:49AM |
DRTak
Also HaGeEm what CAD software are you using. I am using TurboCAD pro.
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 04:00AM |
HaGeEm
Okay, so I almost finished height calibration yesterday. However, when I tried to do a 'hot calibration' (with hotend and heatbed set to PLA temperatures), the heatbed stopped warming after some seconds. From what I have read in this thread, it seems as if the stock PSU (rated at 10A) simply cannot provide enough current to heat the bed. Suggestions ranged from increasing voltage to something above 13V (as it won't affect linear regulators too much but might kill your fans) to adjusting PWM frequency by modifying MAX_BED_POWER in the Marlin 'configuration.h'. Further, I have an old ATX PSU lying around which is rated at 17A. I could modify this one without too much effort. What is the way to go here?
Anyway, before going any further I will order some 40mm fans and put them outside of the empty space below the heatbed using some kind of adapter (which I still have to design and mill). Further, as Tha_Reaper suggested I will put a heatsink on the MOSFET. This might solve the heating problems mentionedabove until I can afford to buy a Duet board, which I will mount in a separate box anyway.
DRTak
At home I am using the developer version of FreeCAD, mainly because it is open source and runs on my linux box. I like it a lot! However, at work we are using SolidWorks altough I did not have too much time to play around with it.
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 04:03AM |
HaGeEm
DRTak
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 04:11AM |
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 05:02AM |
I used to do that too, but i gave up on that since everytime you tinker with the heatbed (even replacing tape matters), the calibration will be thrown off and you have to edit your gcodes. Pretty annoying when you want to reprint an old model and you have t edit your gcodes first to get it to print right. Knowing myself i will forget to do that 90% of the time.Quote
Sir_Death
Tha_Reaper
Thanks for the Idea with M666 Button - until now I did mechanical calibration - and was thinking of how to insert the M666..
As I'm often printng from SD, I will include this M666 to start g-code too.
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 05:42AM |
Sir_Death
You could use the Heatsink Method and connect the second Powersupply to the RAMPS Input marked with 11A (but you still might get Problems with the polyfuse), ...
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 06:41AM |
HaGeEm
Sir_Death
Just to make sure: from the schematics of the RAMPS board Q3 is the MOSFET we are talking about (provided the heatbed is connected to D8), right?
Anonymous User
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 06:49AM |
Tha_Reaper
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 10:20AM |
o_lampe
nebbian
Alternatively if you're feeling brave you could disassemble the push fit connector and drill it out the same as the one on the hotend, which would allow you to push the bowden cable all the way through the hole in the extruder until it's almost touching the extruder gear and idler bearing.
Pretty risky with a M5 or M6 thread. On my e3d clones heatsink it was a 10mm thread with plenty of "meat".
If you still want to try, be aware of brass needs a different drill-angle than the average "all purpose" metal drill has.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 06:23PM |
Re: Ebay SINTRON Kossel Mini full kit November 13, 2015 10:44PM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 12:31AM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 03:02AM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 09:45AM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 12:23PM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 12:29PM |
Tha_Reaper
I need some help...
as i started printing more complicated objects, i noticed a problem starting to appear in my prints: really bad overhangs.
upon further inspection, those bad overhangs only appeared on the side of objects facing the Z-tower.
I noticed that my hotend is not facing downwards. its at an angle towards the Z-tower, and i guess thats where my overhang problems come from. today i tried replacing the effector and hotend bracket, which failed miserably and only gave me more problems.
Here is a picture of my problem: [www.dropbox.com]
you will notice a thread hanging from the top of the hotend heatsink. That thread has a weight at the end, so it is perfectly vertical. you can see that the hotend is not parallel to the thread. the tower that you see in the picture is the X tower.
Anyone else faced this problem? and how were you able to solve it?
So far i tried: replacing the effector and bracket, putting washes on the Z tower side between the bracket and effector (which led to a bend bracket)
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 12:38PM |
In my case i'm pretty sure its not a pushrod problem. the degrees of tils stay the same wherever i move the printhead.Quote
hacker
Tha_Reaper
I need some help...
I can't help you, but I also have hotend a bit tilted when it's closer to the edge of printable area. I do not yet have serious problems associated with that. I suspect my pushrods are of different length, but haven't yet tried to deal with it. At any rate, I'd love to listen to the advice you get
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 01:00PM |
Tha_Reaper
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 02:17PM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 03:25PM |
Re: Ebay SINTRON Kossel Mini full kit November 14, 2015 03:39PM |
GrAndAG
If the effector moves without any tilt, you should have absolutely no problem even with non-vertical hot-end. Because this defect affects [X:Y] offset only, and it's constant. Which can be adjusted in Slic3r to make [0:0] point of the nozzle perfectly in center of the table if you wish. But it's absolutely not needed.
