Ebay SINTRON Kossel Mini full kit
Posted by Miamicraft
Re: Ebay SINTRON Kossel Mini full kit
November 15, 2015 07:38AM
dc42
GrAndAG
If the effector moves without any tilt, you should have absolutely no problem even with non-vertical hot-end. Because this defect affects [X:Y] offset only, and it's constant. Which can be adjusted in Slic3r to make [0:0] point of the nozzle perfectly in center of the table if you wish. But it's absolutely not needed.
I'm sorry, I misunderstood. I don't think that tilt matters very much. I think it may be caused by the groove mount plate not being screwed tight up against the effector, so the effector is horizontal but the groove mount plate isn't.. May be there is a stray bit of plastic between them that needs to be trimmed off.
I think this is indeed the problem... i tried trimming the plastic a bit, but now the hotend has a slight play in it. Not good...
I'm going to try another version of the effector, this one should not have the same problem as it secures the hotend in another way: [www.thingiverse.com]
As an example of what i mean with overhang artefacts i'll show these 2 pictures:
Front of the object:
[www.dropbox.com]
Back of the object:
[www.dropbox.com]
you can see a lot of thick overhang issues on the back, while only a few on the front. My therory is that this is because of the tilted hotend...
November 15, 2015 12:00PM
Tha_Reaper
[www.dropbox.com]
Back of the object:
[www.dropbox.com]
Is it PLA or ABS? If PLA, the difference could be due to non-uniform cooling.
November 16, 2015 01:28AM
PLA.
How to combat non uniform cooling?
November 16, 2015 04:24AM
Tha_Reaper
PLA.
Circular fanduct maybe?
November 16, 2015 04:53AM
good point actually.... does anybody have a good cooling solution for our kits (and hotends) ? Most solutions I found either are made for different heatsink diameters or are to big overall costing way to much printspace on the edges. Or both smiling smiley
And does it matter having a fan blowing to the noozle? Or do I have to make sure only have the fan hitting the object itself?
November 16, 2015 05:04AM
MrPCatt
I have a solution combined from various parts available and some designed myself, but that's not of much use as I have different heatsink diameter, somewhat different mount and actually it does cost a bit more space than I'd want it to, so I'm still thinking… ;-)
But what I wanted to say is that it's best to cool nozzle as little as possible while cooling the extruded plastic well, but in reality you always compromise this way or another…
November 16, 2015 06:06AM
MrPCatt
It's best to have some control over the cooling.
I was having no end of trouble with a certain part (long and thin) curling up on me (ABS, with raft and PEI bed). Eventually after a dozen or so failures I figured out that the exhaust from the hot end fan was cooling the part too much. Rotating the part so that it was at 90 degrees to the airflow made a huge difference and now I'm getting perfect prints. I also put a small metal shroud to guide the airflow from the fan to past the heatsink, so it didn't go down to the bed.
November 16, 2015 12:02PM
MrPCatt
This is an exact fit for our kit. I downloaded this and use it. It works perfectly.
Remove fan. Place shroud. Put fan on shroud. screw in place. its an exact fit for our kossel.
I was having hot end cooling issues when using ABS. Now no more issues.
November 16, 2015 12:18PM
DRTak
MrPCatt
Good thing, though it's only about heatsink cooling, not part cooling.
November 16, 2015 07:58PM
yeah the fan shroud over the hotend heatsink? I must be confused then?
November 17, 2015 02:32AM
DRTak
The fan over the hotend sink is very important to be able to print at all, but when it comes to overhangs in PLA the cooling of extruded plastic also becomes important to print well.
November 17, 2015 05:13AM
Ideally, you have to have 2 fans. One is permanently cooling the heatsink and connected directly to 12V contacts of PSU. And the second one (for PLA cooling) is blowing directly to area around the nozzle, which can be connected to D9 output of RAMPS for controlling from printing software (or from g-code).
Like this:
http://www.thingiverse.com/thing:540716
Or this:
http://www.thingiverse.com/thing:451667
Edited 1 time(s). Last edit at 11/17/2015 05:13AM by GrAndAG.
November 17, 2015 05:16AM
GrAndAG
There's no fan ;-) (but yes).
November 17, 2015 05:18AM
For the object fan we now just need a really space saving solution. Or at least a solution which does not collide with one of the towers.
November 17, 2015 05:25AM
MrPCatt
There are also solutions like this one: [www.thingiverse.com]
November 17, 2015 05:29AM
MrPCatt
Mount the fan facing to the front (or any side between towers). I doubt it will collide much (if any).
November 17, 2015 05:32AM
Okay, I finished calibration and did some test prints using PLA yesterday evening. I used 0.3mm layer height for the first two layers and 0.2mm for the rest. Printing speed was 20mm/s for the external perimeters and 40mm/s for the infill (20%). I set the bed temperature to 60°C and hotend temperature to 195°C for the first layers and 185°C for the rest. First 10mm cube had corners bended upwards. After cooling the PLA on the heatbed using a (handheld) fan the cube dimensions were almost perfect. Both, X and Y exactly 9.98mm. However, Z height was 10.37mm.
Could someone point out what potentially causes this problem? Is it due to overextrusion? What I observed during printing was that the higher layers were more like a smear of PLA. Although I am new to 3D printing I guess this is not intended? I think there is also a post in this thread which states that Slic3er 1.2.9 has a problem with getting the extrusion width right. However, as X and Y width were almost perfect I guess this should not be a problem?
Thanks for your help!
November 17, 2015 05:41AM
My advice would be to not print such small objects for calibration. Try real objects and see if the dimensions are somewhat precise. Or at least take 20mm cubes or bigger.
November 17, 2015 05:49AM
HaGeEm,
I'm printing PLA @ 195C all layers, 0.2 thickness (all layers again). 60mm/s for perimeters (70% for outer), 80-90mm/s - infill, 60mm/s - top/bottom (15-20mm/s very first layer). But I heating up the bed is very bit - to 40C.
Even on default Slic3r settings (40mm/s, 200C, layer 0.3) I had my very first print (1cm cube) very decent. Could you show us yours?
Anonymous User
November 17, 2015 05:56AM
HaGeEm
Had the same Problem when printing to cold and / or to fast. - Gets even worse, the higher the printed object is ... - up to complete blockage of Hotend.
I'm printing at about 12-15mm/sec at 0,2mm Layer height and 215°C for PLA
November 17, 2015 05:57AM
Thanks for getting back to me! I will print a 20mm calibration cube to see if dimensions are still okay and then fiddle around with Slic3er settings...
GrAndAG
I will try your settings, thanks!
GrAndAG
Sure, I will take a picture of it later today, as I am not at home currently...
November 17, 2015 05:59AM
Sir_Death
Could that be that it's just too slow for your heatsink cooling? The longer filament stays near the heated area the higher the heat creeps, the more likely it is to clog? And of course the higher the object is (the longer you print) the likelier it is to finally block the hotend?
November 17, 2015 06:00AM
Sir_Death
Mhm, your settings seem to be totally different from GrAndAG's. I think I will just have to experiment with different settings then...
November 17, 2015 06:10AM
By the way: which Slic3er version are you girls/guys using?
November 17, 2015 06:11AM
hacker
Sir_Death
Oops, sorry, it sounds like the slowness actually solved your problem ;-)
Anonymous User
November 17, 2015 06:45AM
Correct - printing faster gave holes in the print, and nozzle got jammed after about 3-4cm printing height.
Slowing down to 12-15mm/sec (1,3mm³/sec volumetric speed), and printing is perfect....
Anonymous User
November 17, 2015 06:51AM
HaGeEm
Finally 1.2.9 - with nearly all Settings done manually - especially layerwidth
November 17, 2015 08:30AM
Sir_Death
Interesting… admittedly I use different hotend, but I can print PLA at about 100-120mm/s with no underextrusion at 215C…
Does your motor skip when printing faster? Could it be that it's underpowered?
12mm is the speed I use to lay the first layer of PETG…
Anonymous User
November 17, 2015 08:51AM
hacker
Vref is set correctly - double-checked (it was even set to 10% more - did not get better - motor just got hotter...)
I have the same Vref on the other three Motors (X/Y/Z) no Problem with skipping there.
Hotend is simply not melting fast enough. Coldend-Fan already has a Screen to not cool the hotend. - Made it much better (was even worse before...)
November 17, 2015 09:09AM
Sir_Death
hacker
I think extruder current is not necessarily the same as other motors, I think "correctly" means it doesn't skip when extruding, but skips with blocked hotend. Of course if it gets too hot that also adjusts the idea of correctness…
My currents configuration (duet board) is M906 X600 Y600 Z600 E1000 I0.6 meaning extruder current is higher than other axes — can't tell how current numbers translate to Vref, but I think I've seen the stepper driver details somewhere in this thread. The motor is a bit warm, but not too hot.
I don't think you (or I for that matter) need to go as high as 100mm/s, but 12-15 sounds a bit slow to me… Then I think someone on this thread reported he prints infill at 150mm/s and running stock hotend?
