Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 04:28PM |
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 04:35PM |
realthor
dc42
My recommendation is this [www.think3dprint3d.com], but it costs even more. [I have a slight interest, because it uses my IR height sensor.] Or you could build your own using the Kossel variant described in my blog (see link in my signature) as a basis.
Personally I am looking into a sub-400 kit just to wet my feet and I am planning to use that to build another one so I would really like to even canibalize the kit's parts to use on the one I am going to primarily use for prototyping stuff and mechanical parts for broken stuff (I don't need pretty sub-micron resolution but I need precision and repetability in the "good-enough" range). I will not print yoda heads and mini-mes with it. I need fast printing (prototypes need that so a Delta seeemed logical) and even dual-extruder for fast 0.8+mm infills but that is not mandatory.
I was looking at Sintron with interest but got dissapointed after the first 3-4 pages on this thread. I don't mean to hijack this thread so please go on with Sintron stuff here, I got my answer about recommending Sintron for first 3D printer.
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 05:10PM |
dc42
realthor
Personally I am looking into a sub-400 kit just to wet my feet and I am planning to use that to build another one so I would really like to even canibalize the kit's parts to use on the one I am going to primarily use for prototyping stuff and mechanical parts for broken stuff.
The T3P3 kit I linked to would be a good basis for cannibalizing to make a larger printer, because it has good electronics and a genuine E3D hot end. You won't find those on any low-cost kits.
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 05:48PM |
You can invert the behavior of this particular switch in firmware config, to avoid re-soldering work.Quote
blurd
It doesn't short out anymore, but it is TRIGGERED when the probe IS deployed. I connected the switch as shown in the manual. Then I tested it hooking up the NC(on the left) terminal on the switch to the middle pin on the RAMPS and it works like you mention, so I must have a mis-wired one.
z probe wiring
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 05:54PM |
realthor
As much as I droll for such a printer I simply can't shell out that much money fro one. For me it is just a toy so far and my personal view is that it is not yet as useful as the hype goes online. So, even if I can afford it it doesn't make sense. So either building one from scratch or buying a 300-400 kit is an option for me. It's just a tool that can do intricate plastic stuff. No milling, no soldering, just plastic stuff.
I have checked the no-printed-parts option and is about 650EUR ...still way over my budget.
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 06:03PM |
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 06:11PM |
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 06:14PM |
MrPCatt
But you guys should also consider.... a cheap 400 bucks kit might burn the 3d printing experience all together because its more frustrating than fun to work with. Its basically the same like every hobby...
But I totally agree that a kit is the way to go for really getting into the matter.
Re: Ebay SINTRON Kossel Mini full kit November 21, 2015 07:35PM |
Re: Ebay SINTRON Kossel Mini full kit November 24, 2015 01:36PM |
squall
Agreed that this kit might not be everyone, but I have to say I haven't had to spend any extra on getting it working.
The only real mod I had to do was grind the metal rod ballends so they don't bind.
I've been having a lot of fun experimenting with printing and think it's great if you like building stuff yourself.
Just some examples of the stuff I've played around printing so far:
Re: Ebay SINTRON Kossel Mini full kit November 24, 2015 05:09PM |
DRTak
Also, I love PETG filament. Ive been using it for 2 days. Similar qualities to ABS but more flexible. Also no smell like ABS. My kids keep breaking the ABS figurines they want. But no issues so far with bendable PETG
Re: Ebay SINTRON Kossel Mini full kit November 24, 2015 10:58PM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 03:36AM |
DRTak
Out of the objects you printed. How did you print out that straight linear bat thing. My machine has issues with making round stick like objects. Can you tell me your slic3r settings for that?
It rolled on its side when I was trying to get focus on the camera in the previous pic.|
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 04:12AM |
DRTak
I use the same exact settings as ABS. Temp of 218. Bed temp of 100deg. It sticks really well to the heatplate. Sticks better than ABS. The rest of the settings are the same as ABS as well. Retraction etc.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 05:20AM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 05:42AM |
squall
hacker
squall, is the recorder really playable?
It kinda works, but not greatYou have to blow loudly for it to sound like a recorder.
If you blow softly it just comes out breathy/wispy.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 05:54AM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 06:20AM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 06:42AM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 08:00AM |
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 08:59AM |
Tha_Reaper
I use Marlin 1.1 RC2 firmware.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 10:00AM |
Tha_Reaper
I Finally got my LCD to work, but it seems that the reset button on the LCD doesnt work.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 11:32AM |
[github.com]Quote
MrPCatt
Tha_Reaper
Could you please describe where to get it and what I have to take over from my current firmware/Settings, the package which came from Sintron (1.01 or so?). And is there a changelog to see if there are new features or which bugs have been fixed?
Sorry for the dumb question, but I am a noob regarding this Aduino stuff and my research about newer versions gave me more questions than answers.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 11:34AM |
yeah... kill switch. it said reset above it, so i got confused :pQuote
hacker
Tha_Reaper
IIRC, LCD doesn't have a reset button, but rather a kill switch, so it should kill everything, but isn't supposed to be followed by reboot (I hope there's a reason for it, because I found that pretty frustrating personally).
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 11:44AM |
Tha_Reaper
hacker
Tha_Reaper
Anyway: i can press that button all i want mid-print. print will happily continue. Only way to stop it is trough the menu, or killing the power.
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 03:26PM |
Here is the linkQuote
Tha_Reaper
[github.com]Quote
MrPCatt
Tha_Reaper
You basicly compare your sintron version configuration.h and adv_configuration.h with the 1.1RC2 release, and try to copy as much of the custom values as possible. You will need to tweak some things, but it should be pretty straightforward.
I'll upload my working marlin config when i'm at home. From there it's basicly editing your own config values in, and try to get it running.
My RAMPS is under the bed... cant reach that killswitch. I have a foot pedal with which i can kill the power. it does the trick.Quote
hacker
Tha_Reaper
hacker
Tha_Reaper
I thought you might have expected different response. You can also hit reset on ramps, that's what I used to do before. Sintron LCD's kill switch I haven't even tried, maybe it's designed not to work…
Re: Ebay SINTRON Kossel Mini full kit November 25, 2015 08:40PM |
Re: Ebay SINTRON Kossel Mini full kit November 26, 2015 01:55AM |
Re: Ebay SINTRON Kossel Mini full kit November 26, 2015 07:26AM |
I tried and it works. It immediately stops any motor movements at least. When I made initial configuration I sent carriages to out of limits several times, and used this button to stop the printer.Quote
hacker
After pressing kill button printer kinda listen the port as well. Because I was able to reset the printer from Pronterface after kill button was pressed.Quote
AnHardt
Kill is much saver than a reset because after a reset the machines is listening to the serial/usb port again. If the host still sends the code could be executed immediately. The other reason, is a possible AUTOSTART file on the SD-card.
Re: Ebay SINTRON Kossel Mini full kit November 26, 2015 10:47PM |
