Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 10:32AM |
.Quote
dc42
If the bed is matt black and you have no glass on top of it, then you may not get good results from the sensor, because matt black paint will probably not reflect enough IR. The sensor will work on a dark grey surface such as BuildTak, but not black. I recommend matt black paint on the aluminium when you will be putting glass on top of it, because then the sensor can see the reflection from the top surface of the glass without being swamped by a stronger reflection from the aluminium below.
Remember, the only purpose of the H parameters is to account for different trigger heights of the Z probe at different points on the bed. So only use H parameters if you measure the probe trigger height at each point, as I described at [forums.reprap.org]. However, if you get differences in trigger height greater than about 0.2mm then it probably means that you have serious effector tilt, and you need to fix that first.
Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 11:08AM |
DRTak
... I read your blog and you said u will not use buildtak out of anger? What happened? I have the same thought with some places. If they are not nice. I wont buy from them again? In my experience I think I will use glass. I have issues with my nozzle grazing the build plate (when I had the analog z probe). Thats why I have moved away from Kapton like you did.
DRTak
I noticed an error with the web interface today. After I made my own macros under Default G codes. +Add g code. I lost web connection. The macro I made was basic. It was G1 X0 Y0 Z1
I named it HomeZero. I hit apply. Used the gcodes after one calibration session. Then lost web interface. It said cannot connect to duet firmware? So I deleted the cache in Chrome and it worked again. When the web interface opened up. The macros were deleted I assume when I deleted the chrome web cache.
DRTak
With auto calibration x 3. I have it down to (Z height above bed): Nozzle at center 0.2, X tower: 0. Y tower: 0. Z tower: .05. The nozzle height at center never changes. It is always 0.2. The other heights change by up to 0.1mm. Any way to fix the z height at center? Add another g30 probe point at say x2 y2?
Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 04:30PM |
Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 04:35PM |
DRTak
dc42,
I have a question. How does the IR sensor know where the nozzle is in space. I have spaced the IR board 1.5mm above the nozzle tip. But how would the IR board know that?
What if I placed it 2mm above? How would it know?
I guess what Im asking is.. did I overlook that simple equation. Type in some value of what the nozzle height is in relation to the IR board?
Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 04:43PM |
DRTak
dc42,
Re: Ebay SINTRON Kossel Mini full kit December 12, 2015 05:12PM |
dc42
DRTak
dc42,
You have to measure the trigger height (i.e. nozzle height above the bed when the probe triggers) and enter that value as the Z parameter the G31 command in config.g. See the Testing & Commissioning section of [miscsolutions.wordpress.com].
Re: Ebay SINTRON Kossel Mini full kit December 13, 2015 02:56PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2015 04:07PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2015 04:16PM |
o_lampe
Did you check the housing of the USB socket? Some reported bad solder jobs on duet0.6 from Replikeo. ( Mine was OK and obviously resoldered by hand.)
-Olaf
Re: Ebay SINTRON Kossel Mini full kit December 13, 2015 07:02PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2015 09:26PM |
dc42
Regarding the thermistors, in theory all 3 channels should need the same H parameter. Any other discrepancies are likely to be due to thermistor tolerances. It's normal for the hot bed and hot end to give readings a degree or three different at room temperature.
The extruder steps/mm of 663 in the config.g file you are using is about right for the mini geared extruder used on the T3P3 Mini Kossel kit. If your extruder is direct drive, then 100 would be about right.
If you are getting colour hue issues with PanelDue, and it is not because you are viewing the display from a wide angle, then I suggest you check the 5V power feed into the PanelDue in case the voltage is too low.
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 06:14AM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 07:27AM |
Rossini
Hey @all,
has anyone a tipp for me: the pom-rollers on the carriages have a lot of play on my kossel mini. how to solve that? they have so much play, that the force from the bowden tube tilt the effector.
other bearings? other wheels? order some linear-rails?
thanks
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 07:42AM |
dc42
Rossini
Hey @all,
thanks
If it is the usual printed carriage with three wheels, there is a tensioning screw going right through the carriage near the top that you can tighten up. Also check that the wheels are wide enough so that the V-part does not sink completely into the slot of the extrusion.
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 07:52AM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 07:56AM |
dougal1957
dc42
Rossini
Hey @all,
thanks
Dave
Like a lot of the very cheap Chinese Delta kit they seem to use cheap Shower door type roller wheels on the carriages with only a single bearing.
From what I read in here it is a common problem with them wearing out quite quickly and a lot of user's either give up in frustration or upgrade to decent roller's such as the Openbuilds mini Vee wheels and Robotdigg do a cheap copy of them for around $1.50 each Mini Vee Wheels
and along with the eccentric spacers make for a easy adjustable carriage design.
Doug
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 08:13AM |
dc42
The mini V wheels are available from many different suppliers, for example think3dprint3d in the UK. Search ebay or google for "delrin v-wheel". You don't need V-slot to use them, they are OK with standard slot extrusion. I reckon 6mm is the widest slot width they would work with.They need two 623ZZ bearings each.
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 08:23AM |
Rossini
well, i tightend the carriage. But the play comes from the bearings i think. yes it's a single bearing.
I considered the mini-v-wheels but are they compatible with the sintron extrusions, as they are not really v-slot extrusions and shipping costs from robotdigg are very expensive for austria.
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 08:26AM |
Rossini
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 09:39AM |
Rossini
Hey @all,
thanks
Re: Ebay SINTRON Kossel Mini full kit December 15, 2015 06:56PM |
Rossini
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 04:42AM |
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 06:17AM |
o_lampe
BTW: The t3p3 rollers are made for Nut-5 extrusions. When I changed my setup to robotdigg corners, I had to use wider Nut-6 extrusions ( or dremel the slots to fit in the corners )
Now the rollers are to narrow.
-Olaf
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 06:43AM |
Rossini
o_lampe
-Olaf
What are the sintron extrusions? Now i am confused. Are the Robotdigg metal corners compatible with the Sintron extrusions or not. Do i have to dremel the slots?
For the rollers: well i think i buy the mini-v-rollers and print matching carriages. Maybe these: [www.thingiverse.com]
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 07:11AM |
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 07:55AM |
Re: Ebay SINTRON Kossel Mini full kit December 16, 2015 07:07PM |
Re: Ebay SINTRON Kossel Mini full kit December 20, 2015 11:33AM |
Re: Ebay SINTRON Kossel Mini full kit December 21, 2015 04:30PM |
