Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 10:19AM |
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 10:37AM |
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 11:30AM |
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 01:23PM |
AnHardt
I *think* the sintron has a sticker SL42STH40-1204A. I think that means 1.2A rated current?
That's correct.
NEMA 17 is the kind of stepper.
MK8 is the kind of toothed wheel.
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 03:46PM |
DRTak
Also, Hacker, I changed my original Sintron E3D clone to a Hexagon Hotened. I assume the thermistor that came with the Hexagon was off or whatever. I was using PLA at 190deg and PET at 230 deg. Now I have PLA at 220 deg and PETG at 250 deg minimum. lt was working fine. Things looked great. But again, one day after a 5hr print (first time I attempted a 5hr print with PLA) it wouldnt print right anymore.
Update: I printed my first print with the current of the E motor at 1000mA. I also tested my luck and I decided to go back to using my old PLA defaults (ie faster settings). So far so good. I am 15min into the print. Everything looks good. I have never heard my E motor humm like that before. It sounds like a laser beam shooting.
So before at 500mA, I hit extrude and just by my hand touching the filament the E motor would skip. At 1000mA, I physically cannot grab the filament and hold it back to even make it skip when I hit extrude. So somehow my machine must have defaulted to 500mA when it should have been 1000mA? I guess we will find out in another 15min when the problem of underextrusion occured before
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 04:42PM |
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 05:32PM |
DRTak
Hacker, thanks for the info and research. The Hexagon doesnt have PTFE liner in it. Thats why I bought it. Its really all metal. I bought a hobby drill set. It has a 0.4mm bit. I pushed it into the nozzle and the nozzle is clear.
And I think you are right. Eventually I would have had to deal with this issue. It was just a matter of time. The Hexagon needs more torque on the PLA filament I guess. It was fine for PETG but I was running PETG at a very very slow speed. It was skipping though but I thought that was normal for PETG. Now I might test PETG at a faster speed.
Yeah. I calibrated the new thermistor the best I could. It says its a standard EPCOS B57560G104F NTC Thermistor.
This is what my config.g file looks like for it:
M305 P1 T100000 B4066 R1000 H5 L-30
But now it might all have been that the extruder motor was under powered NOT that the hotend couldnt melt enough plastic. I was cranking up the temp of the hotend thinking that it wasnt hot enough.
And beta value of 4036. Also, I have R4700, but I believe if it was wrong the problem would be more serious and I think you have different duet (I have duet 0.8.5 from think3dprint3d). Another reason for temp difference may be how far the thermistor is from nozzle in the heater block. And then you're right, different hotend, different printing conditions.|
Re: Ebay SINTRON Kossel Mini full kit April 26, 2016 06:42PM |
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 04:38AM |
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 06:00AM |
Neither MK7 nor MK8, actually, from drive-gear perspective. They both should have grooved drive-gear, like this:Quote
o_lampe
Also sintrons extruder gear is MK7 ( not MK8 )
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 10:07AM |
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 11:00AM |
DRTak
Thanks for the input. I have changed the thermistor values. I am trying to make it equivalent to ambient room temp of 19deg C. This is what I have so far.
; Thermistors
;*** If you have a Duet board stickered "4.7K", change R1000 to R4700 to the following M305 commands
M305 P0 T10000 B3950 R1000 H-10 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4036 R4700 H225 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
With the above settings. The P0 is 19.6deg and P1 is 19.6deg.
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 11:56AM |
dc42
DRTak
; Thermistors
H225 is way outside the normal range. You either need R1000 for both thermistors, or R4700 for both. Replikeo Duet 0.6 boards and very old RepRapPro boards use R1000, all others use R4700. In theory, all channels should need the same H parameter too.
Also check what resistance your bed thermistor is. RepRapFirmware defaults to 10K, but in most printers bed thermistors are 100K like the hot end. Use the T parameter to specify the resistance of your thermistor at 25C.
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 12:03PM |
DRTak
dc42
dc42. I have a duet 0.6 from think3d. I will change the R back to 1000.
Re: Ebay SINTRON Kossel Mini full kit April 27, 2016 05:01PM |
Re: Ebay SINTRON Kossel Mini full kit April 29, 2016 11:39AM |
Re: Ebay SINTRON Kossel Mini full kit April 29, 2016 03:33PM |
forest
im fast approaching the time to turn my sintron kossel on and im just wiring the 220mm mk3 alloy heat bed (i think it is the one that sintron supply) it is red and the warning dont touch text on the bottom with terminals on bottom in the center, no thermister hole in the center , and what looks like two leds and a resistor, what im wondering is has anyone bother to make the leds remote or have you just lost the signal from them as its underneath? is it worth me dremeling a divot for the thermister ? or just tape it on? the red surface?
thanks guys
Re: Ebay SINTRON Kossel Mini full kit April 29, 2016 03:39PM |
dc42
If your bed temperature is reading about right at room temperature and is a 10K thermistor, then you must have 1K resistors on your Duet. So change the R4700 in the M305 P1 command back to R1000. Keep using the 10K bed thermistor, there is no need to change it.
Re: Ebay SINTRON Kossel Mini full kit April 30, 2016 06:34AM |
Re: Ebay SINTRON Kossel Mini full kit April 30, 2016 09:55AM |
LVD
DRTak
I would not dremel a hole in the heatbed.
I drilled a small hole in the centre not all the way trough and glued the thermistor in it with some thermal paste.
Re: Ebay SINTRON Kossel Mini full kit May 21, 2016 02:20PM |
Re: Ebay SINTRON Kossel Mini full kit May 21, 2016 04:21PM |
Re: Ebay SINTRON Kossel Mini full kit May 22, 2016 05:13AM |
I just attached it in the center of back side using couple pieces of kapton tape.Quote
Dejay
... wonder if there are any tips about attaching the thermistor to the heat bed?
They are just dumb LED power indicators. One of "diodes" (depending on connection polarity) is light up when heat bed is power on.Quote
Dejay
Also, what are those components on the PCB? Two diodes and a resistor?
Re: Ebay SINTRON Kossel Mini full kit May 22, 2016 02:34PM |
Re: Ebay SINTRON Kossel Mini full kit September 12, 2016 04:28PM |
gkr
Hello Folks,
Been away from this forum for a while, but my Sintron Kossel is still doing great.
Yesterday, I was at my local MicroCenter, and happened to see this new "tiny" delta from SeeMeeCNC. They have called it "Eris".
[www.seemecnc.com]
I always wanted to get a Rostock Max V2.. while it was not a funding problem, the problem I was having was to find a place to keep it. I already have 2 printers.
But this new entry was small, and pretty sweet. It has a a cool accelerometer based auto-level feature built-in to the hot-end structure.
I picked one up, and so far it has been quite impressive.
Just thought ya all might be interested, so I shared it.
Thank you.
Re: Ebay SINTRON Kossel Mini full kit September 12, 2016 05:44PM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2016 12:32PM |
Re: Ebay SINTRON Kossel Mini full kit September 13, 2016 03:06PM |
hacker
DRTak
M552 P192.168.2.14 ; IP address (0 = use DHCP)
M554 P192.168.1.1 ; Gateway 71.8.194.37
M553 P255.255.255.0 ; Netmask
Looks like your gateway is not on the same network as your ip, does it work? Or does it even care about the gateway given the abundance of network interfaces?
Re: Ebay SINTRON Kossel Mini full kit September 13, 2016 03:40PM |
DRTak
hacker
DRTak
It works.
My house would be an IT nightmare. I have a one cable line coming into the house. It is connected to a cable modem. I have one ethernet line connecting the modem to an Asus wifi router. The back of the router ran out of ethernet Out lines. So I connected that to an ethernet switch (which I had laying around from an older project. ie its free. I could have just bought an 8 or 10 port switch) which gave me 4 more ethernet lines. I then ran out of those lines. So I had an older Asus Wifi router laying around. So I use that as a "switch" to get more ethernet out lines. One of which goes to my Kossel. Well after many trials I realized that I could not connect to the main intranet without making my Kossel a static IP with a different IP that the main network. So 192.168.2.1 (old router) instead of 192.168.1.1 (main asus new router). The gateway is the main gateway for the cable company modem.
So I could have thrown away the old asus wifi modem and bought another switch. However, turns out that my kids Iphone 3 G can only be on this old wifi network due to older wifi system protocol installed in the iPhone 3g which is a n/g I think. My new modem can run on the wifi "a" protocol and has no backward compatability with the n/g protocol. Also, my kids Kindles can only handle the older wifi protocol n/g. So Im stuck with having to use this old wifi modem along side my newer modem.
And my old duet now powers prusa.
(ftp too, but that sounds like much more hassle to implement, so it's understandable).
Re: Ebay SINTRON Kossel Mini full kit September 13, 2016 09:02PM |
hacker
DRTak
hacker
DRTak
It works.
Nah, that doesn't scare me at all, I have pretty convoluted network setup with different subnets too. It's just that I prefer to have gateway on the same subnet. If you tried to do that on the ordinary box it would probably refuse to even add the default route. It wouldn't know on which interface to look for the gateway. On the other hand duet neither needs default route (as long as you access it from the same subnet) nor needs to pick the interface, because it kinda doesn't have too many to choose from. So probably it either lives without the default route if you access it from .2. network or just doesn't care much sending stuff to the only interface it has if you access it from both network. As long as it's not complaining, who cares. I don't expect way too sophisticated network stack in its firmware. The bad thing about the duet firmware is that works so well I like never even peeked inside.
BTW, meanwhile I have upgraded my kossel to duetwifi a couple of days ago and it makes like no sound whatsoever. Before that I have changed the e3d's 30mm fan to noctua 40mm silent one, so it neither makes sound when powered up, nor while printingAnd my old duet now powers prusa.
The only thing I'm missing on the new duet is telnet(ftp too, but that sounds like much more hassle to implement, so it's understandable).
