Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 04:45AM |
GrAndAG
They always include extra one as spare. Because this part can be faulty rather often. (Actually, 99% of kits provides spare driver.)Quote
SJN
I thought that I got 5 stepper motor drivers, but one of them is different than the others. What is it ? it looks similar, but not quite if you look carefully.
But mine five were absolutely identical.
If yours have the same (square) chip they are the same too, even if the PCB is slightly differ.
Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 06:49AM |
On the RAMPS board, yes, these terminals are different. But the question was about PSU terminals.Quote
o_lampe
The two terminal pairs feed different parts of the board using two fuses. One is for steppers and general stuff, the other is exclusively for the heat bed.
Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 06:51AM |
Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 08:37AM |
Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 10:04AM |
Alternatively, you can reverse it in firmware.Quote
SJN
Had to reverse the extruder stepper motor plug, as it was extruding backwards.
You can do nothing for it. Just do not use autoprobe command.Quote
SJN
I dont want to install the autolevel probe.
Do I have to disable something in the firmware for that ?
Yes. You have to specify height of your printing area, so the firmware will know the offset of hot-end from printing bed when the hotend is parked on endstops.Quote
SJN
Im guessing that you have to somehow tell the hotend that the printbed is at a given distance from the top endstops, so it knows where 0.0.0 is ?
Re: Ebay SINTRON Kossel Mini full kit December 02, 2016 02:23PM |
Re: Ebay SINTRON Kossel Mini full kit December 03, 2016 09:56AM |
Re: Ebay SINTRON Kossel Mini full kit December 03, 2016 10:20AM |
Re: Ebay SINTRON Kossel Mini full kit December 03, 2016 06:46PM |
Re: Ebay SINTRON Kossel Mini full kit December 08, 2016 03:37PM |
Re: Ebay SINTRON Kossel Mini full kit December 08, 2016 07:10PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2016 02:22PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2016 03:42PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2016 03:54PM |
Re: Ebay SINTRON Kossel Mini full kit December 13, 2016 07:34PM |
Re: Ebay SINTRON Kossel Mini full kit December 14, 2016 05:08AM |
Re: Ebay SINTRON Kossel Mini full kit December 14, 2016 05:37AM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 10:05AM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 11:58AM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 12:10PM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 12:21PM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 01:37PM |
Re: Ebay SINTRON Kossel Mini full kit December 15, 2016 02:53PM |
Re: Ebay SINTRON Kossel Mini full kit December 17, 2016 07:35AM |
Re: Ebay SINTRON Kossel Mini full kit December 17, 2016 12:45PM |
SJN
Stepper motor driver failed today..... No cooling
I installed the included heatsinks with the thick heat conducting foam pads on them. Ran the printer, and felt the heatsinks, and they were only luke warm...... Fine I thought.
Now, after the failure, i removed the foam, and glued the heatsinks directly to the driver chip, and they get VERY hot! The foam pads stink at conducting heat.
[attachment 87474 IMG_20161217_132844.jpg]
Re: Ebay SINTRON Kossel Mini full kit December 17, 2016 12:58PM |
Re: Ebay SINTRON Kossel Mini full kit December 17, 2016 04:00PM |
SJN
how do I adjust the current ?
I have not changed anything from stock.
My tepper motors are at normal temperature after a long print.
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 04:59AM |
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 11:02AM |
Re: Ebay SINTRON Kossel Mini full kit December 18, 2016 04:03PM |
