Re: Ebay SINTRON Kossel Mini full kit January 21, 2017 04:24PM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 06:27AM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 06:48AM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 07:06AM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 08:58AM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 09:40AM |
uint8_t cnt=0; while(!lcd_clicked()){ cnt++; manage_heater(); manage_inactivity(); lcd_update(); if(cnt==0) { #if BEEPER > 0 SET_OUTPUT(BEEPER); WRITE(BEEPER,HIGH); delay(3); WRITE(BEEPER,LOW); delay(3); #else #if !defined(LCD_FEEDBACK_FREQUENCY_HZ) || !defined(LCD_FEEDBACK_FREQUENCY_DURATION_MS) lcd_buzz(1000/6,100); #else lcd_buzz(LCD_FEEDBACK_FREQUENCY_DURATION_MS,LCD_FEEDBACK_FREQUENCY_HZ); #endif #endif } }
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 01:36PM |
Re: Ebay SINTRON Kossel Mini full kit January 23, 2017 02:54PM |
Re: Ebay SINTRON Kossel Mini full kit January 24, 2017 10:13AM |
Re: Ebay SINTRON Kossel Mini full kit January 24, 2017 03:37PM |
Re: Ebay SINTRON Kossel Mini full kit January 26, 2017 09:16AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 03:18AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 03:41AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 04:13AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 04:56AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 05:15AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 06:01AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 06:05AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 07:17AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 07:40AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 07:58AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 08:05AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 08:15AM |
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 01:26PM |
OG
does it mean that I need to change manual_z_home_pos value ?
so it means I need to increase that value for example from 234 to 236
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 04:44PM |
OG
OG
I answer to my self and others who has similar situation..
I decreased my manual_z_home_pos value by 1mm.. so 234 -> is now 233
I ran few offset calibrating rounds and between rounds I tweaked delta_smooth_offset value so I could find centre points Z
Now I have adhesion problem ->it means no adhesion at all
Re: Ebay SINTRON Kossel Mini full kit January 29, 2017 05:19PM |
I think that you don't have to lower that end stop.. you can tweak the offset for that ..Quote
Wibbles
My bed sloped down towards the Z tower, so I am wondering whether I can lower the Z endstop 1mm, and trick the firmware. I can't test anything properly at the moment as I want to fit a glass bed and a Buildtak sheet.
Re: Ebay SINTRON Kossel Mini full kit January 30, 2017 03:33AM |
Re: Ebay SINTRON Kossel Mini full kit January 30, 2017 05:55AM |
Re: Ebay SINTRON Kossel Mini full kit January 30, 2017 03:21PM |
Re: Ebay SINTRON Kossel Mini full kit January 30, 2017 11:55PM |
